My original DIY guide was causing confusion with owners that had cars either in Europe or cars made before 9/99 and after 3/03. Their feedback led me to discover some new information regarding E46 power folding mirrors.
In shedding some new light on the issue, I managed to simplify and update the original power folding mirrors retrofit guide to include production build E46 cars from 1997 all the way to 2006 as well as European cars.
However, there is still some mystery surrounding the memory bus ribbon mirrors after 3/03 that I discuss below. Let us begin....
For those of us that drive and parallel park in a big city or spend long weekends at the mall parked in those tight spaces between door dinging SUVs then this feature will come in handy if you got about $300 to $500 and a few hours of DIY time to spare. Otherwise, for free you can just fold in the mirrors with your hands.
But who wants to do that when you can power fold your mirrors from the comfort of your driver's cockpit...
http://www.youtube.com/watch?v=4Kzp08Ck1vc
...or from the convenience of your key fob as you remote lock/unlock the car:
http://www.youtube.com/watch?v=bSWJdb4Re28&feature=player_embedded
PART ONE: BMW made at least four types of mirror control switches in as many as six colors for the E46 cars.
On the top side the switches for the mirrors all look the same. However, what each switch really does can only truly be identified by the color of the bottom side of those switches (or also by the parts numbers).
On the bottom side of the manual folding switch we have these three color types:
-Turquiose bottom switches go with memory manual folding mirrors.
-Black bottom switches work with non-memory manual folding mirrors.
-Grey bottom switches are mainly found in European cars with non-memory manual folding mirrors.
(Although not 100% confirmed these Grey switches may provide the tilt-reverse function on Euro cars with non-memory/non-powered seat)
On the bottom side of the power folding switch we have these three color types:
-Purple bottom switches will work on cars with memory power folding mirrors and memory power adjust seats.
-Yellow bottom switches go with non-memory power folding mirrors on cars without memory and no power adjust seats.
-White bottom switches go with non-memory power folding mirrors found on cars with memory power adjust seats.
(This rare White switch is mainly found on pre 9/99 European cars that had this uncanny combination of memory power seats with non memory power folding mirrors)
For the remainder of this DIY guide I will just refer to the switch as the color of the bottom side. So when I write the words "Yellow switch" it will be referring to a switch that has a yellow colored bottom. For early production year E46 and some European E46 cars you may come across a color bottom that is different from what I list here. There could be a multitude of reasons for that but for the most part 99% of E46 cars will have one of these 4 switch types in any of the 6 colors I've mentioned.
PART TWO: BMW made two types of mirrors for the E46 cars:
1. Memory mirrors that operate in cars built after 09/1999 which have memory power adjust seats.
2. Non-Memory mirrors that operate in cars with no memory and no power adjust seats. Non-memory mirrors also come on ALL E46 cars made before 09/1999.
PART THREE: The most important facet of the E46 mirrors that distinguish them apart is how they connect to the car.
1. Both Memory manual folding and power folding mirrors use identical 12 pin-connectors to receive memory, tilt and fold in/fold out commands from the car.
These mirrors simply connect to the car via control modules also called memory modules. Both manual folding and power folding memory mirrors use the same control "memory" module that sits inside each door under each side mirror. These in-door control modules are what provide the mirrors with memory, tilt and power-fold commands.
If your car already has power and memory seats then already it also has these control modules in the doors and you do not need to buy them or replace them when upgrading to power folding memory mirrors.
Again I will reiterate when retrofitting memory power-fold mirrors onto a car with memory/power adjust seats you do not need to buy or replace these control modules. You also should not need to code the control memory modules to fold the mirrors. However, once installed the car will have to be coded to remote control fold the mirrors via the key fob under the convenience features. Cars that have an Intravee II running Version 6.02 installed can also be coded thru Intravee's i-Bus controller to have the mirrors "convenience" fold and unfold a bunch of ways.
Said and done once installed these mirrors will immediately power fold and unfold right away with just the use of the power folding mirror switch.
To update the switch you would need to only replace the turquoise manual folding mirror switch in your car with the purple power folding mirror switch. The switches both use the same connector and are direct plug and play.
Once you have the power folding mirrors and the purple switch then the rest of the DIY is simple plug and play. This type of retrofit is more prevalent in the USA and Canada since more E46 cars in the USA came with memory and power seats.
The DIY is also a simple plug and play project even for the eBay M3 Replica kits that work off the OEM purple power folding switch since the purple switch is all you would need to buy after you get the power folding mirrors.
2. In stark contrast, Non-Memory mirrors connect very differently to the car.
Manual folding mirrors will connect to the car and the Black (or in some cars Gray) manual folding mirror switch using 6 pin connectors that have 5 or less wires leaving the mirror base.
When you have Non-Memory mirrors that are power folding you will have 5 wires on the 6 pin connector at each mirror and a extra 2 pin connector with two wires leaving one of the mirrors.
This 2 pin wire receives the fold in/fold out command from the Yellow or *********** folding mirror switch via a non-memory power folding control module box that sits behind the glove box.
This makes retrofitting Non-Memory mirrors onto a car with non-memory, manual adjust seats a bit more tricky because you need to buy the non memory power folding control module and install it behind the glove box in order to send the power fold commands to the Non-Memory mirrors from the power folding mirror switch. It is also unclear if this module would need coding to get the mirrors to fold right away from the switch. However, this type of mirror can be coded for the key fob remote "convenience" either using an aftermarket device or the OEM coding methods.
A good thing is they are lots of aftermarket non memory power folding modules and parts that cater to the difficulties of installing non memory power folding mirrors in non-memory E46 cars. They are a few threads on them in the DIY section. More information on what kits to get can be found by using Google Search. You will also find this type of retrofit will be more prevalent in Europe and the parts of the world where more E46 cars did not come with memory or powered seats.
3. The E46 BMW Ribbon BUS Revolution of March 2003!
In 3/2003 BMW extended the Memory BUS system to the mirrors which now used ribbon connectors. This created a new set of mirror part numbers for cars after 03/2003.
The ribbon mirrors as they are called still used the same memory control modules as previously used in the 9/99 up to 3/03 cars that came with memory seats. So this retrofit would entail the same journey as before under the memory-power folding retrofit for cars 9/99 up to 3/03. Just get the mirrors and the switch and plug and play them. The only question is whether the car would need dealership coding to get the mirror switch and key fob to fold the mirrors.
Furthermore it is another mystery as to what control module is used on the non memory manual adjust seat cars after 3/2003 for non memory power folding mirrors. The parts database does not show any specific control module that exists for non memory cars after 3/2003.
The final and biggest mystery concerning the non memory mirrors is that the BMW P/Ns for non memory power fold mirrors stays the same from 09/1997 all the way to 2006. I'm not sure if that means BMW didn't update the P/Ns or the actual non-memory power folding mirror housing and wiring stays unchanged for non memory cars over the years. Meaning these cars do not use a ribbon BUS system in the mirrors.
PART FOUR: Follow the letter guide below that most suits your current set up and needs before starting your DIY Project.
Choose A if your car currently has manual adjust seats and no memory functions. Choose B if your car has electric seats and memory. Choose C if you want to retrofit power fold memory mirrors into your non-memory and/or manual-adjust seats. You can also Choose C if your E46 is a pre 09/1999 model and you want to attempt to add memory tilt power fold mirrors.
If you have a USA spec LHD sedan or touring/wagon then simply use the P/Ns in the sections below to purchase your mirrors and parts. Memory power adjust seat cars already have the 2 control modules in the car so DO NOT buy them! I only listed it to show all the ingredients used to power fold the power folding mirrors.
The prices listed below are the average suggested retail price of the parts as of 12/2011. I found the prices to be much cheaper at most of the forum's sponsor web stores (ECSTuning, GetBMWParts, Tischer and even Circle BMW and most online parts stores have much lower prices).
If you have an M3, a Coupe, a Convertible or a Compact (ti) then use www.realoem.com to find your appropriate P/Ns for your car. The mirrors are listed under Vehicle Trim > Outside Mirrors. The switches are listed under Vehicle Electrical System > Switch > Various Switches, Cigar Lighter. The control modules are listed under Vehicle Electrical System > Control Units, Modules, Sensors, Relays > Body Control Units and Modules.
If you have a European car that is RHD or LHD please refer to the www.realoem.com parts catalogue to find the P/Ns you need for your specific car. Sadly, I do not live in Europe anymore so I cannot tell you what will work on certain Euro E46 cars.
USA mirrors have completely different part numbers than Euro LHD and RHD mirrors. Also the mirror pin connectors and wiring that receive the power fold and tilt functions are very specific to the orientation of the mirror relative to the driver's seat. So RHD mirrors and LHD mirrors are NOT INTERCHANGEABLE! This means a USA shopper cannot go on eBay.co.uk and buy European RHD power fold mirrors for his USA LHD car. With in Europe this distinction is also true for countries that have LHD cars and other countries that have RHD.
A: YOU WANT TO INSTALL NON-MEMORY POWER FOLD MIRRORS:
Car's production date is 03/2003 or later
x1 Heated outside mirror, left P/N: 51168245129 $344.82
x1 Heated outside mirror, right P/N: 51168245132 $344.82
x1 Yellow Switch f mirror adjust./folding back function. P/N: 61318373732 $67.34
Car's production date is from 09/1999 up to 03/2003-6 PIN/2 PIN CONNECTORS
x1Control Unit/module outside mirror fold-in function OBSOLETE-P/N: 61358376506 **
or Control Unit/module outside mirror fold-in function NEW-P/N: 61359177976 $83.78**
Car's production date is from 09/1997 up to 09/1999
x1 heated outside mirror, left P/N: 51168245129 $344.82
x1 heated outside mirror, right P/N: 51168245132 $344.82
x1 European Switch f mirror adjust./folding back function. P/N: 61318373689 $67.34
or Yellow or White Switch f mirror adjust./folding back function. P/N: 61318373732 $67.34
x1 Control Unit/module outside mirror fold-in function OBSOLETE-P/N: 61358376506 **
B: YOU WANT TO INSTALL MEMORY POWER FOLD MIRRORS:
Car's production date is 03/2003 or later-RIBBON CONNECTORS
x1 Heated outside mirror, memory bus, left P/N: 51167153087 $438.73
x1 Heated outside mirror, memory bus, right P/N: 51167153088 $438.73
x1 Purple Switch f mirror adjust./folding back function P/N: 61316901383 $67.34
-And you should already have in your car:
x2 Control units, mirror memory P/N: 61356916054 $125.69 (x2) *
Car's production date is from 09/1999 up to 03/2003 - 12 PIN CONNECTOR
x1 Heated outside mirror with memory left P/N: 51167003437 $344.82
x1 Heated outside mirror with memory right P/N: 51167003440 $344.82
x2 Control units, mirror memory NEW-P/N: 61356916054 $125.69 (x2)*
or Control units, mirror memory OBSOLETE-P/N 61356913364 (x2)*
No MEMORY Power Fold-In Mirrors are found in Parts Database! So during these years you can own a 3 series with non-memory/non-tilt power fold-in mirrors in a car that has memory-powered seats OR you can have a 3 series with non-memory/non-tilt power fold-in mirrors in a car that only has non-memory/manual-adjustment seats.
*These Control units/Modules are already in your car and you do not need to buy them for the retrofit if your car seats are electric and have memory. Manual and Power Folding Memory mirrors use the same Control units/Modules.
** This Control Unit/Module for non-memory power folding mirrors sits behind the glove box and is not needed for 03/2003-on cars. This module will require purchase of a 12 pin connector harness:
Socket housing 12 POL. P/N: 61138364664 $0.63 with pig tails and appropriate wiring for the retrofit project.
C. YOU WANT TO INSTALL MEMORY TILT POWER FOLD MIRRORS ON A CAR THAT DID NOT COME WITH MEMORY SEATS:
If your car production date is between 9/1997 up to 3/2003 then See Jared's brilliant thread on how to do that here:
http://forum.e46fanatics.com/showthread.php?t=467677
D. ONCE YOU HAVE ALL YOUR PARTS THEN FOLLOW THIS WRITE UP:
Written by Terry Kennedy on BFest.com way back in 9/2003
Voila your E46 BMW now has a Premium Package 2 feature that comes on all current BMW models!
:thumbsup:
:thumbsup:
