N46B20 Fuel injector cut off. - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 08-01-2019, 09:37 AM   #1
haansson
Hi!
I've got an -04 E46 touring, with the N46B20 engine.
It cranks but wont start, I bought it like this, cheap.
anyway, I've checked the timing on the chain- OK!
I've checked the sparks - OK!
but the fuel injectors wont open/give pulse.
Every injector shows 12.5ohm.
On the + side i've got 12v
on the - side i've got 3v
between the two i've got around 8v
The car starts if i spray it with starter gas.
Is there anything that will cause injection cutoff like this?
besides crank and cam sensors?
I just ordered a K+Dscan cable for Inpa.
so i havnt checked the faultcodes yet..
kind regards!
haansson is offline   Reply With Quote
Old 08-02-2019, 08:56 AM   #2
markusmarkus
My Ride: 2018 M240i
The first step in diagnosing a problem is to scan the engine computer (DME in BMWspeak) for codes.
Old 08-11-2019, 02:01 PM   #3
haansson
so the scanner reads:
2F45 - EWS3.3 Interface DME-EWS
any tips?
Sponsored Links
Advertisement
Old 08-12-2019, 08:12 AM   #4
markusmarkus
My Ride: 2018 M240i
What scanner are you using?
Old 08-12-2019, 09:42 AM   #5
haansson
INPA.
On the EWS i've got this code
15 power on reset
Static error
Old 08-13-2019, 08:49 AM   #6
markusmarkus
My Ride: 2018 M240i
It sounds like the EWS isnít allowing the DME to send a ground to each of the injectors. The injectors have 12VDC as long as the ignition is in the run or start positions. The DME provides the ground to fire the injector. This same set up is used for the coils. My suspicion is the key isnít aligned with the EWS. Search this forum to find the key alignment procedure.
Old 08-15-2019, 01:13 PM   #7
haansson
SOLVED!
aligned the dme and ews and it started right up
thank you!
Old 08-16-2019, 08:26 AM   #8
markusmarkus
My Ride: 2018 M240i
Youíre welcome.
