DIY: S54 Chain Tensioning piston Install on M54 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 05-16-2015, 10:30 AM   #1
paraklas
My Ride: B30_TS2++
Year: 2001
Transmission: 5-Getrag
Finally decided to change my M54 camshaft chain tensioner with one from the S54. The benefit from this is a stronger push to the chain guide, making the rotation of the chain smoother (less slack?). For sure, once installed, I noticed the engine running just a tad less noisy.
The S54 tensioner is pricey; $250, however I managed to get a deal from ebay for only $50. A new crush washer is mandatory which I purchased from dealer $1.
TIS Instructions:
Tensioner.pdf
Tools:
1/2" ratchet
32mm socket
10mm socket (for the windshield reservoir)
Lots of rags, some oil will spill once the old tensioner is almost removed.
The new (used) S54 tensioner:
32mm socket
Old one still on engine:
Closer with the windshield reservoir removed
Cleaned and ready for install with new crush washer
I tried a lot of extensions, angles, etc, but this is the only thing needed to get the old one out/new one in
RAGS
After some time, it broke loose and removed. Set them side to side: (Left: S54 / Right: M54)
Getting ready for install:
The tensioner is spring loaded, so you need to tighten it while pushing it in.
Used one hand to push and the other to twist
Old 05-16-2015, 10:51 AM   #2
Kye7
My Ride: BMW 2003 330xi
Cool and easy DIY.
Why exactly did you do this, were you having problems?
Any other benefits to this?
Kye7 is offline   Reply With Quote
Old 05-16-2015, 10:55 AM   #3
paraklas
My Ride: B30_TS2++
Year: 2001
No problems at all, just read a bunch of topics regarding this "upgrade" basically. Found a cheap part (was not going to spend $250 for this) and did it. For added benefits, I will post again after I put some miles on it. Right now I just started the car to check for leaks etc.
Sponsored Links
Advertisement
Old 05-16-2015, 12:32 PM   #4
Solidjake
Shifting
Solidjake's Avatar
My Ride: 2013 328i 6MT
Any reason for the height difference? (from the base of the sensor to the tip?
Old 05-16-2015, 01:28 PM   #5
paraklas
My Ride: B30_TS2++
Year: 2001
Different construction entirely. The pistons are different as well, the springs inside are different as well. For sure the spring tension is around 50% more than the M54 version.
Old 05-16-2015, 01:34 PM   #6
Solidjake
Shifting
Solidjake's Avatar
Gotcha, thanks man. Good guide
Old 05-17-2015, 03:51 AM   #7
paraklas
My Ride: B30_TS2++
Year: 2001
Original thread of inspiration here
Old 08-28-2015, 10:14 PM   #8
rkneeshaw
My Ride: 330i ZHP
hey paraklas, hows it running now that you've put a few miles on her? still feel quieter and smoother than before the mod?
2003 BMW 330i ZHP
ESS Twin Screw Stage 2+ - Wavetrac - Headers - Borla - BMW Performance
Turner Motorsports - Powerflex - Hawk Performance
Build thread:
Wheelwell:
Fuelly:
rkneeshaw is offline   Reply With Quote
Old 09-01-2015, 05:06 AM   #9
paraklas
My Ride: B30_TS2++
Year: 2001
I have put around 1200-1300 miles after the mod and an oil change (was due anyway). Still feels quieter and smoother throughout the rpm range
Old 06-26-2016, 01:53 AM   #10
paraklas
My Ride: B30_TS2++
Year: 2001
31200 miles later update.. all ok
Old 07-22-2016, 03:03 AM   #11
Delineation
My Ride: Schwarz 06 325ci
Interesting DIY. Keep updates coming. What is the part number for future reference?
They said I could become anything, so I became a BMW owner.
Delineation is offline   Reply With Quote
Old 08-17-2019, 02:59 PM   #12
Mark II
My Ride: E46 330i + E39 M5
BMW 11317838675 - actual p/n (~$180)
BMW 11311404438 - old p/n
I also noticed aftermarket tensioner replacement p/n:
Ina 551004810 (~$75)
Hi there! Have you rev your engine to high RPM or maybe used it on racetrack?
Mark II is offline   Reply With Quote
