What else to replace while replacing OFH Gasket ? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 04-12-2019, 11:30 PM   #1
OnTheFence
My Ride: 2001 330i (and 530i)
Helping a friend replace his OFHG.
His car
http://www.realoem.com/bmw/enUS/part...MW-325xi&mg=11
Replace #1,6,15
(2 pulleys and Belt)
http://www.realoem.com/bmw/enUS/show...diagId=11_2190
#15
(VANOS line)
http://www.realoem.com/bmw/enUS/show...diagId=11_2170
#4
(Fan shroud rivet)
http://www.realoem.com/bmw/enUS/show...diagId=17_0139
Anything else ?
0714,0171: It was the MAF. NOT intake boots. NOT vacuum lines. NOT Fuel pump
OnTheFence is offline   Reply With Quote
Old 04-12-2019, 11:38 PM   #2
OnTheFence
Notes from when I did mine
https://forum.e46fanatics.com/showth...1108819&page=2
To summarize:
Replaced all 4 PS hoses and PS reservoir. Top tip: Used the 15mm wrench to press against the 2 quick-disconnect lines
Removed electric fan.
Replaced serp. belt and 2 pulleys.
Moved alternator. (That was scary for me)
Top Tip: Hammer that lower bolt thread sleeve back to flush by hammering the bolt.
I used a 4lb hammer and hit it about 50 times until it finally started to move. Once it moved, it's just a few more taps.
Replaced OFHG and Vanos oil line
Topped off the ATF in the PS reservoir.
UPDATE: Here were the main steps:
1) Remove airbox.
2) Remove fan
3) Remove belt
4) Remove alternator
5) Remove OFHG
Old 04-13-2019, 02:37 AM   #3
LeverThis
My Ride: 2004 325i automagic
Its a little easier to replace the ccv with the oil filter housing removed. Also you will have a much better view of the coolant hard pipes where they go into the head, so inspect for any signs of leaks.
LeverThis is offline   Reply With Quote
Sponsored Links
Advertisement
Old 04-13-2019, 06:55 AM   #4
markusmarkus
My Ride: 2018 M240i
Step 1: remove the ground/negative/earth cable from the battery if you’re going to mess around with the alternator. Just saying.
Old 04-13-2019, 07:05 AM   #5
DrewG5
My Ride: 2004 BMW 325i
Year: 2004
Transmission: Automatic
Sounds like personal experance. Ouch..
Sent from my SM-N950U using E46Fanatics mobile app
DrewG5 is offline   Reply With Quote
Old 04-13-2019, 10:48 AM   #6
beechbmw
My Ride: 2004 330ci Coupe
Transmission: 6 spd SSG
Just a random thought from my humble and meager experience, you may also want to consider replacing the voltage regulator on the alternator while the alternator is out of the car. This would be if the car and or voltage regulator has more than ~150,000 miles on it. Just a thought coming from 'I wish I would have done that while I was in there'.
beechbmw is offline   Reply With Quote
Old 04-13-2019, 04:34 PM   #7
Chris C
My Ride: 2001 325Ci
+1 on the voltage regulator like beechbmw suggested. When you compare a new one with a worn out one you'll see a big difference.
Chris C is offline   Reply With Quote
Old 04-14-2019, 07:11 AM   #8
markusmarkus
My Ride: 2018 M240i
Be advised that BMW sourced alternators from Bosch and Valeo, a French company. They are not interchangeable without considerable work. The only way to tell which alternator is in your car is to read the label at the back of the alternator. Hopefully it’s a Bosch as the voltage regulator is fairly cheap.
Old 04-15-2019, 06:54 AM   #9
OnTheFence
Friend's car has 70k and I doubt I will bother changing the voltage regulator.
But, I will note the alternator brand upon removal.
Valeo VR
12317551153
http://www.realoem.com/bmw/enUS/show...diagId=12_1083
Bosch VR
12317559183
http://www.realoem.com/bmw/enUS/show...diagId=12_1084
Old 04-19-2019, 01:00 PM   #10
OnTheFence
Friend has a Valeo 120
Similar Threads
Thread Thread Starter Forum Replies Last Post
Oil Filter Housing Gasket DIY beberle DIY: Do It Yourself 317 03-06-2017 01:30 AM
Trunk Handle Gasket Replacement - Success! shadowen DIY: Do It Yourself 8 03-07-2010 07:03 PM
1987 4runner SR5 Rear Differential Gasket Replacement DIY Guide (with Pics!) Philbert Test Board 2 05-27-2009 12:39 PM
Is this my valve cover gasket leaking? Solidjake General E46 Forum 13 12-14-2008 07:41 AM
Blown Head Gasket. streetlegal General E46 Forum 18 12-10-2008 09:55 PM
