Backfire / exhaust pop tune /FLAMES? - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 10-16-2016, 12:34 AM   #21
guywithe46
I have 1 resenator delete no muffler how can make flames?
guywithe46 is offline   Reply With Quote
Old 10-16-2016, 03:00 AM   #22
rb01
My Ride: 323i 98 208HP->Turbo
Double post
rb01 is offline   Reply With Quote
Old 10-16-2016, 03:02 AM   #23
rb01
Originally Posted by Kozak_Traxx View Post
dude would you please share your values so we can add it to the wiki
Here you go
Sponsored Links
Advertisement
Old 02-04-2017, 07:13 AM   #24
vanoshead
My Ride: e46
Can you get better shot with he injectors values
Sent from my Nexus 6P using E46Fanatics mobile app
vanoshead is offline   Reply With Quote
Old 02-04-2017, 08:09 AM   #25
rb01
U can, add fuel in lower rpm's
Old 02-08-2017, 05:02 PM   #26
rb01
Did some flames on friends 325ti
Sent from my SM-G930F using E46Fanatics mobile app
Old 02-08-2017, 05:21 PM   #27
vanoshead
My Ride: e46
Awesome
Old 02-08-2017, 06:48 PM   #28
SK330ci
My Ride: 02 330ci w/ 3 Pedals
lol, that won't attract any police intervention.
Mods: Header, CAI, Shark, Koni Sport Struts, Rob43 9 Way Shocks, Big Sway Bar, Rob43 Lowering Springs, 3.38 Diff, PFC Z-Pads, 75 Shot Of N20
E46 M3's are just tasty snacks i eat for lunch.
SK330ci is offline   Reply With Quote
Old 02-09-2017, 12:37 AM   #29
asianisafish
My Ride: 330ci
am i out of luck for ms45.....
asianisafish is offline   Reply With Quote
Old 02-09-2017, 03:42 AM   #30
sda2
My Ride: BMW E46 330i Touring
rb01, what values are you using?
sda2 is offline   Reply With Quote
Old 02-09-2017, 03:48 AM   #31
rb01
Old 06-30-2017, 10:46 PM   #32
armenh7
My Ride: 2002 325i
For the exhaust pop mod, if I only modify:
Engine speed hysteresis overrun cut-off
ip_t_puc_deacc_n_maf_mmv
Ignition retard, negative throttle
Ignition retard, fast negative throttle
Will my exhaust only pop when in Park/Neutral? Thanks!
Not so complicated install of BMW Tools (Windows XP, 7, and 10)
PA Soft
Driver:
Program:
armenh7 is offline   Reply With Quote
Old 07-01-2017, 09:47 AM   #33
daniel_f.
My Ride: 330iC
Test and report back.
No further development on MS4x from me.
Old 07-01-2017, 10:41 AM   #34
armenh7
My Ride: 2002 325i
Daniel I have another question for you. First, can this mod cause any serious damage?
Also, I bought a spare DME, so if I flash the virgin file and then update the DME with winkfp, will the DME be fine?
Old 07-01-2017, 05:45 PM   #35
daniel_f.
My Ride: 330iC
Everything not stock may damage your engine! Dme should be fine. Update with winkfp will result in MS430066!
Old 07-01-2017, 05:47 PM   #36
armenh7
My Ride: 2002 325i
I know. I prefer MS430066 because of the way the throttle is set up. I can always use the chipster MS43 checksum correction tool. But I still have the question, will flashing the virgin file then updating cause any issues?
Old 07-02-2017, 08:23 AM   #37
cwarel
My Ride: 330ci coupe
If you still have cats , you will damage them 100% , as when I had exhaust pop with stock headers (usa) they would start gloving red hot )))
cwarel is offline   Reply With Quote
Old 07-02-2017, 12:32 PM   #38
armenh7
My Ride: 2002 325i
After a short amount of time? Maybe I just do it once?
Old 07-02-2017, 02:52 PM   #39
daniel_f.
My Ride: 330iC
Depends on the setting. If you use ignition cut your cats will be shot in a few seconds. If you use fuel cut, it should handle it quite well.
Old 07-02-2017, 02:56 PM   #40
armenh7
My Ride: 2002 325i
Is the tune on the wiki ignition cut or fuel cut?
