ISAless Help - Page 3 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 07-07-2016, 02:17 PM   #41
sbrach
My Ride: E46 and E53
I will test this out for sure this weekend. If I can do anything specifically to help please let me know.
-Steven
sbrach is offline   Reply With Quote
Old 07-07-2016, 02:20 PM   #42
daniel_f.
My Ride: 330iC
Im pretty shure we fixed it
Engine fires up like with ISA, engine backfires like crazy with the overrun fuelcut changes from erom and transition between the engine states is absolutely smooth. There was no real need for BMW to use the ISA...
No further development on MS4x from me.
Old 07-07-2016, 04:18 PM   #43
sbrach
Well eliminating the ISA also eliminates the turbulence intake system so I'm sure there will be some small drawback with regards to emissions.
-Steven
Sponsored Links
Advertisement
Old 07-07-2016, 09:57 PM   #44
cwarel
My Ride: 330ci coupe
Originally Posted by Lakemountain View Post
I modified your file with the ISALess changes from the wiki.
http://speedy.sh/xcyxc/330-tuned-ISALess.bin
This should hopefully make your car driveable.
There is also more testing still being done on ISALess so more changes could appear on MS43Wiki in the near future.
Ok , I got the file , and read this page again and there was more stuff posted on wiki about isaless , so i got those settings dialed in which is pedal angle at the start , the car runs nice and smooth , no more stalling out at light or donkey kicking , so far so good
tnx for the help appreaciated
cwarel is offline   Reply With Quote
Old 07-08-2016, 03:11 AM   #45
LKMT
My Ride: N/A
Good to hear I take from what you wrote that you didn't modify Throttle angle based on driver wish with the new changes?
The Y-axis is rescaled and the values have been modified to keep the throttle open under engine braking.
With the original Throttle angle based on driver wish values I gave you the throttle will be closed when engine braking meaning that you will be pulling a lot of vacuum.
So don't go crazy with engine braking if you are using the old values.
There is a small issue with high idle in some situations with the latest values so we will be doing more testing today.
LKMT is offline   Reply With Quote
Old 07-08-2016, 08:47 AM   #46
cwarel
i dont do engine braking , i shift it in neutral and roll )))
Old 07-08-2016, 09:19 AM   #47
cwarel
oh btw , there is a volvo that has a hose also 3 inch literary same size as bmw lower boot , only it doesnt have the isa connection , so thats what im using right now and its perfect
Old 07-08-2016, 09:35 AM   #48
LKMT
My Ride: N/A
Do you now the year and model of the Volvo? I have access to Volvos VADIS program so I should be able to find the part number for it.
Old 07-08-2016, 01:59 PM   #49
cwarel
Try checking 2000 v40 and 2003 v70 hose came off one of those cars abdnim pretty sure the hosr has a number on it so ill get it
Old 07-08-2016, 03:05 PM   #50
sbrach
What engine did the the Volvo have.
-Steven
Old 07-08-2016, 03:14 PM   #51
cwarel
1.9 turbo 4 cyl for v40 and v70 is a 5cyl turbo 2.5l
Old 07-08-2016, 07:00 PM   #52
LKMT
My Ride: N/A
I assume it's the detachable part of the intake hose between the airfilter and turbo (on the right in the picture)
Can be found in all s40/v40 with a turbo engine (2.0t and T4) between 1998 to 2004 the part number for the whole thing is 30620869.
But I'm having no luck finding a similar part on a 2003 V70 2.5t the pipe between the airbox and turbo is plastic on those.
Old 07-08-2016, 08:55 PM   #53
cwarel
Ill verify the part tmr cuz its dark in nyc and cant really see what im doing ill take it off tmr
Old 07-09-2016, 01:00 PM   #54
sbrach
Sorry if this is a stupid question but how do you re-scale the Y axis?
Edit: I think I figured it out, edit ldpm_pvs_3, correct?
-Steven
Old 07-09-2016, 01:20 PM   #55
cwarel
I used romraider u could do it there)))
Old 07-09-2016, 02:40 PM   #56
sbrach
Ahh I see. I was using TunerPro because all the necessary tables aren't in the RomRaider def.
-Steven
Old 07-09-2016, 03:52 PM   #57
sbrach
Just tested this. Getting a good idle until I touch the throttle. Once I do it starts hunting between 1000-2000rpm. My tune has increased idle speed targets so I am going to try putting those back to stock to see what it does.
-Steven
Old 07-09-2016, 04:43 PM   #58
sbrach
No difference. Perfect idle until I touch the throttle and then it won't stop hunting until I shut it off.
-Steven
Old 07-09-2016, 07:18 PM   #59
cwarel
Idk guys lemme give u my file once i get home cuz mine works fine
Old 07-09-2016, 09:17 PM   #60
sbrach
Has anyone tested if the 2 DTC suppression parameters and the two map changes that are documented in the wiki work on an otherwise stock tune?
-Steven
