Help. When engine is at 5-6K rpm's (like when passing someone) the engine stutters and decides not to go over 4000 rpm's even when the pedal is floored!! If I shut the car off and turn it back on, it runs fine until I am at hi rpm's again. When the engine cuts off it hits me like a ton of bricks, like I just hit a wall. Also, when I start the car in the morning, the engine revs down to about 300rpms 6-7 times before leveling out. I am assuming that these two problems are related. I have had a clogged catalytic converter before in an older 325 and that is what the "cut off" sensation feels like. Anyone ever witness this before?? I was kind of hopping it was the engine recall so I can start over with 0 miles!
Thought you may get a kick out of this.. my fantastic BMW dealer just called me and said the all mighty diagnostic computer has the answer... low fuel!! (car was doing this with a full tank so that is rediculous) And he has even better news, they corrected my tire pressure. YEAH! all problems solved. Is there no such thing as a mechanic anymore or are they all "technicians"
