6speed tranny swap Engine... tilt dumb question. - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 03-27-2020, 09:37 AM   #1
jaga
My Ride: 2002 325i
Year: 2002
Model: 325i
Transmission: Automatic
Hi all fanatics
Quick question, i´ve read from TitaniunCranium member,, *** The Official Automatic --> 6 speed (ZHP Tranny) swap! - LOTS OF PICS , to educate myself in this project as i have found this 6 speed wonderful transmission and i will be doing this swap.
however, i got a small and dumb question. This is related to removing my old auto trannny. In order to achieve this, i will be tilting motor and trans together to have access to top bolts. As said in that thread:
You’ll need to remove the micro-filter and remove the micro-filter housing (held on by Torx screws). I may have also removed the fan housing to maximize the rearward tilt of the motor against the firewall. Take a look when you doing this. You will need every inch of room you can get. Now unbolt the transmission support brace and let the tranny down a little bit. Check your clearance against the back of the motor and the firewall.
my question is, while lifting engine, should i remove the engine mounts top and/or bottom nuts?
I am afraid of damaging engine mounts.
Please share your experience.
E-FortySicks
jaga is offline   Reply With Quote
Old 03-27-2020, 10:50 AM   #2
MrMCar
My Ride: E30M3 F10 RT
If the motor mounts are good(?) (test first with a pry bar) tilting the engine back does no harm.
Besides that it holds the engine in place. If you loosen/remove them the engine can rotate and/or slide back. No Bueno.
We always leave them attached. Albeit long extensions and lots of reaching over the top is needed. Make 101% sure your sockets are fully engaged by tapping the extension to seat them onto the fasteners before removing.
When you remove the torque converter bolts (Facing forward) pry the torque converter back and spin it a little. You want to be sure it's not stuck to the flywheel. Otherwise when you remove the automatic transmission the converter will get stuck.
Less room and when the transmission comes free of the torque converter, it will be a huge mess of ATF.
Don Fields
////MrMCar
www.mrmcar.com
MrMCar is offline   Reply With Quote
Old 03-27-2020, 11:25 AM   #3
jaga
My Ride: 2002 325i
Year: 2002
Model: 325i
Thanks a lot. This is what i needed. Great tip to make sure the flywheel is not stuck.
It seems you have done this before. Could i bother you during my swap for some advice?
If it is okay with you please send me an email to.
[email protected]
I am at the starting point and although i have done other fixes to my car, never have done a transmission swap.
Thanks a lot
E-FortySicks
Sponsored Links
Advertisement
Old 03-27-2020, 11:28 AM   #4
MrMCar
Torque converter, not the flywheel. Flywheel is bolted to the back of the crankshaft.
Don Fields
////MrMCar
www.mrmcar.com
Old 03-27-2020, 12:50 PM   #5
Effduration
My Ride: '05 330CiC
+100 on this...if you strip an e-torx bolt removing the trans, which is easy to do, you are in for a world of hurt, particularly as a first timer.
there are E-10, E-12, & E-14 sized fasteners on the bell-housing. I suggest you get the E-12 & E-14 sockets in both a 3/8 and 1/2 drive size...the E-14 in particular..impact sockets are good, but remove these bolts by hand if possible.
if you are doing this on jack stands, the harbor freight scissors trans lift is a worthwhile purchase at $99 (from memory)
Effduration is offline   Reply With Quote
Old 03-27-2020, 06:29 PM   #6
Renboy
My Ride: 04 330Ci '08 Daytona
Another issue with tranny removal is the torx bolts go through the tranny, through the engine, and have exposed threads. If there's crap on the threads of the bolts, when you remove them, the crap jams up in the block. I've had it happen that the bolt is corroded to the point that it tore the threads in the engine block apart, and then snapped. Not a place you want to be.
Renboy is offline   Reply With Quote
