Bluetooth no sound problem - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > Tuning & Tech > Mobile Electronics Forum
Old 07-31-2009, 08:25 PM   #1
bmw_chuzo
My Ride: HPF M3
Send a message via MSN to bmw_chuzo
Hello
I just retrofitted the oem bluetooth and Navigation kit in my car. The problem is that when I try to call or receive calls, I can't hear anyone on the speakers. The radio would still be playing and not mute like it's supposed to.
I have re-cheked the connections between the x13321 plug and the "R" connector in the retrofit kit and its fine. I don't have the plug for the SES jumper since I think i'm using a 03'+ up harness.
I forgot to mention that I have the 13th ULF, and the car is a 2001 m3
thanks
bmw_chuzo is online now   Reply With Quote
Old 08-01-2009, 12:05 PM   #2
BmwAudio32
My Ride: 2004 Imola 330i ZHP
This probably sounds like a stupid question, but you did pair the phone sucessfully, right? It seems as if your pairing was either lost or not saved to the car correctly.
BmwAudio32 is offline   Reply With Quote
Old 08-01-2009, 12:18 PM   #3
bmw_chuzo
My Ride: HPF M3
yes I did pair my phone I can make calls, check my phonebook, etc. I have tried the same with three other phones and still don't have sound.
this problem is driving me nuts
Sponsored Links
Advertisement
Old 08-03-2009, 07:20 AM   #4
champ222
My Ride: 330CI
i would check the wiring between the bluetooth kit to the radio.
there is one pin that mutes the radio, pulls the pin to ground, and "PHONE" appears on the display
there is another pin that allows the audio from the phone to come through the radio. pull the pin to 12v
both these 2 pins are part of the 17pin connection at the back.
the actual phone audio goes into the small cd changer port.
this is assuming you use a business cd / tape, but i would imagine its similar if you have nav
champ222 is offline   Reply With Quote
Old 08-07-2009, 12:49 AM   #5
ZZen330
My Ride: 2002 330Ci
I see it mentioned that the bluetooth retrofit goes into the cd changer port. Does that mean that no other device can use that port, piggybacked, etc? For example a dice unit, or grom aux adaptor (radio or trunk connection).
Thanks.
ZZen330 is offline   Reply With Quote
Old 08-07-2009, 09:00 PM   #6
bmw_chuzo
My Ride: HPF M3
I believe that too. That all goes to the cd changer plug as the "retrofit" instructions say. I have the bm53/54 radio, since that is the one that can be used with the nav monitor or i'm wrong?
Thanks.
I have a dice unit, but I already tested the bluetooth with the dice disconnected and had the same results
