Persistent P0369 code - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 08-17-2013, 08:22 PM   #1
kmnwa
My Ride: 2001 BMW330 Ci
I recently purchased a 2001 BMW 330CI. The car looks great but the check engine light was on. Pulled the codes & had 1 for exhaust camshaft position sensor, 1 for the intake camshaft position sensor, and 4 codes for the O2 sensors. I replaced both camshaft position sensors with parts from O'reilly Auto Parts then cleared the codes but the exhaust camshaft code & the O2 codes came back as soon as I restarted the engine. I bought an OEM exhaust camshaft position sensor from BMW dealer & replaced the aftermarket camshaft position sensor then cleared the codes but they came back again. Next I rebuilt the VANOS with parts from Beisan then cleared the codes again but they come back again after I restart the engine. The seals in the VANOS were stiff before I replaced them & the engine definitely runs stronger since I rebuilt the VANOS but there is a noticeable lope in the idle when the check engine light reappears. Now I'm stumped on what to do to get rid of the P0369 code for the exhaust camshaft position sensor. I feel like the O2 sensor codes will probably clear once the camshaft position code clears. Anyone have any ideas on what to try next? I appreciate any suggestions you may have.
kmnwa is offline   Reply With Quote
Old 08-18-2013, 09:33 AM   #2
markusmarkus
My Ride: 2018 M240i
What brand/model of code reader did you use? Generic code readers typically provide erroneous or misleading codes. Invest, as a minimum, in a BMW specific code reader such as one from Peake.
Also, I recommend buying only OEM replacement sensors as sensors from parts stores like O'Riley are typically inferior (i.e., junk).
Old 08-18-2013, 11:02 AM   #3
kmnwa
Thanks for the reply, "markusmarkus". I started with the Oreilly camshaft position sensors then went to OEM after I read that aftermarket sensors were junk. Now I have OEM sensors and the intake camshaft position sensor trouble code went away, but the exhaust camshaft position sensor trouble code is still there. I read somewhere that the VANOS seals may need replacing on high mileage vehicles and could cause erroneous exhaust camshaft position sensor codes so I have replaced the VANOS seals also. Since I replaced the VANOS seals there is a noticeable improvement in performance but the P0369 code reappeared after clearing the code.
Sponsored Links
Advertisement
Old 09-14-2019, 10:44 AM   #4
tmoh
My Ride: 330i "E46"
I'm experiencing a similar persistent PO369 code I have already replaced both Ex CPS and Venos seals, engine runs fine but tends to struggle when accelerating and produces a louder exhaust sound than normal. I have checked signal voltage with multimeter while turning the engine with a wrench and it is fine.what more can I check
tmoh is offline   Reply With Quote
