DIY E46 Convertible Top Interior Trim Flap Repair - Page 7 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 34 votes, 5.00 average. Display Modes
Old 06-04-2017, 09:10 PM   #121
Aventus7
My Ride: M3 Cabrio
This was a great post by meansartin14. I have replaced both bat wings now and both took me around 2 hours each, the hardest part was moving the top to different positions to gain access to the screws as mentioned by meansartin14. it was very helpful to have another person moving the top to get the best position to fit the screws back into place. I also used a piece of wood to hold the lid up as a safety measure.
I did not need a Phillips screwdriver as all the screws removed were torx T20.
Aventus7 is offline   Reply With Quote
Old 10-24-2017, 08:40 AM   #122
Cayne23
My Ride: 2002 m3 convertible
I there anyway of getting clearer pics?
Sent from my SM-G935T using E46Fanatics mobile app
Cayne23 is offline   Reply With Quote
Old 12-04-2017, 08:03 PM   #123
tomblang
My Ride: 2002 m3
Hey E46 fanatics, I just bought the kit for my 2002 M3 convertible. Everything is going ok except...I cannot find a way to get access to unscrew, remove and replace the spring module, Can anyone help?? Thanks.
tomblang is offline   Reply With Quote
Sponsored Links
Advertisement
Old 12-06-2017, 03:41 PM   #124
mattman928
My Ride: e46 M3
Its a bear. Just move the convertible roof up ad down a bit until you can reach the screw. I found that I had to adjust the position of the roof for different steps in the attachment and threading of the new parts
mattman928 is offline   Reply With Quote
Old 12-06-2017, 07:58 PM   #125
Cayne23
Again, can someone provide clearer pics of where the hoops are screwed into? Or is it a better idea to just refer to the other side.
Old 12-06-2017, 08:00 PM   #126
mattman928
My Ride: e46 M3
Refer to the other side. Pictures are hard to follow since they are 2D and in a touch location. Looking at the other side live is much better
Old 05-06-2018, 07:49 PM   #127
Cayne23
I just finished this repair today. All went well and everything looks and works the way it should. I will note one thing though. When removing and installing the spring retainer. Position your top so that it's sitting down flat on the tonneau cover. This way gives alot easier access to the Phillips screw on the retainer. Also this gives easy access to a screw that is low on the outer frame.
Old 05-17-2018, 10:22 AM   #128
buddman
My Ride: 2006 325ci
Year: 2006
Model: 325ci
Transmission: Automatic
This helped big time!
I know this was posted over 10 years ago, but I loosely used the steps provided to fix my batwing a couple days ago!
Thanks so much for posting this!
buddman is offline   Reply With Quote
Old 09-08-2018, 05:07 PM   #129
opelikamike
My Ride: 2005 330Ci Vert
Year: 2005
Model: 330Ci Convertible
Did this yesterday as drivers side was broken at bottom and passenger side was in process of splitting. Not hard just time consuming but looks great now. Thanks so much. How to do was very helpful.
Mike in AL
opelikamike is offline   Reply With Quote
Old 09-08-2018, 05:08 PM   #130
opelikamike
Year: 2005
Mike in AL
Old 04-10-2019, 08:58 AM   #131
pichleres
My Ride: BMW 330 ci
tops tring fixing
Thanks for the post.
pichleres is offline   Reply With Quote
Old 04-20-2019, 05:25 AM   #132
Bdave
My Ride: M3 HPF Stage 3
I hope to God someone reads my post before you start this job. The DIY is way, way, way too involved. And totally unnecessary.
It is an extremely difficult job to do unless you do it my way.
Under no circumstances do you want to start unscrewing these fittings. It is a nightmare.
Simply get a pair of vice grips and squeeze the lead slugs on one end of each string to set free the string.
Use hemostats if necessary and thread the string through the original existing fittings. You may have to use a lighter to take the strings to a point. Thread string back through the open lead Slug and squeeze it shut. Job done.
It will take you literally one-tenth of the time to do it my way. So the rest of the directions in the DIY are fine. Although I did not use any ordinary fabric glue. I used high strength Loctite brand flexible glue. I bought some ordinary fabric glue and did a test area and thought it was extremely weak and would fail over time. Loctite brand glue seems to be a much more permanent solution. Very strong!
https://www.amazon.com/Loctite-Plast...gateway&sr=8-3
Bdave is offline   Reply With Quote
Old 05-05-2019, 09:21 PM   #133
BobCV
My Ride: 2005 325Ci Conv.
Even though it's nearly 12 years old, this is still a great article. I did a lot of searching and this one never seemed to come up. But one day, as a last ditch effort, and with the right combination of words, I hit this one on Google and it was an instant solution to my problem. I had the repair kit with the batwings, but was really struggling to figure out how to get access to the screw that holds the spring down (I simply didn't have the roof at the proper position). The instructions and photos were key. An hour later and it was done. Thanks meansartin14!
BobCV is offline   Reply With Quote
Old 05-30-2019, 02:02 AM   #134
e46SG318CI
I'm looking to fabricate these parts with aluminum so they last. Will you happen to still have the broken ones to trace out their full dimensions? Thank you
e46SG318CI is offline   Reply With Quote
Old 05-30-2019, 09:04 PM   #135
BobCV
Unfortunately, I do not. Sorry, otherwise I would have been happy to oblige.
Old 05-30-2019, 09:21 PM   #136
e46SG318CI
No worries pls
Old 07-15-2019, 06:42 PM   #137
scrimber
My Ride: e46 325Ci
I've been putting this off for a while since the batwings were pretty expensive, but they recently appeared on amazon under "e46 batwings". Bapmic 54317135351. i'm installing them tonight. https://www.amazon.com/Bapmic-543171.../dp/B01N5EXYRD
scrimber is offline   Reply With Quote
Old 07-15-2019, 07:39 PM   #138
billeldon
My Ride: 2004 325Ci
I've got mine and really need to do one side, but life has gotten in the way. Now it's time. I acquired the car with one broken and the headliner already damaged, but will find an iron-on patch to get it all back together.
billeldon is offline   Reply With Quote
Old 07-15-2019, 09:01 PM   #139
e46SG318CI
Hi scrimber,
Would you be able to note down the dimensions of the bat wings and the locations of string holders?
Am thinking to fabricate these in metal so they don't fail over time like plastics.
Thank you
Old 08-18-2019, 02:59 PM   #140
Andyjo
I just ordered a set off of amazon, and was thinking the same thing, we have a 3D printer and it would be a very easy part to make.
I plan on making a cad model, will post the drawing when I finally do it ***x1f601;
Andyjo is offline   Reply With Quote
