testing door actuator - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 11-09-2019, 08:10 PM   #1
nylpug
My Ride: 325i (M56), 330ivert
Year: 2003
2002 330cic Driver side door not locking via remote nor with the lock/unlock button inside the car. The passenger side lock works as usual.
I took out the driver side actuator out today. Took about 15 minutes to slide it out.
Now my question is: how can I test the actuator? What pins do I hook up to a 12-volt battery to test to see if it is bad or not? Attached is a wire diagram of the actuator plug.
I want to test it to make sure it is the actuator that is not working. Which pins do I test?Click image for larger version
nylpug is offline   Reply With Quote
Old 11-09-2019, 08:37 PM   #2
BaliDawg
DEADBEEF BAADF00D
BaliDawg's Avatar
My Ride: E39 E46 E84
I would first verify that all the expected signals appear on that connector during various lock/unlock actions. This isolates the problem between the controller and the actuator.
Looks like you apply voltage to pin 1 to lock and pin 5 to unlock.
Old 11-10-2019, 01:19 AM   #3
scottjoh
Modded ///Member
My Ride: '99 323i & '02 540i
BaliDawg, pin 4 is not ground for the actuator motors pins 1 and 5 that you mentioned. Pin 4 ground is for the Hall effects sensor on pins 6, 7 and 8.
scottjoh is offline   Reply With Quote
Sponsored Links
Advertisement
Old 11-10-2019, 01:49 AM   #4
BaliDawg
DEADBEEF BAADF00D
BaliDawg's Avatar
Thanks for the correction.
Iíll fix my post.
Old 11-10-2019, 11:13 PM   #5
nylpug
Year: 2003
Anyone wants driver side door actuators for free to test if they are good or not? I don't think they work but don't know how to test them. One of them for sure doesn't work as it came from my 330cic.
Here is the story: I got 2 actuators from a junk yard to try to fix my door lock problem. I got 2 in case one of them is bad as all parts were on sale that day. I changed the first one and it didn't work. And then I changed the second one and it worked. In thinking about my installation, I might not have installed the first one correctly.
If anyone wants these driver door actuators, they are free (if not far from Pasadena, CA). Again, one of them for sure doesn't work and the other one likely doesn't work either.
In hindsight, I probably will go with new actuators and not used ones in future.
Old 11-18-2019, 11:37 AM   #6
scottjoh
Modded ///Member
If you have a 2-dr E46 you should always use new actuators.
Sent from my iPad using E46Fanatics
