41 - 60 of 77 Posts
· Registered
2002 m3 SAAD RACING STAGE 4 TURBO KIT PRO EFI E85 FLEX FUEL BUILD AXLES FROM SAAD BUILD 6SP TRANS FROM LEVEL 10
BUILD MOTOR BY SOUND PERFORMANCE.
best time to day is ETA 11.021 132.08 mph (only 4th pass and brake my trans) soon to be 6870 new turbo install 9 sec soon with good driving
· Registered
How much power are you making? It seems that with the components you have, your MPH would me much higher. Maximum Psi did this MPH on the stock motor....
· Registered
Discussion Starter · #46 ·
Keep up the good work! Times updated.
· Registered
Hey alenas,
can you give us more details on "6SP TRANS FROM LEVEL 10"
· Registered
Discussion Starter · #49 ·
Just curious what their "built" 6 speed trans consists of. It is not a common procedure. I only know a few guys that refresh the Getrag 6 speeds in the states, and they are just polishing components and replacing damaged parts, not really upgrading the strength of the boxes for bigger power. Take it from a guy that has destroyed plenty of them.
· Registered
:thumbup:
· Registered
[email protected]
[email protected], 2.32 (cosmos328ci) E46 328Ci, 5MT, ESS Twinscrew SC, Haltech, E85, cheap street 255/35/18. (M54B30 eng)
https://www.youtube.com/watch?v=J1KteXstaRU&feature=youtu.be
Temp: 78.8 deg F (26 deg C)
Need more traction. LOL
Tyres spinning freely through 1st and 2nd.
E85 only showing E60 (70% of Full tune) on fuel composition scaler. (reducing tune: less timing) I need to change where I get my fuel from.
cosmos328Ci;[email protected], 2.107 (cosmos328ci) E46 328Ci, 5MT, ESS Twinscrew SC, Haltech, E85, Hankook Z221 (semi-slicks) 265/35/18. (M54B30 eng)
84.2 deg F (29 deg C)
Heaps more traction but car was playing up - would rev slower and not to redline engine miss. (Turned out to be the crankshaft position sensor)
· Registered
Discussion Starter · #52 ·
Nice drop from your previous best! Keep at it!
· Registered
Discussion Starter · #54 ·
keep chopping away!
· Registered
Heaps more traction but car was playing up.
The reason my car was playing up - The Crank Position Sensor was faulty.
Replaced my CPS tonight. I used my CPS out of my old M52TU28 (cause I know it works)
Did mine from underneath the car - quite simple and easy, used a small 1/4" rachet.
The car goes like it should again - :evil: HUGE DIFFERENCE!! :excited:
keep chopping away!
Thanks, now the car is running smooth and revs again I am looking forward to hitting the strip again. Was going to go last Sat, but car was getting worse.
· Registered
We have an update to provide. I drove Alen's SP/Saad/ProEFI E46 M3 to the following:
Shake down pass on low boost
60' - 1.578
330' - 4.548
1/8 - 6.899
MPH - 105.12
1000' - 8.913
1/4 - 10.569
MPH - 137.42
http://www.youtube.com/watch?v=RRRNM8Tb7ng
Specs:
SP Built Motor
Saad Racing Turbo kit, Fuel System, Intake Manifold w/ LS3 Throttle Body conversion & Ignition System
Precision 6870 CEA GEN2 .81 A/R
ProEFI Pro128 Flex Fuel Standalone EMS
Dual Rail Fuel Injector Clinic 1100cc injectors (12 total)
CCW Drag Pak w/ Mickey Thompson 28x11.5x16 ET Street
· Registered
60' - 1.578
330' - 4.548
1/8 - 6.899
MPH - 105.12
1000' - 8.913
1/4 - 10.569
MPH - 137.42
Specs:
SP Built Motor
When do we get to see the high boost runs?
· Registered
Discussion Starter · #58 ·
Went [email protected] on Wednesday with my E46 M3 running pump E75. Bumped the record a bit more from my previous best. Racing again tomorrow at Fall Nationals at Englishtown. My car is still running our production Stage 2 kit with a 6266 journal bearing turbo, stock 130k mile motor, and has about 35k miles on the kit. I have a 3.5" exhaust, larger inlet pipe, and a samsonas dog box transmission.
· Registered
Awesome numbers! Sounds like it's time to bump up to your stage 3 or 4 and take the first U.S. 9 second slip.
That tranny must be insanely fun to shift.
· Registered
Discussion Starter · #60 ·
Bumped the US record a bit more today. Would have been a 9 second pass but I was bracket racing and got out of it for a 10.0 dial-in. We will go 9's on the stock motor for sure.
41 - 60 of 77 Posts
