ISAless Help - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 07-02-2016, 02:13 PM   #1
cwarel
My Ride: 330ci coupe
ISAless Help
So I followed the instructions on ms43wiki on how to remove isa.
1) So i took ISA unit out completely and there was a hole size about 3/4 inch))
2) Went to home depot and bought a thing that you should put on the leg of ur chair so it doesnt scratch the floor , it has a cone shape and its thick rubber so it fits in the whole perfectly blocking all the air.
3) ECU parameters changes , moment where i spend 3 hours doing it , cuz 3 times tunerpro closed on me without saving the progress so i had to do it over))
So here is my big question there is 2 lines that i cannot find which are
dummy_w_1: 800
c_dyw_cycnr_is: 150
I check abbreaviations and still couldnt find them anywheres
So the car runs without them , but it stalling out sometimes ,and linear throttle works the best with ISA delete , well i think so)
I can upload my file if you want to check it just lemme know
cwarel is offline   Reply With Quote
Old 07-02-2016, 02:17 PM   #2
daniel_f.
My Ride: 330iC
Dummy_w is not necessary to Change, i Need to Look up tue other one
No further development on MS4x from me.
Old 07-02-2016, 11:55 PM   #3
cwarel
So also I have a question how can i raise rpm and make it more stable? ( i live in new york and its hot)
Sponsored Links
Advertisement
Old 07-03-2016, 01:56 AM   #4
daniel_f.
My Ride: 330iC
Unfortunally it wonŽt recognize higher idlespeed Targets (right now!), so the easiest work around is to raise idlespeed Targets and open the throttle just a bit more.
It should automatically adjust the throttle to whatever is needed, however it currently doesnŽt do it, so its still experimental.
Old 07-03-2016, 01:09 PM   #5
cwarel
alright sounds simple enough , how do i do it ?)
Old 07-03-2016, 01:49 PM   #6
daniel_f.
My Ride: 330iC
Modify the corresponding maps?
Old 07-03-2016, 02:09 PM   #7
cwarel
alright ill look into that later on today
Old 07-04-2016, 07:02 AM   #8
daniel_f.
My Ride: 330iC
Stay tuned for an amazing update
Seems like a fellow MS43 artisan found the trick
Old 07-04-2016, 09:35 AM   #9
sda2
My Ride: BMW E46 330i Touring
Very curious for that as well! Any idea of how long it takes?
Is there some kind of public information on what the dev team does at the moment?
sda2 is offline   Reply With Quote
Old 07-04-2016, 09:40 AM   #10
daniel_f.
My Ride: 330iC
WeŽre being lazy right now Its been on test for two days so far and right now throttle, ignition and fueling is used to set idlespeed. I havenŽt heard back if the idlespeed setpoints are working like expected, so its probably another few days until its getting published.
Next topic is most probably clean alpha/n, but i wanna rewrite some of the code before that gets published.
Next next topic is most probably variable Launch with bang and NoLiftShift, weŽll see.
Old 07-04-2016, 09:46 AM   #11
Blu302
My Ride: '98 E46 323i
Year: 98
Model: E46
Transmission: Manual
Talk to diablorojo. About the Isa removal, he has just gone through it. I helped him with high rpm at idle and reducing the hunt.
The idle aim numbers etc still work as normal and the hunt is removed by changing the vanos, ignition and icv starting position.
_______________________________________________
Power is knowledge, So share the knowledge!!
Blu302 is offline   Reply With Quote
Old 07-04-2016, 09:56 AM   #12
daniel_f.
My Ride: 330iC
Send me a PM on this please.
Old 07-04-2016, 10:29 AM   #13
sda2
Thanks Daniel!
What about PUC? I heard it doesnt really shut down the injectors.
Old 07-04-2016, 10:34 AM   #14
daniel_f.
My Ride: 330iC
Sorted
Old 07-04-2016, 10:53 AM   #15
sda2
That's very very nice to hear! Can't wait to get my car back and throw this thing out!
Old 07-04-2016, 01:34 PM   #16
daniel_f.
My Ride: 330iC
Idlespeed setpoint works
So its official: ISAless is now finally possible and works perfectly. No hunting, no hassle.
Thanks to Tobias S. for figuring it out
Old 07-04-2016, 02:19 PM   #17
sda2
Thanks for the solution Tobias!
Is it really "only" changing these four parameters?
c_abc_inc_isa_1: 0
c_abc_inc_isa_2: 0
[edit]
Old 07-04-2016, 02:22 PM   #18
daniel_f.
My Ride: 330iC
Is it really "only" changing these two parameters?
c_abc_inc_isa_1: 0
c_abc_inc_isa_2: 0
(edit)
Had another chat with Tobias and i really start to wonder about myself... I canŽt count the hours i spent disassembling and comparing dozen of subs in IDA and at the end of the day, its just supressing the DTCs... Really makes me wonder if automotive engineers tend to overcomplicate things...
IŽll quit work earlier tomorrow to give it a test!
Old 07-04-2016, 02:26 PM   #19
sda2
Better throttle reaction? Can we now make the throttle linear?
Old 07-04-2016, 02:31 PM   #20
daniel_f.
My Ride: 330iC
I haveŽt tested it, so canŽt comment on the throttle reaction. Second part should be doable now
