Too cold to wrench in Minnesota, any heated garage options? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 01-17-2020, 01:45 PM   #1
PHDE46
My Ride: 2002 330ci vert
Year: 2002
Model: 330 CiC
Transmission: 5 speed manual
The CCV valve and associated tubes needed to be replaced on my 02 330Ci. My garage is not insulated or heated, so I ended up taking to my local indy shop. The wallet is about $1k lighter now.
I'm wondering if anyone has any leads on heated garage space available for rent, or ideally, available in exchange for the adult beverage of the owner's choice. My hut is in Roseville.
I'll hang up and take my answer off the air...
Model description: 330CI
VIN: EV88139
Market: USA
Type: BS53
E-Code: E46 (C)
Chassis: Cabriolet
Engine: M54 - 3,00l (170kW)
Drive: Heckantrieb
Transmission: manuell
Body Color: Titansilber Metallic (354)
Upholstery: Standardleder/hellbeige 2 (arbeitsn (N6HC)
Production date: 31.08.2001
Assembled in: Regensburg
PHDE46 is offline   Reply With Quote
Old 01-17-2020, 02:13 PM   #2
Effduration
My Ride: '05 330CiC
It's colder in St. Paul, But I use a Mr. Buddy (Big Mr Buddy ) heater with a propane tank in my unheated, un-insulated garage. Certainly takes the edge off.
Effduration is online now   Reply With Quote
Old 01-17-2020, 06:44 PM   #3
Wade Middleton
My Ride: 330Ci ZHP
Year: 2005
Model: ZHP Coupe
Transmission: 6 Speed Manual
Check to see if there are garages that rent time and tools out. It's kinda like having a full service garage rent their place by the hour.
Wade Middleton is offline   Reply With Quote
Sponsored Links
Advertisement
Old 01-18-2020, 06:11 AM   #4
Efthreeoh
Maybe you should think of heating your garage. It's not expensive and easy to do. I originally heated my shop with something called a Modine Hotdawg heater. They have several sizes, rated by BTU and hang from the ceiling rafters out of the way. A simple 4-inch exhaust, 120V electric circuit, and gas piping is all that is required for installation. The heater takes either propane or natural gas (it comes with both sets of jets). If you are handy and your county codes let you install your own gas plumbing, it's any easy DIY job. I ran mine off a 120 gallon propane tank and never ran out of fuel.
https://www.greenhousemegastore.com/...Dawg%20Heaters
Efthreeoh is offline   Reply With Quote
Old 01-18-2020, 10:27 AM   #5
JoshUpNorth
My Ride: 2001 BMW 325xi Touri
Year: 2001
Model: 325xiT
Transmission: 5-SPD Manual
I live up in the Duluth region and I can feel your pain. I don't have a heated garage and end up doing a lot of my work outside all bundled up. We've already gotten about 5 feet of snow this winter. Luckily my 325xiT hasn't had any problem starting even on the coldest days. Good luck on your search.
JoshUpNorth is offline   Reply With Quote
Old 01-18-2020, 10:37 AM   #6
wfx32
My Ride: AWD
Model: 330XI 08/2004
Transmission: auto
nice idea. those camping cylinders are tiny. i am going to try this with a regular 5 lb tank and conversion from the q grill.
wfx32 is offline   Reply With Quote
Old 01-18-2020, 10:44 AM   #7
wfx32
My Ride: AWD
Transmission: auto
better something like this mr heater with forced air?
https://www.amazon.com/dp/B00KRFVG5G/
Old 01-18-2020, 02:03 PM   #8
jmo69
My Ride: 03 325xi 98 328is
My son bought something similar to this along with a 100 lb LP tank to work in my all steel garage. The only insulation it had was some 1/2" foam board covering about 80% of the ceiling. got warm enough to work in Wisconsin winters. I moved it to my insulated garage and the other the day it took the temp from 25 to 45 in 20 minutes with it running on low, got up to 70 after another half hour or so. https://www.amazon.com/ProCom-PCC80V...%2C215&sr=1-51
Alternative to expensive xi control arm bushings
Bad outer xi ball joint?
jmo69 is offline   Reply With Quote
Old 01-18-2020, 02:13 PM   #9
Effduration
My Ride: '05 330CiC
That looks better than a Big Buddy heater...better fan to move things around.
Old 01-19-2020, 01:37 AM   #10
darkfires102
My Ride: 325xi, '07 E60 M5
Year: 2003
Transmission: 5spd Manual
Winter really sucks wrenching, you bundle up, and then you're stuck sweating in below freezing temps, feels uncomfortable for sure. Wearing gloves takes off a lot of the hurt
darkfires102 is offline   Reply With Quote
Old 01-19-2020, 05:59 AM   #11
Effduration
My Ride: '05 330CiC
You bet. I hate those little green gas tanks. I can't tell if they're empty...until its too late...I have the conversion hose that lets me use the 5 gal propane tank with my coleman tailgate grill.. I use that same hose with my Mr. Buddy heater and run it off a 5 gal tank.
Old 01-26-2020, 06:18 PM   #12
PHDE46
Year: 2002
Model: 330 CiC
Thanks, everyone. Insulating the garage is on the project list and moving up. I'll check around to find a garage rental option, too.
VIN: EV88139
Market: USA
Type: BS53
E-Code: E46 (C)
Chassis: Cabriolet
Drive: Heckantrieb
