Pre-cat Oxygen Sensor DIY (lots o pix) - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 23 votes, 5.00 average. Display Modes
Old 03-24-2006, 09:48 PM   #21
r0x
My Ride: 2001 325Ci
Originally Posted by Tom Busby
Awesome write-up and pictures on this thread by rOx.
And prescient screenname-choice by rOx don't you think?
Thanks. You're too much, Tom!
Hey, if I could afford to replace four oxygen sensors at once,
1) I wouldn't be working on my BMW by myself
2) It would be a Ferrari, not a BMW.
r0x is offline   Reply With Quote
Old 03-25-2006, 03:27 PM   #22
maxnathan
My Ride: 2004 m3 ESS VT3
Awesome write-up!
Clear, concise and helps save the moolas that those bmw dealers steal......
maxnathan is offline   Reply With Quote
Old 03-25-2006, 04:51 PM   #23
Ivegotissues666
My Ride: 88' BMW E30 SETA
Send a message via AIM to Ivegotissues666
Originally Posted by FFWD
According to my shop, only the two pre-cat sensors are shorting. They said I should change all four since the two post-cats will probably go within a few months.
I doubt that. The Post-Cat O2 sensors mainly deal with emissions monitoring and if there were a problem you would most likely not find out unless you failed emissions due to an annual inspection.
If you want preventative maintenance then let the shop do them. But honestly they won't go in a couple of months BTW how many miles on your car? O2 sensors supposedly are able to hold out for 100,000 miles.
I replaced all 4 for preventative maintenance purposes around 55,000 miles give or take
Jared
Check out my Other DIY's
Ivegotissues666 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 03-31-2006, 12:06 AM   #24
FFWD
My Ride: 99 323i, 01 M3 Cab
Car has about 200,000 km's (125,000 miles).
Jared
FFWD is offline   Reply With Quote
Old 07-18-2006, 09:02 PM   #25
6strings
My Ride: 2000 328ci
is there anywhere else to get 02 sensors cheaper?? bavauto.com sells them for 100 for pre-cat and 110 for post cat each. i need to get mine replaced as well since they are throwing the SES light.. codes p1188 n p1189..
after reading.. it seems that usually the pre-cat sensors are the ones that need to be replaced rather than the post cat.. does p1188 and p1189 mean that both pre and post sensors need to be replaced ?? why are there two codes? thanxx
6strings is offline   Reply With Quote
Old 07-18-2006, 11:08 PM   #26
FFWD
Before you go and spend the money on the O2 sensors, make sure that's actually your problem. Although all my errors indicated O2 sensors, the root cause turned out to be a defective crankcase vent valve (aka oil separator). My shop wanted to charge me $1500 to change all 4 O2 sensors. Luckily I went for a second (and third, and fourth) opinion, and decided to try replacing the $50 part first (although the labour to do so turned out to be a nightmare). Once that part was replaced and the codes reset, car has been fine. Telltale signs are a fog horn sound when you turn your engine off.
Old 07-19-2006, 12:11 AM   #27
Mikaly
My Ride: TiAG 323i on 19s
Great, clear DIY. Nice job on the writeup.
Mikaly is offline   Reply With Quote
Old 07-19-2006, 08:23 AM   #28
6strings
My Ride: 2000 328ci
there is a fog horn sound but its not a loud sound.. when i turn my engine off i have to open the door in order to hear that sound. it sounds like the fan turns off and then theres this faint little fog horn sound like "errrrr" for a few seconds.
where can i find this 50 dollar part? is it a diy? all the signs point to o2 sensors tho.. slower performance, delayed acceleration.. did u still get these signs even with that defective crank case valve?? thanx for ur input!
Old 07-22-2006, 11:31 AM   #29
coolguy660
My Ride: IS GONE....
Send a message via AIM to coolguy660
Yeah I wanna Know where to get the $50 dollar part and the DIY on it.
I replaced the Pre-cat O2 Sensors but the light is still on and The car won't start after its been on for awhile. Or what else could the problem be?
coolguy660 is offline   Reply With Quote
Old 11-07-2006, 01:59 PM   #30
dillard
My Ride: 2004 M3 Cabrio
Did anyone ever know the answer to this question? I'm getting both P1188 and P1189 codes too. I sure would like to know if I can narrow the problem down to specific O2 Sensors.
Proud owner of '04 M3 Convertible:
dillard is offline   Reply With Quote
Old 11-07-2006, 10:16 PM   #31
FFWD
Do a search on "fog horn" in the DIY forum. Here's one of them. Note - this is a pain in the a$$ DIY. I'll see if I can find the part number for you also.
https://forum.e46fanatics.com/showthr...light=fog+horn
Old 11-07-2006, 10:21 PM   #32
FFWD
And here's another thread with a link to the RealOEM site and part numbers. You'll probably want to replace all the hoses and tubes while you're at it, especially if the car is older. Make sure you double check with the dealer if your car is a cold weather model or not. Two dealers told me different things after providing my VIN to them. I ordered the non-cold weather model (even thoughI am in Canada), and ended up with the wrong hoses. The valve fit fine, though.
Old 11-11-2006, 01:44 PM   #33
nughaud
My Ride: '01 330CI / '11 335i
Thanks for the write-up... I'll be doing this later today. I had to buy the O2 socket and the 12" extension. You do need that extension I can tell you that.
nughaud is offline   Reply With Quote
Old 11-11-2006, 06:35 PM   #34
nughaud
One thing which you did not mention or I missed it is that the you need to do this when the engine has just recently been run and the engine is hot.
This will enable to O2 sensors to be more easily removed. Doing it while the engine is cold could resort to stripped O2 sensor head or the threads which is NOT good.
Old 07-21-2007, 02:25 AM   #35
vids_blk323Ci
DFW
My Ride: JB 323Ci SP PP
Send a message via AIM to vids_blk323Ci
Thread revival time! Excellent write up! okay I Need the OEM part number for the pre cat sensors. NE1 have them? I found the post cat sensor DIY. Cross-linking for reference: https://forum.e46fanatics.com/showthread.php?p=4719022
btw, pre-cat sensors are running $93 each at bavauto. NE1 have a better place to get them from?
Dinan Stage I S/W | ACS RSB | ///M FSB |UUC TMEs & Pulleys |Ate Slotted Discs | ScanGuageII | RockyMounts MTB Carrrier | OEM Rear Clears | LED Euro City Lights & Rear Fogs | Two-Tone Suede DIY | ACS Pedals | Bimmian Gauge Rings & M3 Face | Smoked Frnt Corners w/ Luxeon LEDs | EAS CF Roundels | JLevi Ti CF trim | Blk Suede shift/ e-brake boots | ECS Smoked Frnt Bumper Reflectors | DICE Duo
vids_blk323Ci is offline   Reply With Quote
Old 07-21-2007, 04:00 AM   #36
vids_blk323Ci
DFW
found a good flowchart to add to this writeup: http://www.obd-codes.com/trouble_cod...1-sensor-1.php
Old 09-29-2007, 11:19 PM   #37
joserse46
just did this I found removing the secondary air pump and the windshield wiper reservior (which is very easy gave more room for the sensor closest to the bumper. My old sensors look identical to the ones in this thread, I thought it was so white and ashed from the Seafoam stuff
joserse46 is offline   Reply With Quote
Old 02-17-2008, 06:50 PM   #38
oberonmsu
Just used this DIY to do the sensors in my 2000 323i. Was easy as pie, and reading this was a HUGE help. The only dumb move was when we switched up the wiring harnesses, car ran like crap. Quick fix though.
oberonmsu is offline   Reply With Quote
Old 02-22-2008, 09:49 PM   #39
emg2919
My Ride: 2001 BMW 330ci
doing this tomorrow...hopefully this fixes my rough idle and misfire issue. even after changing coils, plugs, boots, disa, cleaning MAF, new stock Air Filter, sea foam, and some other things.
emg2919 is offline   Reply With Quote
Old 02-22-2008, 10:37 PM   #40
Speeder
My Ride: '04 325i - '08 C300
Are you getting an SES light?
You might wanna check out this thread as well:
https://forum.e46fanatics.com/showthread.php?t=342081
After 2 months of fishing for the cause of rough idle on my car, it turned out to be the same problem discussed in there.
Good luck!
Speeder is offline   Reply With Quote
