Seen a few posts recently about folks asking what they can code on an e46 using Carly. Also seen a lot of misinformation from folks who likely haven't used it on an E46, but just read the marketing literature (aka BS) at the vendor website.
Today I went through every option that was available on the Carly I have using the compatible Gen2 Carly OBD connector and put them in the attached PDF. As you will note there are severe limitations to what you can code and what values are available.
I was using Carly via iOS but I doubt there are any additional options using the OTG connection and Android as I previously had that setup and didn't see anything more. I was a tester for these folks before they launched the product.
I was using Carly on a 2003 330i and it only offers three modules for compatibility coding.
GM5 - Locking and comfort
LSZ- Lighting options
SM - Seat module (only a single option was offered)
Anyway - as I've said before - Carly is fine for newer BMW's (2011+) IMHO but for coding various modules on an e46 you are still far better off using either BMW Scanner 1.4.x or the BMW Standard Tools (INPA, NCS Expert etc.)
In fairness I use Carly on newer BMW's but if you are thinking of this specifically and solely for an e46 there are far better options.
Attached PDF shows ALL Carly coding options for this 2003 330i
