Engine Mount - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 01-16-2020, 03:52 AM   #1
gagi
My Ride: E46 325i
Engine Mount
To replace engine mounts, do I need an engine support bar on the top to lift the engine? Would a floor jack pushing on the oil pan be enough?
gagi is offline   Reply With Quote
Old 01-16-2020, 04:22 AM   #2
Overboost
//Binary is in my DNA
Overboost's Avatar
My Ride: 2002 325i
I did mine with a floor jack and a block of wood on the oil pan. I followed the 50sKid video below.
  • To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
The older I get... The faster I was...
No Fear
Overboost is online now   Reply With Quote
Old 01-16-2020, 01:52 PM   #3
gagi
My Ride: E46 325i
What's the pain index with this project?
Sponsored Links
Advertisement
Old 01-16-2020, 04:07 PM   #4
Newbimer
My Ride: 2005 325i
Pretty easy but you will need a long extension bar/universal to reach the RS nut from the top. Easier if you remove the air pump.
Newbimer is offline   Reply With Quote
Old 01-16-2020, 04:29 PM   #5
mega_stihl
My Ride: E46 & E32
It's an easy enough job. You might have to remove some **** around it, but it's easy. Jack & wooden board will do the trick.
mega_stihl is offline   Reply With Quote
Old 01-16-2020, 08:41 PM   #6
cvx5832
My Ride: 535i, 325Ci, C300
Same. Did it with a jack and wooden block to spread the load.
cvx5832 is offline   Reply With Quote
Old 01-17-2020, 05:21 AM   #7
sefeing
My Ride: 2002 BMW 325i Sedan
Year: 2002
Model: 325i
Transmission: Automatic
Doing this as soon as it warms back up in NYC, but will probably pull the trigger on the harbor freight engine support bar.
That said, I'm more worried about tackling the trans mounts, which I SHOULD have done when I did the flex disc. Maybe even remove the exhaust / disc again to do it?
Anyone have a good tutorial (besides 50s kid's) for auto trans mounts?
sefeing is offline   Reply With Quote
Old 01-17-2020, 06:38 AM   #8
Overboost
Overboost's Avatar
My Ride: 2002 325i
I did mine at the same time I did the engine mounts. I even used 50sKid hack of using a 13mm wrench and a 1/2" ratchet to turn the wrench. That took all of 5 minutes to replace them with nothing else removed. Easy peazy.
No Fear
Old 01-17-2020, 07:19 AM   #9
sefeing
Year: 2002
Model: 325i
Great to hear this hack was easily repeatable - I'll give this a shot!
Old 01-17-2020, 09:18 AM   #10
smolck
My Ride: 2003 330ci (manual)
I have the harbor freight engine bar, so much easier. I accessed the passenger side mount's top nut from underneath, a flex head ratchet makes it easy. The drivers side you can also get to from the top by just reaching your hand down there and go after it. Again, a flex head ratchet is key. With the engine brace it is super easy and takes 45 minutes tops. Use the vertical hooks that come with the kit to go through the loop right above the tstat. Once the lower nuts are loose, just give a few twists on the hook to raise the engine some, the mounts slide right out.
I HIGHLY recommend Corteco M3 engine mounts. Just installed them on my 330ci and they are nice Oem+ option. Bought mine from FCP, lifetime warranty abounds!
Check out my BMW Blog
Check my Youtube channel for DIY's and fun stuff
smolck is offline   Reply With Quote
Old 01-17-2020, 10:18 AM   #11
gagi
My Ride: E46 325i
I am expecting new mounts from FCP next Wednesday. Looking at the dramas on YouTube, I think people got into clearance trouble because they tried to change both sides at the same time. Shouldn't be an issue if done one side at a time. I guess I will find out.
Now, I am debating if I need to get the engine bar from Harbor Freight.
The job that I am really dreading is the oil pan gasket. I never liked working under the car anyway.
Old 01-17-2020, 11:37 AM   #12
sefeing
Year: 2002
Model: 325i
Rad! Did you have any issues with clearance that required you to do what 50's kid did and lever the engine to one side? Or is it super super straight forward with the support bar?
Old 01-17-2020, 11:50 AM   #13
smolck
Super straight forward with the engine bar. A buddy just updated a thread on bimmerfest on his revshift mounts. Check the pic here (https://www.bimmerfest.com/forums/sh...d.php?t=962475) and you will see me under the car and my support bar on top. I did one at a time, though both are easily removed at the same time with the support bar and no "levering' needed on the ZHP in the pic or my car a few weeks ago with regular sized M3 mounts (because the bar will lift the engine uniformly and give you plenty of room). For $80 or less, it is cheap insurance that the engine wont fall off a jack or that you damage your oil pan.
I just did my oil pan gasket and new mounts on my car, wouldnt even attempt to lower the front subframe for that work without the bar. Well worth the $$ IMO.
Yea, you need it. $80 or less with their "super coupon" and well worth the piece of mind and all the extra room under the car without a jack in your way.
Old 01-17-2020, 12:09 PM   #14
Brewtus79
My Ride: M3 Vert, 330xi, X5
Year: 2002
Model: M3, 330xi, F15 X5
Transmission: 6 spd manuals
Yea, you need it. $80 or less with their "super coupon" and well worth the piece of mind and all the extra room under the car without a jack in your way.[/QUOTE]
that alone makes it worth the $80.
Sent from my SM-G950U using Tapatalk
Brewtus79 is offline   Reply With Quote
Old 01-17-2020, 12:20 PM   #15
curry
My Ride: 2002 330Ci
I did this job following the 50s Kid. The engine bar might have been nice, but it is unnecessary. I used the jack and chunk of wood method. Each side, front and back. It's difficult torquing the transmission mounts with a normal sized Torque wrench. For the front, if you do it one side at a time at least loosen the nut for the other side, but don't take the nut off. This eases the tilt of the engine. Don't torque the top bolts on the front mounts until you're done. It keeps things flexible as you finish the job. For the rear mounts it makes things easier the higher up you have your car raised. All in all it took me about three hours.
If you have a front mount that has leaked out it can end up with one side of the engine an inch or two lower than it should be. I had that issue on my passenger side. You will have to raise the engine up higher on that side to install the new mount. If you have this issue however and a manual stick, your car will shift much better when you do this job. It's worth the effort.
curry is offline   Reply With Quote
Old 01-17-2020, 01:02 PM   #16
gagi
My Ride: E46 325i
The vibration that I am experiencing is not bad at all. It is hardly noticeable in N and very slight in D. How much improvement can I expect from new mounts? Will I notice during acceleration and deceleration?
Old 01-17-2020, 02:43 PM   #17
smolck
Mine were complete blown out. I noticed a difference, especially in shifting (manual trans). If yours are as bad as mine were, you’ll notice.
Here are mine compared to the new M3 mount.....
ID:	791833   Click image for larger version
Old 01-17-2020, 02:49 PM   #18
curry
My Ride: 2002 330Ci
Wow. Those look even worse than mine did. At least both of mine were still intact. Was your passenger side the one that was the most compressed?
Old 01-17-2020, 03:10 PM   #19
smolck
Yes, broken one came off the driver side, flat one from the passenger side.
Old 01-17-2020, 06:54 PM   #20
Overboost
Overboost's Avatar
My Ride: 2002 325i
If the oil pan gasket is on your "to do list", then get the Harbor Freight engine support bar, you will need it anyway for that job.
No Fear
