How does one completely drain brake fluid? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > Tuning & Tech > Suspension & Braking
Old 02-16-2018, 01:20 PM   #1
dutchhome
My Ride: 2004 330xi
I would like to completely drain the brake fluid in my wrecked parts car. What is the best process to extract all brake fluid from our beloved E46's?
Should I just use a pressure bleeder and have it pump air through each of the brake lines and clutch slave?
dutchhome is offline   Reply With Quote
Old 02-16-2018, 01:37 PM   #2
TobyB
My Ride: 2004xit, 2001ci
The very short answer is that it's not possible.
There are too many low spots, etc- the calipers, for
example, always have fluid in them.
What I do, given this, is to take things apart as far as possible
(yes, pistons out of calipers)
and take all the lines out of things like the abs pump.
Then let them drain in different positions.
And then store them in airtight bags.
Even then, fluid leaks out over time, so obviously, I've not
gotten it all out.
Compressed air helps a bunch... but it doesn't get it all.
An anti- corrosive coating helps a lot on the caliper parts.
what I've found over the years,
t
TobyB is offline   Reply With Quote
Old 02-16-2018, 01:44 PM   #3
asianisafish
My Ride: 330ci
Pressure bleeder I guess
asianisafish is offline   Reply With Quote
Sponsored Links
Advertisement
Old 02-16-2018, 01:49 PM   #4
paraklas
paraklas's Avatar
My Ride: B30_TS3
Year: 2001
Transmission: DCT GS7D36SG
Disconnect lines from ABS/DSC pump/servo, disconnect other end at calipers, gravity will drain them in a day at most. Remove calipers open bleed valve, put them upside down and will also drain.
Old 02-16-2018, 06:41 PM   #5
Mr Podman
My Ride: E46 Coupe
You don't want to drain all the brake fluid from your system.
podman
Mr Podman is offline   Reply With Quote
Old 02-16-2018, 10:02 PM   #6
dutchhome
My Ride: 2004 330xi
Thanks everyone. We used a pneumatic brake bleeder to pull what we could from the calipers and the clutch. It was able to extract enough fluid that there wasn't any mess when we disconnected everything. I'll be careful when we pull off the booster to make sure we don't end up with any surprises.
Sent from my [device_name] using E46Fanatics mobile app
