Wanted to share my E46 Coupe build that I started a few years ago. I started with a 2002 BMW 325Ci (5-speed manual) that I found on OfferUp. It had over 198,XXX miles but that did not matter as I had plans for this one. My goal is to build a car that'll be fast/reliable (at least I thought) that I'm able to drive on the street and beat it on the track.
First, I got rid of the ugly spoiler it came with and put a muffler since it was straight piped and also ordered CSL wheels.
Fitment was tough and had to go with smaller tires to make it fit (also had to get the fenders rolled).
I drove the car for a few hundred miles before the stock engine decided to give up on me and spin a bearing. Once that happened, I dropped it off to Amor Autosports located in Santee, CA and started ordering more parts.
BC coilovers were the first things ordered but ended up selling it and going with PartsShopMax coilover kit to accommodate my setup.
Also ended up ordering upgraded upper/lower control arms, poly bushings, subframe reinforcements, and z32 brakes from PartsShopMax. CAE short shifter, hard motorsport poly rear windows, and some other M3 parts to be able to support a 800-1000hp car.
Sparco quick release, steering wheel, and seats were also purchased. I had a MOMO steering wheel with a NRG quick release but unfortunately they were stolen since the car could not be locked.
I was able to source a 6 speed manual transmission and complete rear end that came off a 2005 E46 M3. The original differential was welded so I wanted to get rid of that.
I was also looking at HGK and the high quality parts they supplied and ended up ordering a carbon roof, trunk, dash, and door panels.
Found a replacement engine to install and wanted to do something that would make the car have the power/torque that I wanted. My options were either a S85 V10 engine or a 2JZ non-vvti. I was more interested in the V10 but making it reach the power I wanted and hearing about the reliability issues pushed me away from it. Even though it was a BMW engine that sounded amazing. Fitting it in the E46 engine bay would be a challenge so I decided to avoid that and go with a built 2JZ engine which definitely will not please the purists.
I had it built all the way over in Bahrain with a shop I am familiar with and arranged it to be shipped out to San Diego. The 2JZ engine setup was getting the heads ported, 272 cams, BC rods and pistons, HKS GT-III turbo, and mating it with an AEM Infinity standalone.
Due to Covid, there were many delays with shipping. After waiting half a year it finally showed up.
The guys at the shop went right in and dropped the already blown stock engine.
Started assembling the 2JZ and getting it ready.
Welded the reinforcement plates for the subframe
Got the reinforcement plates, bushings, diff bushings, trailing arm bearings, control arms, and rear end installed including the brakes.
Transmission got mounted on the engine
It's in!
Custom transmission mounts made too
Definitely exciting to see more progress being made.
After doing some research, it turned out that the HKS turbo won't be the best option for me considering it being an old turbo.
Sold it and shipped it to a friend in Oman then purchased a Garrett G35-900 Turbo that was recommended by JP at Amor Autosports.
Turbo got mounted with new fuel filters and lines and catch can routed and all braided to be E85 compatible.
It's in!
