Coolant System overhaul questions - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 11-03-2017, 09:10 AM   #21
mjbrox
My Ride: 325CI Convertible
Originally Posted by assifitness View Post
What kind of beer
http://skabrewing.com/brews/modus-hoperandi-ipa/
mjbrox is offline   Reply With Quote
Old 11-05-2017, 10:13 AM   #22
mjbrox
I finally got around to driving it yesterday.
Well the coolant reservoir is leaking where it's supposed to meet up with the mounting plate thing.
Was there an o ring I missed? Is it a faulty part.
I honestly don't see how it could have been done wrong.
I'll pull the tank tomorrow night but I really hope I don't have to pull the mounting bracket.
Anyway it's not huge deal since I got the parts from fcp. But it is annoying
Old 11-05-2017, 12:11 PM   #23
Spannerhead
Spannerhead's Avatar
My Ride: '02 330i/5 slicktop
Did the parts click when you pushed them together?
Current:
Past BMWs:
Past Other: '85 GSL-SE '88 JZA70 '86 4K quattro '85 RX-7 S '85 RX-7 GSL
Spannerhead is online now   Reply With Quote
Sponsored Links
Advertisement
Old 11-05-2017, 02:06 PM   #24
mjbrox
They did
Old 11-05-2017, 03:22 PM   #25
Neonnblack
My Ride: '03 330XI
If I'm thinking of the same place where the bracket goes into the radiator yes there is an o ring for it. There are o rings all over this cooling system that like to fall off without you knowing when taking it apart.
Sent from my SAMSUNG-SM-G930A using E46Fanatics mobile app
Neonnblack is offline   Reply With Quote
Old 11-05-2017, 04:03 PM   #26
mjbrox
I'd really like to dick punch the guy who designed this cooling system.
Oh well once I get this sorted the car is trouble free, right?
Old 11-05-2017, 05:40 PM   #27
OnTheFence
My Ride: 2001 330i (and 530i)
I don't recall having to explicitly install any o-ring.
Aren't they already on the parts themselves?
0714,0171: It was the MAF. NOT intake boots. NOT vacuum lines. NOT Fuel pump
OnTheFence is offline   Reply With Quote
Old 11-07-2017, 08:21 PM   #28
mjbrox
So I pulled the Reservoir and there was nothing obviously wrong with it. So I put it back together and it is still leaking
How can I tell if it is the reservoir for the mounting bracket
Is it possible to replace the mounting bracket without pulling the radiator?
Old 11-08-2017, 05:09 PM   #29
mjbrox
I emailed FCP and they dont think it is fully seated. How much force do you have to put on this thing?
Old 11-08-2017, 05:35 PM   #30
TR4G-
My Ride: E36/8 3.0i, E46 ZHP
Do not use anti seize on the bolt. Torque specs are designed for dry and clean installation (unless otherwise noted). If you use anti seize (or the opposite - have loads of crud in the threads) you will hit that torque spec much later than had you not used antiseize (aka the bolt will spin farther in than designed before getting to the specified torque. And the opposite if there is loads of crap in the threads - you would reach the torque spec earlier than were it clean). Not really a big deal as many people forgo torque specs all together - but still, as good practice, try not to use antiseize unless instructed to!
TR4G- is offline   Reply With Quote
Old 11-08-2017, 05:46 PM   #31
LeverThis
My Ride: 2004 325i automagic
I can't remember off hand and I've done it on 2 cars. Removal was the hard part for me from what I remember.
Go to minute 24:30 in this 50skid video to see him install the ET ... he doesn't seem to use THAT much force ...
Is the ATF t-stat fully seated? Piece of the old one left behind?
Not sure if mentioned already, but what brand parts are you using?
LeverThis is online now   Reply With Quote
Old 11-08-2017, 06:17 PM   #32
mjbrox
Its a manual transmission.
The bracket is OEM and the Reservoir is Rein....or Visa Versa.
Yea, I had my neighbor install it the second time around when I was under it. I saw the metal clip, click
This is so annoying.....
Old 11-09-2017, 07:09 AM   #33
OnTheFence
Not a ton. I actually have the spare parts in my garage, and will post a video of them being snapped together tonight or tomm. AM.
Old 11-09-2017, 07:21 AM   #34
jeng
My Ride: 2001 BMW 330ci
I used a screw from Home Depot
The old thermostat housing screws were corroded (2001 330ci). Replaced the screws in July 2017 and the car has been running fine since then.
Except for the damn headlights...which is another issue.
jeng is offline   Reply With Quote
Old 11-09-2017, 07:46 AM   #35
Spannerhead
Here's another possibility:
https://forum.e46fanatics.com/showthread.php?t=1101813
Current:
Past BMWs:
Old 11-09-2017, 08:11 AM   #36
mjbrox
When I pulled it off fa the print looked like the one in the car l, which was ironically Behr
Old 11-09-2017, 04:05 PM   #37
mjbrox
ICP is sending me new parts.
BTW, great customer service at FCP
Can i remove the retaining bracket thing without removing the radiator?
Old 11-11-2017, 11:06 AM   #38
mjbrox
I?m putting in the new parts and I?m now noticing that the coolant level sensor has no o-ring. Is that normal?
Old 11-11-2017, 12:16 PM   #39
turbo1168
My Ride: 01 330ci FIAT 500
That's because it's a dry chamber it runs in, uses a magnet in the tank.
turbo1168 is offline   Reply With Quote
Old 11-13-2017, 02:50 PM   #40
mjbrox
Thank you everyone.
I got all the parts in on Saturday and its leak free. I even felt confident enough to have my wife drive it to work
