Backfire / exhaust pop tune /FLAMES? - Page 7 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 03-11-2019, 10:05 PM   #121
armenh7
My Ride: 325i (Turbo M54B30)
Originally Posted by Harry_de_best View Post
Hey guys, first time posting here but have messed ALOT with the exhaust pop/burble settings.
I'm 99% sure that you aren't getting pops above 3000-4000RPMs because you are not running MS430056. I did all my tuning and modifications on MS430066 and for the life of me could not get it to pop above 3000-4000RPM. I changed at least 10 more tables relating to maximum and minimum ignition angles etc with no effect what so ever.
After flashing to MS430056, and using the timered settings I got pops straight away from any RPM. On MS430066 the timer settings did not work at all.
The only question I have now is the hysteresis tables, not sure why you want the pops to pop at such a slow interval. After studying modern BMWs, they seem to start with a higher hysteresis then drop to a lower hysteresis.
I'm running catless headers with two scorpion mid resonators and a remus rear muffler. I have to retard ignition around -18 to -20 deg to get decently loud pops. I have not messed with any fueling as I don't think its necessary since the pops are loud enough.
Around -9 to -10 degrees I get the modern burble sound, where the pops aren't crackling but are actual burbles.
There are also many other subtle changes between 56 and 66 e.g the time it takes for cruise control to activate (56 is instant on when you press the button on the steering wheel, 66 you have to hold the button down for a few seconds). Overall 56 is much more reactive to changes in the map, e.g I was trying to reduce rev-hang on 66 - the changes I did seem to reduce it but when I loaded the same numbers on the 56 map, the rev-hang was reduced so heavily it was like a race car, the car would shake after letting of the throttle - I could feel the diff bushing wobbling lol.
I guess if you want your car to spit fire, you will have to add fuel and retard ignition timing heavily while having the correct hysteresis. You'd want big hysteresis numbers at high RPMs to keep the flame going.
[EDIT] Forgot to mention, the ip_t_puc_deacc tables work super well based on gear, so for myself in gears 4-5 I have the burble much shorter than in gears 1-2-3. Makes daily driving much less painful as I have no cats. This method completely negates the need to disable fuel cut (ip_n_min_puc rpm > Redline rpm) since if you are coasting it will burble non stop and get really annoying.
I discovered how to get pops above 4k rpm. I use version 66. You edit the linked y-axis table to your desired rpms.
One issue I discovered from doing that however is that no matter how much or little I retard my timing, the pops sound like pops vs a burble. I prefer a burble
With timered pops, I can't get anything in park/neutral.
armenh7 is offline   Reply With Quote
Old 03-11-2019, 10:13 PM   #122
Harry_de_best
My Ride: E46 330i
Year: 2002
Model: 330i M Sport
Transmission: Manual 5spd
I tried editing Y-axis on ver 66 however that did not change anything for me. I tried editing much much more and could not get anything consistent.
To get pops in neutral you need to edit the table at 0xBD4C. The MS430056_64K.xdf doesn't have this defined, you have to use the XDF with the launch and no lift shift, it has 0xBD4C defined. The table is called ip_t_puc_deacc__n__maf_mmv.
Standard that table is all 0.
If you want burble, change your hysteresis to lower numbers while running a less ignition retard. Don't need any changes to fueling, maybe a tiny amount if you have cats.
Harry_de_best is offline   Reply With Quote
Old 03-11-2019, 10:15 PM   #123
armenh7
That's the table I edited in version 66 but still nothing in neutral. I haven't tried with 56 yet.
Here it is popping in first gear (auto). I couldn't get past 6k because it would automatically shift to second https://drive.google.com/file/d/1UZh...w?usp=drivesdk
Sponsored Links
Advertisement
Old 03-11-2019, 10:17 PM   #124
Harry_de_best
My Ride: E46 330i
Year: 2002
Model: 330i M Sport
None of the timer stuff worked for me with 66. Don't know why.
Old 03-11-2019, 10:17 PM   #125
armenh7
See my post. I edited it
Not so complicated install of BMW Tools (Windows XP, 7, and 10)
PA Soft
Driver:
Program:
Old 03-11-2019, 10:18 PM   #126
armenh7
In the video I just posted, that's with timer st 2 seconds. It works for me. The timer doesn't work if you set overrun cutoff to 7008rpm rather than the factory 1200rpm
Old 03-11-2019, 10:19 PM   #127
Harry_de_best
My Ride: E46 330i
Year: 2002
Model: 330i M Sport
Yeah I set all my overrun stuff to factory and it didn't quite work regardless the combinations.
My car is manual, maybe that's why?
Old 03-11-2019, 10:20 PM   #128
armenh7
Shouldn't be. Gear detection is done by speed vs rpm I believe
Old 03-11-2019, 10:22 PM   #129
Harry_de_best
My Ride: E46 330i
Year: 2002
Model: 330i M Sport
I was thinking more along the lines of the auto gearbox ECU doing some funky stuff to the maps - in the bins there are always some maps for both AT and MT....
Old 03-11-2019, 10:24 PM   #130
armenh7
Here are my values
https://drive.google.com/file/d/1MMs...w?usp=drivesdk
If you set the very first map to 7008 at 90C, it will pop endlessly and will ignore your timer maps
PA Soft
Driver:
Program:
Old 03-11-2019, 10:26 PM   #131
Harry_de_best
My Ride: E46 330i
Year: 2002
Model: 330i M Sport
Mine are quite similar in 56 however I have much lower hysteresis, a range of 96, 128 and 160.
Lower gears with lower hysteresis, higher gears with higher hysteresis.
Old 03-11-2019, 10:37 PM   #132
armenh7
Is it a 330?
Old 03-11-2019, 10:45 PM   #133
Harry_de_best
My Ride: E46 330i
Year: 2002
Model: 330i M Sport
Is it a 330?
Yes
Old 03-12-2019, 02:51 AM   #134
sda2
My Ride: BMW E46 330i Touring
Try setting id_n_hys_min_puc__vs__gear to 7008rpm in the upper line to deactivate it completly or set c_t_puc_deacc_vs to the amount of delay in seconds you want.
..:: Visit
- the ultimate Siemens MS wiki ::..
sda2 is offline   Reply With Quote
Old 03-12-2019, 03:41 AM   #135
Bertrum
My Ride: 99 323ci
I found running a little leaner really helped the flames come out from the exhaust.
(Completely straight through)
Please like, comment and subscribe ***x1f607;
Bertrum is offline   Reply With Quote
Old 03-12-2019, 09:23 AM   #136
cwarel
My Ride: 330ci coupe
Leaning mixture only helped in short term , as I think it makes exhaust pipes hotter quicker because of higher egts, But after i was able to heat me exhaust through hard driving , with extra fuel I had flamebowls like a flamethrower. I wish my car was still NA.
cwarel is offline   Reply With Quote
Old 03-12-2019, 11:35 AM   #137
LKMT
My Ride: N/A
The reason ip_t_puc_deacc__n__maf_mmv is set to all zero is because it's never used in the ecu code on any software version. That is also the reason why it doesn't exist in the new xdf files
When the car is standing still it will use c_t_puc_deacc_vs instead of the ip_t_puc_deacc tables.
LKMT is offline   Reply With Quote
Old 03-13-2019, 01:18 AM   #138
armenh7
I noticed that the new xdfs no longer had that. What value should I set it to though? One time I set the value too high and my engine flooded with fuel
Old 03-13-2019, 02:24 PM   #139
bbaddo
Is there a way to get pops below 3000rpm? I only get 1-2 stronger bangs when I rev to max and after that small pops, how can I get bangs all the way to 1000-2000rpm?
bbaddo is offline   Reply With Quote
Old 03-13-2019, 02:42 PM   #140
armenh7
Modify the lower tables in the map
