Replacement O-rings on Upper/Lower/Expansion Tank(s) O-ring only - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 106 votes, 5.00 average. Display Modes
Old 03-03-2013, 10:38 AM   #21
BM-MAN
My Ride: Hot 3 coupe
Send a message via MSN to BM-MAN
Great Thread OP! I've been dealing with a coolant leak for months due to deformed 2" oring in expansion tank, finally bought a new tank last week. Only wish I found this thread sooner. Oh well.. bookmarked.
BM-MAN is offline   Reply With Quote
Old 09-20-2013, 07:41 PM   #22
djbradle
My Ride: 2002 325 xit
Sorry for the resurrection
http://www.harborfreight.com/205-pie...kit-67644.html
So it would be awesome if someone could get a digital ID of the Air temp sensor o-ring. I have a package of these I bought awhile back and would like to replace the o-ring with one from this set but I don't really want to do a whole drain to find out the size or while coolant is pouring out through the temp sensor hole.
djbradle is offline   Reply With Quote
Old 12-17-2013, 10:27 PM   #23
slowroller88
My Ride: 330I
Send a message via Yahoo to slowroller88
Many thanks
Just wanted to thank all the posters for the information shared. I too had a progressive leak for about a month till it finally got too bad to continue driving. I replaced the bleed plug, cap, hose from water pipe on the side of the block to the expansion tank, o-rings for the trans cooler, and the water pipe assembly under the E.T. Still had a leak, then I read this post. Replaced both o-rings in the bottom of the E.T., and now no leak. Had I read this post earlier, could have saved some $$. I went down to my local Oreilly's and matched as best I could from their o-ring box, but will order the proper sizes and replace again, just to be safe.
Thanks again for the great post. ( I was about to order a new radiator...till I saw this thread!!)
slowroller88 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 12-27-2013, 07:14 PM   #24
swordsman11868
My Ride: 2003 325i
Transmission: Autotragic
I've read this entire thread and didn't see the O-ring size for the E.T. cap (2 o-rings).
Did I just miss it or does anyone have the size?
I'm pretty sure mine are getting flat and allowing coolant to escape after I shut the engine off.
Edit: I measured each o-ring and got the following: 1.16" o.d. bottom. 1.20" o.d. top.
No idea what the inside diameter would be.
I'm just here to change the world.
BMW Wiki:
Are you getting hot air no matter where you set your A/C in your E46? Check out this ancient thread! Chime in with your experience:
swordsman11868 is offline   Reply With Quote
Old 04-14-2014, 12:21 AM   #25
Guam135i
My Ride: 2008 BMW 135i
What a great resource, thanks
Guam135i is offline   Reply With Quote
Old 06-14-2014, 08:42 AM   #26
e46dub
My Ride: 2000 328i
where can you find these? I tried Granger but couldn't seem to find any on the website with those specs
EDIT: CRAP i bumped old thread. apologies
e46dub is offline   Reply With Quote
Old 11-03-2014, 01:06 PM   #27
Stephen46ci
My Ride: 318Ci sport 2004
Could anyone give me a link for the Two ET o-Rings? I have a 318 will they fit the same? I also live in the UK so US website isnt any good
Stephen46ci is offline   Reply With Quote
Old 11-17-2014, 02:59 PM   #28
Guest021715
Account closed.
Bump.
Ordered the McMaster Carr O-rings. Will update if it resolves my coolant leak.
Old 11-17-2014, 08:28 PM   #29
Guest021715
Account closed.
Never mind, they won't ship my order to Canada.. Bastards..
Old 12-07-2014, 10:23 PM   #30
Stephen46ci
I ended up going to a local engineering firm and getting them custom made! Turns out it was the ET cap...
Old 12-22-2014, 02:27 AM   #31
mikeetastic
My Ride: lots of 3
bump.. does my local autoparts carry them (oreilly's autozone etc)? i just need the upper and lower o-ring since ill be changing my thermostat.
mikeetastic is offline   Reply With Quote
Old 03-03-2015, 07:21 PM   #32
genuity
My Ride: 2001 330iS
Thumbs Up
Bumpity! Bump! Thanks to the OP and all the contributors. I wanted to replace my thermostat as preventative after 50k and wondered about how good the existing o-rings would hold up. So glad I came across this!
genuity is offline   Reply With Quote
Old 12-05-2015, 06:48 PM   #33
Chocolate Lab
My Ride: 2000 328i black 5-sp
Another bump... Replaced my radiator a couple months ago and no leaks at all from the radiator itself, but after a couple of weeks I got a small leak from the upper radiator hose so I replaced it with a new one. But now I have a much bigger leak from the heater hose (#5 in the realoem diagram) where it connects to the ET. That looks like a much tougher hose to replace, so I'd rather just get the o-ring. Besides, I might have to get an o-ring just to drive it to where I can replace the whole hose.
But I'm confused about one thing. Sellsellsell posted the links to bmp's 1.125" o-rings, and sdstevep posted 22mmx3. Those are different, so are these for different locations or something? I notice that the 22x3 is in one of those Harbor Freight kits. Has anyone tried that? Or for that matter, the 1.125" ones?
Also, this is OT to the thread, but wondering how hard that one hose is to replace. I searched but didn't find more than a few posts on those heater hoses.
Chocolate Lab is offline   Reply With Quote
Old 12-07-2015, 03:24 AM   #34
e4603
My Ride: #3 bus
Originally Posted by Chocolate Lab View Post
Sellsellsell posted the links to bmp's 1.125" o-rings, and sdstevep posted 22mmx3..
During my last coolant system refresh, I ordered 3 from bmpdesign as I wasn't sure the exact size neither:
Coolant Hose O-ring for 1.125" Fitting (115246)
Coolant Hose O-ring for 1.5" Fitting (115242)
Coolant Hose O-ring for 1" Fitting (115240)
Noticed the 1.125" refers to the hose fitting size, not the o-ring size.
All I can say is one of them fits.
e4603 is offline   Reply With Quote
Old 12-07-2015, 10:16 AM   #35
spoedvraat
My Ride: BMW 330i auto 2002
Thank you very much for the trouble you went to. This will save a lot of souls.
spoedvraat is offline   Reply With Quote
Old 01-19-2016, 01:50 AM   #36
rustysrustyduc
My Ride: alot of BMWs..
Has anyone ever replaced the O-ring between the radiator and the expansion tank mount?
rustysrustyduc is offline   Reply With Quote
Old 01-19-2016, 07:26 PM   #37
NoVaDreier
My Ride: 2001 325i
Yes. I replaced the O-ring (17111711987, 14.5mm x 2.5mm) between the radiator and connecting plate when I replaced the expansion tank / connecting plate assembly along with two more of the same O-rings that seal the automatic transmission cooler to the connecting plate.
NoVaDreier is offline   Reply With Quote
Old 02-06-2016, 01:55 PM   #38
swordsman11868
My Ride: 2003 325i
The ORing store.
theoringstore.com
BMW Wiki:
Old 02-10-2016, 01:54 PM   #39
venerated
My Ride: F22 M235i
Bumping this thread instead of starting a new one. I completely replaced my cooling system and I have a leak where the ET attaches to the ET bracket at the bottom where the thermostat sits inside. Could it be possible that I didn't get an O ring in that area and just didn't realize it? Has anyone else had the same issue? I replaced with all OEM parts. I have to take it apart anyway so I'm gonna order the O ring and see but just wanted to hear other's experience? I'll report back with my findings as well.
2003 325xi Sedan Jet Black/Natural Brown Leather
1989 325i Vert Bronzitbeige Metallic/Natural
2014 M235i Coupe Estoril Blue/Black
venerated is offline   Reply With Quote
Old 02-15-2016, 02:58 AM   #40
swordsman11868
My Ride: 2003 325i
How bad is the leak? I would think if there were no o-ring in there it would be just pouring out.
I have a "cold/hot" leak from there. In other words - overnight when the car cools off - a tiny amount of coolant drips out - enough to leave a trail but not enough to need any added.
BMW Wiki:
