ISAless Help - Page 12 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 08-23-2017, 06:31 PM   #221
LKMT
My Ride: N/A
Originally Posted by Kopfspringer View Post
I get "Motornotprogramm" and Error shwon in the Picture. Sometimes there is another Error too, sayin something from ECU Error...
I had a look at your file and checksum4 was incorrect so that is probably what's causing the error.
I have disabled checksum4 in your file and applied the wiki changes to ip_tqi_maf__n__maf.
As the values in the wiki are made for a M54B30 you may need to modify ip_pvs_isa_isapwm__isapwm to get a stable idle.
This table dictates how much pvs input should be added for a given isa duty cycle. So if your idle is low try increasing this table.
LKMT is offline   Reply With Quote
Old 08-23-2017, 06:43 PM   #222
LKMT
My Ride: N/A
Originally Posted by Paul_13 View Post
Also probably a daft question but do we completely remove the ISA and unplug it?
Yes the ISA can be completely removed from the engine.
Old 08-24-2017, 08:08 AM   #223
Kopfspringer
My Ride: BMW e39 Supercharged
Year: 2001
Model: E39
Hey Guys!! THANK YOU!
I thought "correcting the Checksum" means using the Checksum Corrector...
Now is read all the former posts and understand what you meant by Checksum4...
I will test this evening. Hopefully it works.
By the way... yes i have completely removed the ICV and plugged the hole.
Thank you... i will report if everything is working well.
Best regards,
Michael
Kopfspringer is offline   Reply With Quote
Sponsored Links
Advertisement
Old 08-25-2017, 01:38 AM   #224
Kopfspringer
Year: 2001
Model: E39
Guys!
Incredible!!
Everything is working!! AND... i have automatic transmission... no Problem at all!
I tested everything yesterday evening, made some logging cruises. Just found out that i needed a little bit more injection over 850 Load and a little bit less ignition due to Knock 1 over 6000 U/min...
Now the Car is working good!!!
Thank you very much!!
Old 09-02-2017, 03:50 PM   #225
Paul_13
My Ride: E46 330i touring
When you say correct checksum4, what do you correct it to?
I corrected to the tune which has the ISA valve. Said 2 checksum errors were found, didn't mention chk5 or chk4
Checksum 4 is an addition checksum that the dme uses to verify that the _mon_ values in the calibration file are not corrupt.
The variables that the dme uses to calculate this checksum is located in the program section so tools like Ultimo Checksum Corrector can only correct this checksum in a 512KB file.
If you are using 430056 you can disable this checksum by setting lc_swi_cal_mon_cks to 165(0xA5).
Do you have to set this in the full 512kb file and flash in boot mode for it to work?
Edit: solved it. You have to set this in the 512kb file or it will not save the value and default back to 1
Paul_13 is offline   Reply With Quote
Old 09-03-2017, 07:03 AM   #226
LKMT
My Ride: N/A
Hmm this does not sound right to me, you only need the 64kB file to disable chk4 with lc_swi_cal_mon_cks. The 512kB file is only needed if you want to actually correct the checksum.
To me it sounds like your Tunerpro installation had some problem when saving the 64kB and that's why it reverted back to 1.
Old 10-24-2017, 07:30 AM   #227
danius375
My Ride: BMW 330ci (E46)
Did anyone manage to get their B22 running right without ISA? What are your ip_tqi_maf__n__maf and ip_pvs_isa_isapwm__isapwm settings?
Me and my friend spent 2 days trying to get it to idle properly, and it still either hunts, or cuts out. If we try and raise the ip_pvs_isa_isapwm__isapwm setting, when the revs drop, they get stuck at about 1200rpm for a couple of seconds before dropping to a normal idle.
danius375 is offline   Reply With Quote
Old 10-24-2017, 07:30 AM   #228
danius375
Double reply...
Old 10-29-2017, 07:16 PM   #229
Blu302
My Ride: '98 E46 323i
Year: 98
Model: E46
Transmission: Manual
That is a factory thing with the drop. My B25 did that all the time, even after the ISA delete.
_______________________________________________
Power is knowledge, So share the knowledge!!
Blu302 is offline   Reply With Quote
Old 03-04-2018, 12:43 PM   #230
donBogi
My Ride: 325i
ISAless Help
Does anybody have some proper settings for the m54b25 Engine for ip_pvs_isa_isapwm_isapwm ?
Raised the tables and run‘s acceptable but i have some high idling when going reverse.
Edit: also have Idle bouncing when starting in cold state. Should probably lower the settings
Gesendet von iPhone mit Tapatalk
donBogi is offline   Reply With Quote
Old 07-11-2018, 05:49 AM   #231
sda2
My Ride: BMW E46 330i Touring
Okay I'm running on ISAless for quite some time now.
Yesterday I wanted to apply my burble setting, but the car just doesn't go into overrun without cutoff. Not even with PUC completly disabled in IP_N_MIN_PUC
Does someone have an idea why?
sda2 is offline   Reply With Quote
Old 07-11-2018, 07:02 AM   #232
daniel_f.
My Ride: 330iC
I'm using the timered version and works like a charm.
No further development on MS4x from me.
Old 07-30-2018, 03:50 AM   #233
Pov06
My Ride: 325
I deleted my ICV for the first time on my M54B25. It is running an M50 intake manifold and an M54B30 throttle body.
I used the values for the M54B30 from the Wiki and had to rescale the axes in some tables and the engine is idling perfectly. I didn't need to make any changes to ip_pvs_isa_isapwm__isapwm
Not sure if the stable idle is because of M54B30 throttle body or because I rescaled the table axes. Might help someone though!
Pov06 is offline   Reply With Quote
Old 01-02-2020, 01:33 PM   #234
gunner916
My Ride: 2001 330i
hope to accomplish this with my m50 intake swap to prep for boosting!
gunner916 is offline   Reply With Quote
