Just had the check engine light come on in my 02 325 XI and had it plugged in at autozone . 2 codes came up .
1.) P0492 secondary air injection system (bank 2)
2.) P0491 secondary air injection system (bank 1 )
The code reader recommended that the likely solution is the replace the smog pump. Now this is a 300$ part that I would rather not replace but will if I have to . My question for you guys is taking into consideration that I have never replaced the upper or lower intake boot , or DISA gasket , and the outdoor temp sensor is no longer with us thanks to the previous owners, could this be a vaccume leak? . I know all these things I'm listing are all connected to each other eaither physically or electronically . I do hear a new hissing sound around the top back drivers side of the engine closest to the cab , and
The car does start a little rough in the morning but immediately smoothes right out .
Any and all input would be appreciated .
