Too much power and torque? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 05-17-2018, 08:53 PM   #1
cwarel
My Ride: 330ci coupe
So ive replaced 3 center support bearings and 3 guibo for the past 2 weeks , after I tuned the car at 10 psi and it makes 400whp ( still got 14 psi left ) also 93 octane fuel.
Anyways i got a 5 speed manual 330ci with poly bushing all around and a welded diff( which is leaving its home asap) since im driving the car on a daily basis now.
The problem I have everytime I race the car driveshaft support bearing and guibo go bad which sounds like something isnt lined up , but I checked everything and everything was ok , except for the 2 things that go bad. The center support bearing has an aluminum housing and the 2 tabs that bolt to the chasiss keep on ripping out , this time airbag in the car went off ( steering wheel) and battery isolator charge also went while i was on the highway.
Is there a reinforced version of center support bearing , like instead of aluminum I need steel , otherwise I would have to reinforce it myself somehow , because i think that could be the major culprit.
cwarel is offline   Reply With Quote
Old 05-17-2018, 09:02 PM   #2
armenh7
My Ride: 2002 325i
Pole position (@seemslegitgarage on Instagram) seems to be running fine with quite a bit of HP and torque
Not so complicated install of BMW Tools (Windows XP, 7, and 10)
PA Soft
Driver:
Program:
armenh7 is offline   Reply With Quote
Old 05-17-2018, 09:11 PM   #3
cwarel
Well if thats the case I guess I gotta look into the geometry
Sponsored Links
Advertisement
Old 05-17-2018, 09:13 PM   #4
armenh7
My Ride: 2002 325i
https://www.instagram.com/p/BhoonzYgzD_/
510 HP and 550 TQ
PA Soft
Driver:
Program:
