Gears on a BMW? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 05-11-2004, 04:20 PM   #1
Glory22
My Ride: 323ci
Gears on a BMW?
I'm curious...can you put a set of gears on a BMW to help it's acceleration off the line? A buddy of mine has a new Mustang GT, and he's putting a set of gears on to help in acceleration. I know you can spend a fortune to supercharge a 323ci, and get a dinan chip...would gears work? If so has anyone done this?
Thanks!
Glory22 is offline   Reply With Quote
Old 05-11-2004, 04:25 PM   #2
notE46
it costs a bigger fortune to purchse the new gear sets. on tope of that they are hard to find and then you have to have them installed. etc.
s/c is cheaper
notE46 is offline   Reply With Quote
Old 05-11-2004, 04:35 PM   #3
slow323ci
E46-free since 10-13-06
My Ride: 335i coupe
Sure. Many people on these forums have done it, including me. Except with a BMW, you change the whole diff assembly rather than the gears inside it.
I swapped my original 3.07 differential for a 3.46. Made a huge difference.
Do a search for "differential" and you'll see dozens of threads about this.
P.S. - It's not even expensive - my swap cost less than $460 for parts and labor. The parts were from a wrecked 323.
slow323ci is offline   Reply With Quote
Sponsored Links
Advertisement
Old 05-11-2004, 04:50 PM   #4
notE46
I think he was talking about the gears in the transmission... but I could be wrong.
Old 05-11-2004, 05:32 PM   #5
slow323ci
My Ride: 335i coupe
Nah... When a Mustang guy (or anyone with a muscle car or hot rod) says he "got gears" that means in the differential.
Old 05-11-2004, 06:00 PM   #6
bobm3
Senior Eurowerkz Member
bobm3's Avatar
My Ride: 2003m3smg
when you say gears to get off line faster you mean
rear gears in the diff. i agree get 346 gears they are not that costly. not like
the ones for my m3 411 and 433 they will cost 3,000.00 to buy and install
if you put in the 346 gears you will get a good bang for your dollar. they will give you in the neigberhood of 20% more torq. from what you have already.
you won't be a burner but you will move faster it is worth the money in the case of the 346 gears. look in the for sale forum you just might see a set of does gears for sale.
bobm3
bobm3 is offline   Reply With Quote
Old 05-11-2004, 06:48 PM   #7
teamdfl
Slow in, slower out
My Ride: 325it
I just swapped the stock 2.93 diff in someone's 328 with a 3.15 from a 325.
Ed
Real racers race LeMons
teamdfl is offline   Reply With Quote
Old 05-11-2004, 07:55 PM   #8
bbh03
My Ride: M5, X5, 911SC
Ed
How much did that 3.15 come to if you dont mind me asking? They seem to be alot more than 3.46s.
bbh03 is offline   Reply With Quote
Old 05-11-2004, 08:49 PM   #9
teamdfl
Slow in, slower out
My Ride: 325it
I have no idea how much it cost. I think the owner of the car bought it from someone who installed a 3.46 to replace the 3.15.
Ed
Old 05-11-2004, 08:51 PM   #10
cowmoo32
cowmoo32's Avatar
My Ride: Yukon, E92 M3
I hear ppl at my school w/ camaros saying "I got me a 4.10 gear"...no, you didnt. You got a new differential. Sorry, that just annoys me. I had to tell someone.
Simsima got a new differential and I remember reading that he said it make all the difference in the world. The RPMs are just higher when cruising on the highway.
Old 05-11-2004, 09:00 PM   #11
Amalfi
Ed
No regrets at all? Like is 1st gear too short now? Does the car rev too high on the highway?
Amalfi is offline   Reply With Quote
Old 05-11-2004, 09:19 PM   #12
teamdfl
Slow in, slower out
My Ride: 325it
Again, it's not my car. From what I've heard, the owner loves it and has zero regreats. He said the minor change in revs (7.5%) on the highway is barely noticeable.
Old 05-11-2004, 09:43 PM   #13
Glory22
My Ride: 323ci
Thanks for all your replies guys!
I was talking about the differential gear replacement. What do the numbers of the gears mean...like 3.07, or 3.46? Are 3.46 gears made by BMW or are they aftermarket. Also, if i switch to these gears does it make the car unreliable or anything?
"Slow323ci": What exactly did you do to your 323ci, besides the gears in order to make it quick? I have the same model car and i'm looking to modify in order to make it a little quicker.
Thanks for your help!
Old 05-11-2004, 09:54 PM   #14
teamdfl
Slow in, slower out
My Ride: 325it
Swapping the gearset inside the differential assembly (a.k.a. the final drive) is possible but requires some critical shimming to set gear mesh and bearing preload. It is usually much cheaper to find a complete used differential assembly from another BMW with the desired gearset already installed. All non-M E46 differential assemblies are interchangeable. At most you may have to swap output flanges which may only require a couple long screwdrivers for leverage. They are held in only by a wire clip and are easily pried out.
The number is a gear ratio determined by the number of teeth of the ring gear (output) vs. the pinion gear (input). For example: 41 teeth on the ring gear and 13 teeth on the pinion give you a 3.15 ratio. 41/13=3.153846 3.15 is close enough. That means that for every 3.15 turns of the driveshaft, the axles will turn once.
Your car will not be less reliable with a lower gear (higher numerically). At worst, you will increase the RPMs at any given speed which will probably drop a couple MPG off your gas milage.
Old 05-11-2004, 10:28 PM   #15
slow323ci
My Ride: 335i coupe
Hmmm, things I did to make my 323 quicker, in order of improvement:
- 3.46 differential swap made by far the biggest difference
- Conforti Shark software
- Conforti intake
- Borla exhaust
- Plasma Direct ignition coils
BTW, if your 323 is an automatic you already have the 3.46 diff.
I easily outran a Porsche 968 the other day. I'm not sure how fast those are though.
Old 05-11-2004, 11:06 PM   #16
Donkey
Don't think so. When they say that got a 4.10 gear, that's what they got: a new ring and pinion gear with a ratio 4.10, not a new differential. There is a lot more to a differential then just those two gears.
Mike
Donkey is offline   Reply With Quote
Old 05-12-2004, 09:57 AM   #17
Glory22
My Ride: 323ci
Yeah, mine's an automatic with steptronic....that means i already have the 3.46 gear ratio? So there's nothing i can really do to the differential then i guess
Old 05-12-2004, 11:37 AM   #18
slow323ci
My Ride: 335i coupe
Yes, you already have the 3.46. Nothing you can do...
Old 05-12-2004, 12:33 PM   #19
teamdfl
Slow in, slower out
My Ride: 325it
3.64 from a Z4 2.5
Old 05-12-2004, 12:35 PM   #20
Glory22
My Ride: 323ci
Have you done that to your car? changing to a z4 differential...
