Status
Not open for further replies.
DIY: How to Code FA for AT->MT swap
1 reading
37K views 4 replies 1 participant last post by  Bali
#1 · (Edited)
Background
These instructions describe how to code an E46 with FA coding for AT->MT swap using NCS Expert. If you have an E46 that originally came with an automatic transmission but was later swapped with a manual transmission and need to code the car for this change, then this guide is for you. This guide does not cover the M3 model.
An E46 built 09/2001+ has the newer style FA coding format. This guide is for those cars.
An E46 built before 09/2001 uses the older style ZCS coding format which is not covered here. See this thread for that: DIY: How to Code ZCS for AT->MT swap
The instrument cluster (AKMB) stores the car’s FA (central coding key). FA describes the specific car, its option codes, factory configuration, etc. The light control module (ALSZ) also stores the FA as a backup copy in case the cluster gets replaced. Coding an E46 for AT to MT swap simply removes the automatic transmission option code ($205) from the FA in both instrument cluster and light control module, and then forces all control modules to pick up the changed FA. Some modules need to know whether the car is AT or MT and others don’t. It’s good practice to code all modules after an FA change.
Requirements
  1. Already made the requisite AT->MT swap wiring changes, see this thread: Auto to Manual Swap Wiring
  2. Working installation of BMW Standard Tools; NCS Expert is used for coding and INPA is used to clear DME adaptations, view settings, and verify coding changes. How to Install BMW Standard Tools
  3. Fully charged battery, or on a battery charger providing at least 12V system voltage
Terms
  • FA: the central coding key for the car, contains all the encoded options (such as 205 for AT)
  • AKMB: instrument cluster module
  • ALSZ: light control module
With all that preamble out of the way, let’s get coding!
Load FA from AKMB
First, we load the current FA stored in the AKMB
Start NCS Expert
Click File, Load Profile.
928226
Click the Expert Mode profile
Click OK
928227
Click VIN/ZCS/FA
928228
Click ZCS/FA f. ECU
928229
Click E46
Click OK
928230
Click AKMB to select the instrument cluster module
Click OK
928259
NCS Expert reads the FA from the module you selected
Notice the $205 option code for automatic transmission in the FA below
928276
#2 · (Edited)
Modify FA in AKMB
Now we modify the loaded FA to remove the $205 automatic transmission option code
Click Enter FA
Click E46
Click OK
928308
Click OK leaving the VIN value unchanged (the VIN characters won't match exactly)
928279
Now you'll be at the FA editing screen
Select the $205 in the list and hit the Delete key to remove it
Click OK
928263
The FA in NCS Expert now has the automatic transmission option removed
Note the missing $205 option code below
Click Back
928264
Notice that all the modules are selected for coding by default
We only want to code the AKMB right now
928265
Click Process ECU
Click AKMB
Click OK
928266
Now only the AKMB is selected for coding
The SG_CODIEREN job is selected by default
We need to change that to the FA_WRITE job to write the modified FA
928267
Click Change Job
Click FA_WRITE
Click OK
928268
We are now ready to write the modified FA to just the AKMB
928269
Click Execute job
It only takes a few seconds for the modified FA to be written to the AKMB
After the status changes from Job active to Job ended, the AKMB has been written
928275
#3 · (Edited)
Modify FA in ALSZ
Next we write the modified FA to the ALSZ, as it is the backup for AKMB.
928281
Click Change ECU
Click ALSZ
Click OK
928280
Click Execute job
928283
The modified FA is written to the ALSZ
It only takes a few seconds for the modified FA to be written to the ALSZ
After the status changes from Job active to Job ended, the ALSZ has been written
Close NCS Expert
#4 · (Edited)
Code All Modules
Next step is to reset the coding on all modules to pick up the modified FA
Now we read the FA from the AKMB to verify that the changes took.
Start NCS Expert
928309
928310
Click the Factory Coding profile to allow the Process Car option
Click OK
928286
Click VIN/ZCS/FA
928311
Click ZCS/FA f. ECU
928312
Click E46
Click OK
928313
Click OK
928314
NCS Expert reads the FA from AKMB
Verify the $205 is no longer shown in the FA
The default is to run the SG_CODIEREN job on all modules, which is what we want
Click Back
928294
Now we want to code all the car's modules from this new FA so they all pick up the change.
Click Process Car
928299
Click Code Car to begin coding all modules
928298
Wait a few minutes as each module is coded back to its defaults using the new FA
Sometimes a module will not be found or fail to code. In this case just code the module individually.
Sometimes one of the modules fails to code and the process stops. The Code Car function fails out on the first module coding failure. In this case just code the rest of the modules singly. Only a few modules beyond AKMB (cluster) and ALSZ (lighting) need coding for manual swap: ABS/ASC/DSC, LCM, and maybe GM5, IHKA.
Done!
#5 ·
Clear DME Adaptations
After this, the only other thing you must do is clear the DME adaptions. This triggers the DME to pick up the new FA.
How to Reset Adaptations
Notes
Status
You have insufficient privileges to reply here.
