1 - 6 of 6 Posts
So, I'm driving an 03 330xi and it's giving me a bit of trouble.
Before I get into it, I'll sadly admit that this one is an automatic with tiptronic :(
First, it has a whistling noise when i'm putting a low to moderate amount of throttle on it. I don't know if this is just a characteristic of automatic cars... somebody told me it was the intake. But I also heard something about a possible tear in an elbow (they didn't specify).
Second, when i'm doing a slow U turn on my hill with the wheel in a full turn, there seems to be a low "pop" noise that comes from the back about halfway through.
Third, I noticed when I turn it off that first, there is a rush of air supposedly from the intake and a flap on it but then a moment later there is a short gear-like grind that comes from the back.
My final issue is the one that worries me. Twice now, when at a complete stop and I slowly start to accelerate, the car won't respond. Instead it makes tiny jumps forward over and over again until the engine dies. First time, i got out, made a phone call and it was fine after. The second time, I started it up again much sooner and it had the abs, brake, and dsc (caution triangle w/ circle) lights on. Got back, let it sit, and no lights later when I restarted it. I was thinking fuel pump or filter at first. Others have mentioned transmission not catching or a few other things. Any ideas or experience with this?
I know this is a lot of questions, but some of them could be nothing from what I have been told so far.
Any help or experience with these is appreciated!
Thanks guys.
CEL? It should have triggered one by now. If it has go get the codes read and that will tall you a lot about what is wrong. From what you describe, it sounds like you have a leak at some point in your intake as well as something bad on your rear suspension. I would suggest looking on your intake and intake boot for cracks and places that could leak. As for the pop in the rear, I don't know enough about that to suggest anything, but i'm sure one of the other fanatics will have some advice.
Discussion Starter #3 (Edited)
Thanks for the advice, I'll look into that.
And I'll be getting the codes on it tomorrow or the next day to see what's going on. I just figured I'd see what our forum had to say so far while I wait.
Also, no lights are on when I drive it. Only that one instance with the abs, brake and dsc but those went away as well.
Thanks guys.
+1 on intake leak...the 'elbow' on the lower intake boot rips. It's not the only intake thing that rips, but it's the best whistler we have.
Pop from the back on U-turn? Look underneath in the rear end for odd things. I'm thinking maybe a rear sway bar endlink...see if the rubber boots on both ends of them are intact...if not, they're suspect.
The Xi axles seem to have issues, but I thought mostly in the front...don't panic yet!
Look with good flashlight, like my favorite, the xl50.
Whooshing air/flaps on shut down...chewbacca noise maybe? That could be ccv. If you mean back of engine. If not, see if maybe you have a exhaust flap stuck...if you meant at the rear of the car.
There are other whooshing sounds I recall reading about but nothing is coming to mind.
Get someone to shut off car while you listen with a hose in your ear and isolate that sound. CCV is below 2-3 cylinder below intake manifold. That might just want a long hard drive to clean up, but maybe it wants a new CCV.
Final thing sounds like trans. Read up on that some more. It may be you need a trans fluid change/filter change. There may be a programming fix. I don't really follow auto problems too much...it just makes me all the sadder for you guys! :lmao:
Discussion Starter #5
Just an update, along with no CEL being on, my car isn't throwing up any codes... Which i guess is good on it's own, but frustrating.
Makes me think my problem getting going might be a fuel pump issue? From what I've heard, that might not give any codes.
For the popping in the back have someone take a look at the rear diff. My buddies E30 had that same noise at full lock and it ended being something with his diffm(sorry I can't remember what it was :/). Whistle is most likely goi g to be the intake boot rip. But I'd think you'd have a CEL by now
1 - 6 of 6 Posts
