DAILY E46 MOD/REPAIR UPDATES - What have you done? - Page 2170 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 2001 votes, 4.91 average. Display Modes
Old 02-10-2020, 10:38 PM   #43381
dothehundo
My Ride: 03 325Ci / 02 325iT
I need to find someone with one of those Quickjacks nearby so I can borrow it.
03 MT 325Ci coupe Rapid commuting device
02 MT 325iT wagon Grocery and stuff getter
97 NA Miata Toy | 83 R80 - 2 wheels!
dothehundo is offline   Reply With Quote
Old 02-11-2020, 06:32 AM   #43382
VpointVick
My Ride: '03 325iT Mysticblau
Originally Posted by dothehundo View Post
Pictured in the back, Dayton Audio PS65LP-4 6-1/2" Ultra Efficient Low Profile Full-Range Driver 4 Ohm
Not pictured but in the front, Infinity REF-6522EX Shallow-Mount 6-1/2 Inch Coaxial Car Speakers, because the ones above were too thicc for the front
I'm pretty pleased with them, though I've only taken 2 short trips so far.
No pictures at all.
VpointVick is offline   Reply With Quote
Old 02-11-2020, 10:57 AM   #43383
dothehundo
Originally Posted by VpointVick View Post
No pictures at all.
There is one pic, a couple posts back, unless I'm the only one seeing it somehow?
Sponsored Links
Advertisement
Old 02-11-2020, 11:13 AM   #43384
VpointVick
Ah, I hadn't realized that your post was responding to someone.
Old 02-16-2020, 12:37 PM   #43385
yjsaabman
My Ride: '03 325i Touring
Began stripping my "winter" (hasn't really been much of one so far) wheel project. Holy crap is the finish thick on these things! It also looks like there is a clear coat underneath the black finish. Made the mistake of starting in the basement while my wife was at her sister's yesterday. She was not a fan of the way it made the house smell! Lol!
Sent from my SM-G970U using Tapatalk
yjsaabman is offline   Reply With Quote
Old 02-16-2020, 01:40 PM   #43386
jmo69
My Ride: 03 325xi 98 328is
The factory wheel finish is extremely hard, I tried taking the finish down to the aluminum on the lip of my e36 wheels. I ended up sanding it off, my fingers were sore as hell when I was done. The strippers I used didn't touch the primer, even the Aircraft stripper didn't work.
Alternative to expensive xi control arm bushings
Bad outer xi ball joint?
2003 325xi auto Stahlgrau
1998 328is 5sp
jmo69 is offline   Reply With Quote
Old 02-16-2020, 05:12 PM   #43387
yjsaabman
Originally Posted by jmo69 View Post
Th factory wheel finish is extremely hard, I tried taking the finish down to the aluminum on the lip of my e36 wheels. I ended up sanding it off, my fingers were sore as hell when I was done. The strippers I used didn't touch the primer, even the Aircraft stripper didn't work.
I made sure I got the stripper that said paint and epoxy, and it is actually working. It's taking multiple applications, though.
Old 02-18-2020, 02:07 AM   #43388
kit2kay
Fuel lines
I'm having trouble figuring out what kind of fuel line this is and what it connects to on a 1999 BMW 323i with a M52TU engine
kit2kay is offline   Reply With Quote
Old 02-18-2020, 10:50 AM   #43389
LL i am
My Ride: 2001 325ci
check inlet fuel hose to rail. 13537548987
LL i am is offline   Reply With Quote
Old 02-18-2020, 12:34 PM   #43390
Archbid
My Ride: 330ci Convertible
Year: 03
Model: 330cic
Transmission: 5-Speed Manual
Pulled my actuator on the vert to fix the latch pin and it stopped working. New one arrives tomorrow.
Archbid is offline   Reply With Quote
Old 02-18-2020, 02:54 PM   #43391
turbotalon1g
My Ride: '02 330i
Installed new cloned DME thanks to Kassel Performance for that piece and Eurotech for the diagnosis.
turbotalon1g is offline   Reply With Quote
Old 02-18-2020, 07:59 PM   #43392
yjsaabman
I was thinking return line from the rail, since it is an earlier car.
Old 02-19-2020, 10:56 AM   #43393
alan53
My Ride: bmw E46 330ci
Year: 2004
Model: 3 series
Transmission: 6 speed
Send a message via Yahoo to alan53
My car passed its annual inspection (MOT)with a few advisories 330ci 217k miles.
alan53 is offline   Reply With Quote
Old 02-19-2020, 01:34 PM   #43394
jmo69
I wouldn't call an 03 an early car, my has the FP regulator built into the fuel filter.
1998 328is 5sp
Old 02-19-2020, 03:16 PM   #43395
yjsaabman
OP said 99 323i which did not have the fpr in the filter.
Old 02-19-2020, 08:09 PM   #43396
apseagle
My Ride: 02 325xi 5 speed
Just diagnosed a failing bearing on my alternator. It was a rebuilt Bosch unit installed at 188k, failed at 227k. For $36 I ordered a rebuild kit with new bearings, regulator/brushes, slip ring and bearing spacer. Should be in in a couple of days and I will get it out and rebuilt. I just did the one on my Mercedes with the same kit and it worked great.
apseagle is offline   Reply With Quote
Old 02-20-2020, 11:49 AM   #43397
BullCityBimmer
My Ride: 1998 323i
Itís an evap hose. Plugs into the back of the manifold. Zip tie it as it rarely stays in place for me
BullCityBimmer is offline   Reply With Quote
Old 02-20-2020, 04:07 PM   #43398
jmo69
My bad, looked at the wrong post.
1998 328is 5sp
Old 02-22-2020, 03:11 PM   #43399
stapler12345
My Ride: E46, F30 2015 335xi
@176,272
- added in Meyle HD Shock Absorber Mount
- swapped in Sachs Shock Absorber; Rear; OE Version
- new rear rotors (generic)
- new rear brakes (generic)
- added rear brake sensor
- added splash guard
- emissions testing
I've never heard of a woman wanting more than she actually deserved. Never.
stapler12345 is offline   Reply With Quote
Old 02-22-2020, 04:59 PM   #43400
Maxima98
Did the good ol OFHG, threw on some Toyo Extensa HP II, found some 17" Drag DR69 wheels for a damn good price. Looks ten times better. Also no more oil leak!
Maxima98 is offline   Reply With Quote
