Is 330Ci exhaust similar to 325iís? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 03-25-2020, 10:44 AM   #1
jaga
My Ride: 2002 325i
Year: 2002
Model: 325i
Transmission: Automatic
Hi all
My car is a 2002 325i auto sedan.
My next project is to make 6MT swap. I got a donor car which is a 2004 330Ci.
I am also thinking to take the complete exhaust pipes and the exhaust headers.
Are those parts Interchangeables?
If so, will the 325i sound improve?
I have checked realoem but exhaust headers show different part Numbers, however fcpeuro show es that they fit both M54 motors.
I appreciate your comments.
E-FortySicks
jaga is offline   Reply With Quote
Old 03-25-2020, 10:45 AM   #2
smolck
My Ride: 2003 330ci (manual)
The exhaust manifolds for a 330 will fit a 325 and vice versa. 328 and 323 manifolds are different where they connect to the rest of the exhaust. My experience is the sound will not change. For that, add an aftermarket muffler or delete one or both resonators.
Check out my BMW Blog
Check my Youtube channel for DIY's and fun stuff
smolck is offline   Reply With Quote
Old 03-25-2020, 10:50 AM   #3
jaga
My Ride: 2002 325i
Year: 2002
Model: 325i
Great. That was my initial idea, bit needed to be aire. Thanks a lot for your fast response. Happy 3-25 day
Enviado desde mi iPhone utilizando E46Fanatics
E-FortySicks
Sponsored Links
Advertisement
Old 03-25-2020, 10:57 AM   #4
smolck
No problem. By the way, I just replaced my cats with true headers and I went to my local metal recycle place with the old cats, they gave me $80 a piece for them, so if you have extras lying around, may want to sell them to your local recycler and make some $$$ to help get that 6 speed in there
Old 03-25-2020, 01:35 PM   #5
TobyB
My Ride: 2004xit, 2001ci
I thought the 330 exhaust piping was larger diameter,
but that's only from having to lift the 325's and the 330's, and thinking the 330's was heavier.
Not very scientific,
t
"I'm sorry. I actually had to poop and ended up breaking the car."
- Hot Tub
TobyB is offline   Reply With Quote
Old 03-25-2020, 03:10 PM   #6
MrMCar
My Ride: E30M3 F10 RT
Best to look up the exact part numbers of your VIN and compare parts pictures of the cats/downpipes/flange orientation and the middle section to that of what you desire to install.
Short version.
Had a customer with a high mileage 325. Had clogged cats. Sourced used cats and the flange had different orientation and would not bolt up.
Luckily we had a new take off mid/rear section that fit. I wasn't about to repeat the cat R&R for a mis-match with the flanges.
It was so long ago I don't have the model information in my database any longer.
Just take 5 min and check.
Don Fields
////MrMCar
www.mrmcar.com
MrMCar is offline   Reply With Quote
Old 03-25-2020, 03:15 PM   #7
smolck
t
Same part numbers in realoem, save for the mufflers which are different depending on year/options. But the exhaust manifolds (cats), pipe diameter, front resonator and rear resonator are all identical. 2" if memory serves.
Old 03-25-2020, 04:00 PM   #8
Aidzer0
My Ride: BMW
Year: 2001
Model: 325i
Transmission: S5D 250G
I thought ci e46ís had longer headers on the flange side. Due to coupe/vert vs sedan. I can imagine that cat back could be the same length. Since the extra length is at the cat flange.
I also believe that the 330 has the valve flap in the muffler and the 325i doesnít.
Aidzer0 is offline   Reply With Quote
Old 03-25-2020, 05:37 PM   #9
BaliDawg
Here to serve yíall
BaliDawg's Avatar
My Ride: E39 E46 E84
Some 325s do have the exhaust flap.
Old 03-25-2020, 09:07 PM   #10
smolck
I thought ci e46's had longer headers on the flange side. Due to coupe/vert vs sedan. I can imagine that cat back could be the same length. Since the extra length is at the cat flange.
I also believe that the 330 has the valve flap in the muffler and the 325i doesn't.
I just put headers for a sedan on my coupe. No differences, bolted right up. And once again, realoem.com lists 325 sedan exhaust manifolds as the same part number for my 330ci.
Yep, which is why realoem.com shows multiple part numbers for the muffler based in mtech package or not.
