**E46 DYI: How to make Cigarette Charger turn ON/OFF with ACC** - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 10-26-2014, 09:40 PM   #1
psuryava81
My Ride: 2005 325xi
Hi All,
I have got several useful tips and tricks from this forum. But for the Cigarette Charger I never found a good fix. The one's I found were very dangerous hack-job driving both the cigarette charger and radio off of the 5Amp fuse. I set out to find a better solution without spending too much. Below is the solution I came up with. This solution maintains the two separate circuits for Radio and charger with their respective fuses.
Diclamer: I do not take any responsibility if you screw up and anything on your car is damaged. This tutorial merely documents the steps I followed to get the fix working on my 2005 E46. If your car is any other year I strongly recommend verifying the fuse board layout is similar to 2005 E46 before you proceed.
Things you will need.
1. Add a Circuit ATC Fuse-TAP
Imge Link https://ibb.co/kRPv6v
2. A donor fuse to to extract a spade connector
3. Digital Multimeter
Steps.
1. Remove the 5Amp fuse from position 7. Start the car and verify the Radio does not turn ON. Keep the Fuse Aside. Refer to the Fuse placement chart under the fuse board if the Radio turns on after you start the car.
2. Now remove the 20Amp fuse from position 47. Verify the cigarette charger does not work anymore. Keep this aside.
Refer to the Fuse placement chart under the fuse board if the cigarette charger still works.
Image Link https://ibb.co/i1dYta
3. Now place the 5Amp fuse in the bottom row of the fuse tap and the 20Amp fuse on the top row of the fuse tap. See pic below.
Image Link https://ibb.co/f1YBeF
4. Now break the donor fuse to yield a connector as shown below
Image Link https://ibb.co/iuOYta
5. Trim the non spade end of the connector so that it can be inserted on the wire end of the fuse tap.Make sure it is set in firmly.
6. Using a set of pliers crimp the wire end to make the spade connector set in place. Pull the spade connector with some force and make sure the spade connector does not fall out or move too much.
Image Link https://ibb.co/eUDNmv
7. Now place the fuse tap in position 7 and the wire with spade connector on the top end on position 47. *********Make sure you dont plug it in the lower end as that is always +12V ********* Doing so might damage the switching circuit when you start the car*******
Image Link https://ibb.co/hcJYta
8. Now start your car or put the key in ACC position and verify the Radio and the Charger turn ON. Turn your car off and the charger should turn of as well.
9. Now carefully tuck the wire in a good position and lock the fuse board back in place. Verify again by starting your car that it works and nothing was unplugged when you put the fuse board back in place.
You should be all set
Prashant
psuryava81 is offline   Reply With Quote
Old 04-01-2015, 12:10 AM   #2
turbosnow
My Ride: 2002 330ci Vert
Worked, great, thanks!
Instead of using a disassembled fuse, I crimped a spade connector to the end of the wire coming off the fuse tap. Works like a charm.
turbosnow is offline   Reply With Quote
Old 04-18-2015, 11:50 AM   #3
ricecooker713
My Ride: 330 ci
Great idea, so much easier/cleaner than tapping into the radio power or running a new wire
ricecooker713 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 04-18-2015, 12:22 PM   #4
invisible man
My Ride: invisible car
You bought a fuse tap but you couldn't buy friggin spade connector?
Giubo. G I U bo. Pronounced joo-boh. Don't allow yourself to sound ignorant.
invisible man is offline   Reply With Quote
Old 06-11-2015, 11:27 PM   #5
monkeyhead
My Ride: 2003 330i
Thanks psuryava81, worked like a charm, freakin awesome !!!
see one, do one, teach one
monkeyhead is offline   Reply With Quote
Old 07-09-2015, 03:40 AM   #6
ripop
My Ride: 2005 M3 Convertible
This was super helpful, thanks!
ripop is offline   Reply With Quote
Old 07-22-2015, 02:35 PM   #7
SeeBee
My Ride: 2004 M3 Vert
Worked like a charm. Thank you...
SeeBee is offline   Reply With Quote
Old 09-01-2015, 09:06 PM   #8
fifty2weekhi
My Ride: 325xi
Did mine today. I am very happy I finally don't have to remember to unplug my GPS!!
The "hardest" part of this easy MOD is to get the spade out of the donor fuse. @invisible_man: I don't see why I would buy a spade connector when I have so many spare fuses lying around. Besides, the spade connector won't necessarily connect any better to the fuse-TAP wire.
One uncertainty I had was the fuse-TAP also had a rating. I only saw 10 amp and 30 amp at my local Advance Auto Parts and I bought the 10 amp one. Not sure it matters if I only use it for GSP and cell phones.
fifty2weekhi is offline   Reply With Quote
Old 10-30-2016, 03:01 PM   #9
U_Fraz
My Ride: 330i
i did it
It took me two calls to my breakdown cover to realise that my insurance tracker + reverse camera's display (two in one rear view mirror) actually do not turn off when i lock the car.
Each time i thought the newly bought (2nd hand) 330i 2004's battery is aged. 2nd time i took it to halfords and they did the free health check and told me its in perfect health. i turned my attention to the costlier possibility of alternator being faulty but thankfully that also was confirmed by Halfords guy to be all fine.
then i realized that the cigarette lighter socket doesnt actually turn off when i take the key out of ignition. i have looked everywhere for a solution but This thread was a life saver. I did exactly as explained used another fuses' leg which i think is the only suitable form of connection in the glove box.
i have tested it and its working as expected. However, i do have a question if anyone can answer. Can this be wired to work only when the car is ON (engine is running)?
U_Fraz is offline   Reply With Quote
Old 11-09-2016, 10:37 AM   #10
VladBelsky
My Ride: E46 roadster/E85 Z4
Year: 2003
Model: 3.0i
Transmission: 6-speed
I'm doing this, in order to go with this:
Name:	usb socket.png
VladBelsky is offline   Reply With Quote
Old 05-21-2017, 08:54 PM   #11
ssubhan
My Ride: 2000 BMW 323CI
This was very useful to me. Thanks!!!
I used this to connect to the 'Circuit ATC Fuse-TAP'. It was pretty hard to crimp it in firmly. It came off first couple of times I tried.
'MALE TAB QUICK DISCONNECT'
ssubhan is offline   Reply With Quote
Old 08-01-2017, 08:56 PM   #12
frank15p
My Ride: 330i
anyone have the images for this write up
frank15p is offline   Reply With Quote
Old 08-01-2017, 09:45 PM   #13
psuryava81
My Ride: 2005 325xi
Not sure why the images are not visible on the write up anymore. A couple people have been able to do it just with the instructions. All you need to buy is the fuse tap from autozone and a donor fuse for spade connectors. Here is a link for the tap.
http://www.autozone.com/electrical-a...-tap/32414_0_0
Old 08-02-2017, 03:38 AM   #14
frank15p
My Ride: 330i
not sure what he means by Now break the donor fuse to yield a connector as shown below, and Trim the non spade end of the connector so that it can be inserted on the wire end of the fuse tap.Make sure it is set in firmly. Using a set of pliers crimp the wire end to make the spade connector set in place. Pull the spade connector with some force and make sure the spade connector does not fall out or move too much, pictures would be great thanks tho
Old 09-04-2017, 03:08 AM   #15
frank15p
My Ride: 330i
Anyone have pics
Anyone have pics for this mod pleasee
Old 09-04-2017, 07:04 AM   #16
madmaxxk
My Ride: 2004 330ci
Pics are here
I did a little digging around and found the original pics. Your welcome http://s864.photobucket.com/user/psu...?sort=3&page=1_nr_
madmaxxk is offline   Reply With Quote
Old 09-12-2017, 01:22 PM   #17
frank15p
My Ride: 330i
thank you!!
Old 12-28-2018, 05:46 PM   #18
camrydriver111
My Ride: 05 325i
If the smaller fuse is on the bottom wouldn't your cigarette lighter blow the radio fuse?
The way it's set up the up cigarette lighter current (up to 20A) goes through the 5A fuse.
camrydriver111 is offline   Reply With Quote
Old 01-03-2019, 04:52 PM   #19
jaga
My Ride: 2002 325i
Year: 2002
Model: 325i
Transmission: Automatic
Great DIY!!!!! I just did ir and it worked perfect... thanks a lot.
Sent from my SM-A310M using E46Fanatics mobile app
E-FortySicks
jaga is offline   Reply With Quote
Old 08-09-2019, 03:30 AM   #20
SupraJari
My Ride: e46 325ix
Year: 2000
Model: e46 325ix
Transmission: auto
One more completed this mod and it *simply works* !! Thanks!!
SupraJari is offline   Reply With Quote
