Any High Mileage Bimmers Still Running Strong - Page 12 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 07-04-2010, 09:37 PM   #221
ryanbailor
My Ride: 2001 330 Ci
2001 Convertible 330ci, 210,000 miles, still smooth and strong. Original Motor and Trans. Changed Bushings, U-joints, suspension. Solid Car!
ryanbailor is offline   Reply With Quote
Old 07-04-2010, 09:43 PM   #222
MyE46I
My Ride: 330I
165k no mechanical problem what so ever, changed all belts/ fan blades / spark plugs / recently adjustable valve replaced. but yea great great car
MyE46I is offline   Reply With Quote
Old 07-04-2010, 09:49 PM   #223
323I00
My Ride: E46 323I
185 000 k not miles
323I00 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 07-04-2010, 11:37 PM   #224
whataboutbob
My Ride: 2002 325 xit...
128k normal preventative maintenance, 25mpg overall avg, cooling system, fuel pump, 1 window reg,
whataboutbob is offline   Reply With Quote
Old 07-05-2010, 12:01 AM   #225
afstud
My Ride: 2003 ZHP 6-speed
99 328 sport, 194k miles still running great, i had to do some tunning up to it but she is still smooth as silk at a complete stand still. just workin on minor things now.
afstud is offline   Reply With Quote
Old 07-05-2010, 04:25 AM   #226
QUEDRO
My Ride: 2001 325i ZSP
162K miles on my 325 and running great. But constantly maintaining and replacing here and there old parts. Too much money...:/
QUEDRO is offline   Reply With Quote
Old 07-05-2010, 05:08 AM   #227
loginfailed
My Ride: My buddies 350hp
Bought at 129k miles. Still runs strong. Currently at 140k miles.
Replaced:
  • Valve cover gasket (was leaking onto header causing burning oil smell)
  • Spark plugs (did at same time with valve cover gasket)
  • Wheels (they were bent & vibrating)
  • Wiper cowl (seal against the glass was deteriorated)
  • Fuel pump filter (left me stranded at gas station lol)
  • Driver midrange speaker (trim ring cracked & it was falling into the door)
  • Driver kick panel/dead pedal (was cracked by previous owner)
  • Both front window regulators
Stuff it still needs:
  • Oil pan gasket (already have)
  • Oil filter housing gasket (already have)
  • Cooling system overhaul (just ordered everything Friday)
  • Tie rods
  • Control arms
  • Steering guibo
  • Trailing arm bushings
  • Final stage resistor goes a little haywire sometimes
I'm sure there's more. I knew was I was getting into. Its a $5,000 car what can one expect? It's an old car but it looks nearly perfect so I don't mind all the work.
loginfailed is offline   Reply With Quote
Old 07-05-2010, 10:52 AM   #228
slash_e34
My Ride: e34 e30 e46&e46 ZHP
bought my aunts 2000 323i everything works 198,400 and motor is running good.
OEM GPS maps is far far outdated (actually got me turned into a one way in Brooklyn NY)
Tackling a little steering play and I think I have it pegges to driver LCA and steering coupler guibo thing
Chattering OEM clutch
headlight lens need replacement or wetsanding
I have a brand new ZHP suspension waiting to be installed
and in desperate need for wheel upgrade
slash_e34 is offline   Reply With Quote
Old 07-05-2010, 02:18 PM   #229
dls.tech
My Ride: 323i Wagon, mk3 VR6
I don't have high mileage but I have a ton of problems. I'm at 103k
-Reverse went out on auto transmission at about 70k
-Replaced 3 window regulators
-Radiator blew at 95k
-New thermostat
-Radiator hose just blew last night
-Control arm bushings were completely blown at 100k
-Transmission problems are starting. Doesn't want to drive in Drive sometimes.
There's more but I just can't remember. This is my first and last automatic BMW. I hate myself every day for not getting a manual.
dls.tech is offline   Reply With Quote
Old 07-05-2010, 08:29 PM   #230
tjwomer
My Ride: 2000 323i
Just rolled over 210,000 in my 323i. Did the worst DIY this weekend, had to change the starter. Beyond that I have replaced the following:
Alternator
Cam Sensor
Idler Pulleys
Thermastat
and the normal wear and tear items.
Can't complain, it has been a great car.
tjwomer is offline   Reply With Quote
Old 07-05-2010, 08:39 PM   #231
HighPod
My Ride: '00 white 323ci
165,000 miles and replaced:
radiator w/ hoses, expansion tank, thermostats
water pump replaced with stewart high flow pump and metal pulley
sway endlinks and control arm bushings
ccv system
fuel filter
belts and plugs
HighPod is offline   Reply With Quote
Old 07-05-2010, 11:37 PM   #232
iclimb513
My Ride: has 1 diff too many
-New thermostat
Everything you listed is absolutely normal and expected to be needed on a 100k car. The tranny is the only thing on the list that's at all serious.
iclimb513 is offline   Reply With Quote
Old 08-12-2010, 12:38 AM   #233
stapler12345
My Ride: E46, F30 2015 335xi
got mine at 77k, now at 115k
just gonna type out the maintenance
- passenger side rear window regulator
- both FCABs (Powerflex), both RCAB links
- 2 sets of Pzero Neros
- driver side control arm
- microfilter
- oil changes every half year (approx 7.5k miles)
- fuel filter
- spark plugs
- Zerex coolant
- 1 HID bulb
* just bought all the parts (except Stewart Water Pump) for an entire overhaul of the cooling system and 2 pulleys, 2 belts to be installed this upcoming 2 weeks. also, intake CPS.
* need some Cool Carbon brake pads around December
I've never heard of a woman wanting more than she actually deserved. Never.
stapler12345 is offline   Reply With Quote
Old 08-12-2010, 01:45 AM   #234
mpollard
My Ride: 323i
164,000 miles......had an oil service today....no leaks
will need a new set of tires this winter if it rains
Waiting for BMW to start building the E46 again...Makes sense to me that they would bring it back.
mpollard is offline   Reply With Quote
Old 08-12-2010, 03:23 AM   #235
e46vert
My Ride: 330ci
Are u the first owner? and have you had to replace your top?
e46vert is offline   Reply With Quote
Old 08-12-2010, 10:04 AM   #236
Lusticles
My Ride: 325Ci
98.4k
Haven't had it that long.
So far I have things I know need replacing:
Rotors
Washer Fluid Pump
All 4 Tires
Other than that I'm not sure what I should do; it's an '02 325Ci.
Lusticles is offline   Reply With Quote
Old 08-12-2010, 10:08 AM   #237
spencers
My Ride: 2006 330i
199,880
Still running strong. Third owner.
Doing VANOS seals to restore lost power whenever the weather cools down.
spencers is offline   Reply With Quote
Old 08-12-2010, 12:01 PM   #238
Zchild
My Ride: 2000 BMW 3XXi ZSP
Only owner 2000 E46 323i 318,290 as of this morning and still running strong! Just my two and a half cents worth...
V/R Zachary Pullins Sr.
National Capital Chapter BMWCCA
NCC Member Recognition Chairman
NCC High Performance Driving School Back-Up Registrar
NCC Auto-X BOD Liaison
DIY Senior Committee Coordinator
2006 E90 325Xi & 2000 E46 3XXi
" Vision without resources is just hallucination"
Zchild is offline   Reply With Quote
Old 08-12-2010, 11:27 PM   #239
san_siro
My Ride: 323i, E93
Originally Posted by san_siro View Post
110k on my 00 323i. Replaced only the following for preventive maintenance:
* Belts
* Thermostat
* Radiator pressure checked for leaks and coolant flush
* camshaft position sensors (intake & exhaust)
* rear window regulator, driver side
* Oil changed every 5 - 7k
Have 130k miles now and also changed:
* Spark plugs
* Idle Control Valve
* Valve Cover Gasket
* Fuel filter
* Rear wheel bearing, passenger side
* Coolant Expansion Tank
* ATF fluid
* All Rotors
* All Shocks
* Control Arms
* Tie Rods
* Differential fluid
* Steering Coupling/Guibo
* Pre-Cat o2 sensors
san_siro is offline   Reply With Quote
Old 08-13-2010, 01:23 AM   #240
the_curry_man
My Ride: 2001 330i 5spd ZSP!!
JUST HIT 100K TODAY!!! getting clutch replaced but other wise its a good, solid car....
Ebay Headers
Dinan Cold air intake
Orion V2 angel eyes
18' tsw rims
clears all around
weighted shift knob
CSL Front bumper
Red sharpie mod
Strut Bar
M3 lip spoiler
UUC Stage 2 Lightweight Aluminum Flywheel
UUC Performance Organic Clutch
Magnaflow Muffler
the_curry_man is offline   Reply With Quote
