FYI: Mechanical Fan to Electric Fan Swap - Page 22 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 40 votes, 4.83 average. Display Modes
Old 06-05-2015, 08:33 AM   #421
Solidjake
Shifting
Solidjake's Avatar
My Ride: 2013 328i 6MT
Part number is 17117561757 and it will fit
You can find more information in my thread below and at the end is a post with the best places to get the fan from
https://e46fanatics.com/forum/showthread.php?t=849735
Make sure that your transmission fluid has been replaced and that the auto trans thermostat in the expansion tank is good.
Old 07-03-2015, 04:18 PM   #422
robin325ci
My Ride: Helrot 325Ci
How's the reliability of the Behr Hella made in China electric fans? I'm considering swapping over to the electric fan but I've read that some people having problems with the Behr fan not lasting long.
robin325ci is offline   Reply With Quote
Old 07-03-2015, 09:18 PM   #423
WOLFN8TR
My Ride: 05 M3
I got the Behr fan when I didn't my Mechanical Fan delete. It was on the car for two years before I sold it. Worked great.
BAVSOUND Stage 1 - UltraGauge - Valentine One - Orion V4's - ARC-8's
TTFS Engine/SMG Tune/CSL 255 - SGT Headers/Sect 1/SCZA - Evolve Eventuri
VIS XTS CF Hood - CF Lip/Console/Diffuser - OE CSL Trunk - BWS 500S 9k/11k
WOLFN8TR is offline   Reply With Quote
Sponsored Links
Advertisement
Old 07-04-2015, 06:09 AM   #424
Solidjake
Shifting
Solidjake's Avatar
Robin, mine is working perfect for over four years already.
Old 07-06-2015, 03:47 PM   #425
robin325ci
Thanks for the feedback WOLFN8TR and Solidjake!
Old 07-10-2015, 04:36 PM   #426
Solidjake
Shifting
Solidjake's Avatar
enjoy the swap when you get it done
Old 07-12-2015, 02:17 AM   #427
MysticBlue
My Ride: 04 330xi & 05 330cab
just did this on my 04 Xi. Easy. I thought the bumper would be an issue....not. Thanks Solidjake for the great DIY and comments!
MysticBlue is offline   Reply With Quote
Old 07-12-2015, 03:28 PM   #428
Solidjake
Shifting
Solidjake's Avatar
You're welcome man, enjoy the swap!
Old 07-15-2015, 08:03 PM   #429
TRITONAL
My Ride: E46, F25
Living down in AZ, few weeks ago it was 115F ambient, and the single Behr Hella fan kept my car at 96C idle, 99C cruising. I'd say it's doing its job just fine
The E46s are the Knights of the chessboard. They can outmaneuver the other, more powerful pieces on the board. They aren't the King or Queen of the garage, but they are the first piece that you want to move.
TRITONAL is offline   Reply With Quote
Old 12-17-2015, 01:03 AM   #430
tatsbykilo
My Ride: BMW e46 323i 1999
I have a problem
So this little box on the fan isn't connected how do I connect it in this conversion , I have a 1999 BMW 323i
tatsbykilo is offline   Reply With Quote
Old 12-17-2015, 01:18 AM   #431
SilberVogel
My Ride: 2002 330Ci Conv.
With the auxiliary fan in front of the radiator removed, you'll use the same plug to power the new electric fan behind the radiator.
Edit: Or are you referring to the AUC sensor? AUC sensor has four wires (two brown, one blue, and one yellow) and is circled in red below:
DIYs help you save money with repairs; let
help you save money with the parts.
SilberVogel is offline   Reply With Quote
Old 12-17-2015, 08:47 AM   #432
Solidjake
Shifting
Solidjake's Avatar
It's still used. The electric fan has a bracket for the sensor.
Old 01-05-2016, 04:14 PM   #433
rhicken
My Ride: 2001 330i
Two Fans?
I have been reading all the threads and posts on this swap and am about to do the swap myself.
One probably dumb question is, can't I just tap into the original plug and run both front and rear electric fans instead of removing the front one?
Thanks.
rhicken is offline   Reply With Quote
Old 01-05-2016, 08:12 PM   #434
CarbonZHP
Because Race...Convertible?
CarbonZHP's Avatar
My Ride: goes choo choo
Year: 2004
Model: 330Cic ZHP
Transmission: AT->5MT->6MT
No need. Youll get better airflow with the fan removed
Original Car: Silver Grey on Grey, A/T (1 of 186)
As it sits: Silver Grey on Black, M/T (1 of 51)
Instagram: @CarbonZHP
CarbonZHP is offline   Reply With Quote
Old 01-05-2016, 08:14 PM   #435
Max'd out
My Ride: 04 330cic
Year: 2004
Model: 330cic
Transmission: auto
The front fan is not that hard to remove. No need to complicate the process.
Max'd out is offline   Reply With Quote
Old 05-20-2016, 10:21 PM   #436
whjeffs
My Ride: 04 Silver Gray 330Ci
I am in the process of this swap as well as some other repairs. One question I have that I did not see a clear answer to in the 44 pages of this thread. Do I put this shroud back on or not? I don't know if airflow through the radiator would be better with or without it.
ID:	632385   Click image for larger version
Jeff
Alpine ics-x7HD
a/d/s 346is
JL Audio 300/2
JL Audio 500/1
(2) Image Dynamics ID8V.3-D4
whjeffs is offline   Reply With Quote
Old 05-20-2016, 11:44 PM   #437
CarbonZHP
CarbonZHP's Avatar
Year: 2004
Model: 330Cic ZHP
Yes
Sent from my XT1585 using Tapatalk
Old 05-21-2016, 11:16 AM   #438
Arsenal2012
My Ride: 330xi
Originally Posted by smaritz View Post
Well the problem that I had was that something went wrong with my car's ECU, and the electric fan it came out with never received a pulse to switch on when needed, resulting in a blown headgasket and cracked head Now the cost of repairing that was rediculous, so I had the autoelectrician just make the fan run with a relay, so it's on all the time on full speed.
I can tell you, that noise was killing me. Last week I had it ripped out and replaced with a clutch fan. That's me, happy
This is my fear, how can I test that a signal is being sent for my Aux fan to kick on? Do I have to start my AC, wait and pray?
Also someone asked at what temps does the fan come on at, did anyone answer? I only read to page 6 excuse me if someone did.
Thanks,
Arsenal2012 is offline   Reply With Quote
Old 06-14-2016, 07:05 PM   #439
AJP330i
My Ride: Blue
Ok gents. Bumping this thread yet again! Sue me...
Installed the Behr fan. All is good until the fan spins up to high speed then it vibrates excessively enough to be felt in the cab. What gives?
"Carpe Diem, Seize the Carp"
AJP330i is offline   Reply With Quote
Old 06-14-2016, 09:37 PM   #440
fire730
My Ride: 01 325iT - 04 Burb
Sounds like it's out of balance.
I've seen some fans come with a little clip attached to one of the blades. Did you happen to remove that during installation by mistake?
01 325iT ZSP - Koni - Hotchkis - Stoptech
01 525iT - TiAg - Koni - B&G
04 Chevy Suburban - SLP - BlackBear - Belltech
01 330Ci - parts car
16 Chevy Tahoe - Wife's Daily
fire730 is offline   Reply With Quote
