im more amazed at the zipties... that must have taken forever to do..
Exactly. When the needle began to move, I cut the motor and coasted to an emergency pull-off.I thought I read “I got off the autobahn.” So for one you can do this fix without a lift at home in an hour. If you ever see the needle moving and you know you have a leak just hit a highway or travel on a route without stops, traffic or lights. You want the air and remaining water to cool the engine if you are in an emergency. Shut off the engine and coasting at high speeds can add time to that temp gauge. All in all most folks will just pull over let it cool and fight to that destination. Don‘t overheat though, once the light comes on I hear it’s already too late.
Half an hour. Just wanted to hold the epoxy plug on with something which will withstand the pressure.im more amazed at the zipties... that must have taken forever to do..
As Denzel Washington said in training day Ma Ninja…..Exactly. When the needle began to move, I cut the motor and coasted to an emergency pull-off.
From my time in Germany I remember they're very strict on fluids from cars. You couldn't even wash your car on your own drive for lest the soap suds found their way into the water table. They'd throw away the key to your cell if you spilt any coolant on the ground!So for one you can do this fix without a lift at home in an hour.
Yeah, if it was me I'd change it before driving anywhere despite any laws saying I shouldn't. If the stadt Polizei turned up I'd smile politely but lose any ability to speak German.I had a crack in the same location the FIRST time my expansion tank cracked. My advice is just fix it yourself and avoid taking a chance with a 15 minute drive. If the shop is a mile down the road that's another story but that coolant is going to get super hot in 15 minutes. And since the tank gets so hot and is under pressure, it will take that tape off and compromise those zip ties before you even realize it.
Replacing the tank is quite easy but you just have to make sure you catch the excess coolant.
Can’t remember brand. It’s OEM by style, at least.What brand is the new expansion tank?
The installation of aftermarket cooling system parts is strictly verboten.
Won't be Bilstein. They only make dampers. But could be Febi-Bilstein, an entirely unrelated company selling mid-priced products.Can’t remember brand. It’s OEM by style, at least.
EDIT: Looks like Bilstein.
use the bilstein that's arriving to put on the car at your home and then take the 15 minute drive to auto hobby shop to put a BMW original one 🤣Can’t remember brand. It’s OEM by style, at least.
was what the Google image of your ziptied reservoir is supposed to be. I like it!Hood Automotive tire Leg Tread Tire
And William Wallace just yelled from the grave" "FREEDOM"!From my time in Germany I remember they're very strict on fluids from cars. You couldn't even wash your car on your own drive for lest the soap suds found their way into the water table. They'd throw away the key to your cell if you spilt any coolant on the ground!
