Guys,
I bought a 2000 323ci Cabrio about 6 months ago as a project car. The car was in a minor front fender accident. The owner bought it running, had the damages repaired, then while at the bodyshop asked them to paint the engine bay. They did the job, and while the engine was out it was decided to swap in a Manual Transmission.
The car went back together, and once it was back nearly one piece they found that it would not crank. The dash lights up, but it seems to be in limp mode- for example the little orange light on the shifter is on all the time, even when the car is off, and the blower always comes on with the turn of the key. It does not retain the settings that were in effect the last time the key was "on". This is where I came in.
From what I can see the swap was done semi properly, meaning that most of the parts necessary for the swap were swapped in- as far as modules and sensors go. However I found many loose ends.
I decided the best thing to do was to put the auto tranny back in, seeing as I had all of the parts, then narrow it down from there. I did so, and all of electrical seems to be in order now, but the car still would not crank.
I originally suspected the key or the EWS, because the starter motor doesnt seem to get the signal with the turn of the key. When I cross the terminals the car cranks.
Anyways the car was at the dealership this week, and the diagnosis spit out 13 pages of codes. The main ones (first page) were all related to the DME system- specifically faults with the throttle sensor and pedal-travel sensor (short circuits??). The EWS and keys were not one of the faults. So now I have a problem somewhere between the EWS and Starter solenoid. I had the DME and EGS reprogrammed to the original specs thinking that the manual tranmission may have caused some confusion in the DME. This was not the problem.
The technician then suggested reprogramming the Instrument cluster module (KOM), the light switching module (LSZ or SZM, not sure) and something else (IRH??) but the programming was unsuccessful due to other problems within the circuit not allowing it to accept the reprogram.
So getting back to the diagnostics, I now have the car back in my possession and plan on starting at the top, but at least I know the modules are good. Saying this, I am going to start by locatiing the pedal travel sensor and throttle sensor, which I believe is located in the throttle body (correct me if I am wrong), then seen if there are any shorts or maybe the plug is bad. Maybe I will replace the sensors if the wiring looks good.
A few things to note here:
1. The fuel pump blows the fuse when ever powered- when pump is unplugged under the seat, the fuse does not blow but car still does not crank.
2. The URS rollover is showing up on the diagnosis??
Can anybody help me out? This thing is driving me insane...
-Dan
-Dan
