What's up with this engine support bar? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 08-05-2019, 12:04 AM   #1
kd7iwp
My Ride: 2001 325i, 2009 535x
I got this cheap engine support bar given to me and am about to use it to hold up the engine to take out the sub frame. Thing is, it's got a weird setup. As seen in the photos it has these three bolts at the part which holds the base on. Any ideas what the top two are for? Tightening the bolts does not squeeze the bottom part (that has the rubber feet) since the metal tabs are to thick to squeeze and so the whole red bar rotates fore and aft roughly 30 degrees. I would imagine it should be tight.
Also, the opening to hold the base is quite wide and there is so much slop that you can't come anywhere near tightening it down. This means the bar flops back and forth. I can get some washers to put in as spacers (it comes with one but that's not nearly enough). Any thoughts on how to use it?
ID:	781155   Click image for larger version
ID:	781157   Click image for larger version
kd7iwp is offline   Reply With Quote
Old 08-08-2019, 06:48 PM   #2
kd7iwp
As an update, I made a slight modification and it's working great holding up the engine in my E61. Rather than placing the footing between the two arms coming off the beam dealing with the slack between them, I got longer bolts that go through and attach the feet to the outside of the two arms. Anyway, it's working really well for me and I can completely lock down and control the angle of the beam.
