Reusability of 150k Dual Mass Flywheel - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 03-17-2019, 08:29 AM   #1
stevemd
My Ride: 325xiT, XC60, CR-V
Year: 2004
Model: 325xiT
Transmission: 5spd
Pics below of my 150k DM Flywheel and the 100K clutch disc. 2004 325xit 5 spd.
The disc surface of the flywheel is pretty smooth though some heat spots.
I had heard there is supposed to be some measurable play between the dual mass halves to help determine reusability or toss of the flywheel but Bentley has f*** all to say about that, indeed no mention of the flywheel at all.
Appreciate any advice.
Also I would appreciate feedback on the Valeo single mass kit if anyone has used it and can comment.
Thanks!
ID:	770405   Click image for larger version
stevemd is offline   Reply With Quote
Old 03-17-2019, 09:23 AM   #2
74123
Guest
My Ride: 320i SE Coupe
Thanks!
So long as the teeth are ok and there is no warping you're fine. Assuming it's sitting correctly on the crankshaft you can buy or borrow a DTI with a magnetic base and check the runout.
Having said that I recall reading somewhere that the dual mass flywheels are a pain and that you should take the opportunity to replace it with a single mass.
74123 is offline   Reply With Quote
Old 03-17-2019, 09:38 AM   #3
Effduration
My Ride: '05 330CiC
In my limited observations (10 people or so) more than 50% of those who have switched to a SMF in a non-racing application regretted doing so due to the noise or chatter of the SMF and/or new clutch disc
I recently re-used a dual mass flywheel DMF with approx 150k on it, about 3 months and 2k miles ago. I had two to choose from. I used a new LUK clutch kit. I've had no problems since install.
You need to measure the rotational play in the DMF. Check my facts, but I think the max is 5 teeth from full right to full left or vice versa. There is a good YouTube on this issue, please search for it.
If there is excessive front/back play in the DMF, that would also be a reason to replace it.
Effduration is offline   Reply With Quote
Sponsored Links
Advertisement
Old 03-17-2019, 12:39 PM   #4
SidewaysGreg
My Ride: E46 330Ci
Year: 2002
Transmission: 5spd manual
Zero issues with my SMF (10lbs), minimal chatter (have to really listen to it to hear anything at all).
For dmf it totally depends on the play. If itís moving more than 1/2Ē without resistance Iíd change it.
SidewaysGreg is offline   Reply With Quote
Old 03-17-2019, 06:18 PM   #5
76m2002
My Ride: 2002 325iT
Year: 2002
Model: 325iT
Transmission: 5-speed
The problem with DMF is that there is just more stuff go wrong, especially at your mileage. A SMF is just fine; I've converted two e46's, an e30, and two Mini Coopers to SMF. I usually use the Valeo kit. No problem with chatter as long as you use as stock-ish flywheel. I've used a UUC lightweight flywheel in one e46 and it was fine, but did have a bit of chatter at idle.
'76
'02 325iT
'91 318is
76m2002 is offline   Reply With Quote
Old 03-18-2019, 09:37 AM   #6
stevemd
Year: 2004
Model: 325xiT
Transmission: 5spd
Thanks for the replies. I will throw the DM back on the end of the crank and check for play and warp w/dial indicator.
May lean towards the Valeo SM kit as I believe that is a 'stock-ish' flywheel. Feel free to suggest other SM FWs more stock-ish if they exist and don't cost an arm and leg. I'm fine with ponying up the $$ for the Valeo kit.
Old 03-18-2019, 04:00 PM   #7
Sapote
My Ride: 2000 323i auto wagon
Any history on the old parts? Why opening up the tranny for checking this?
For normal driving I think you just replace the clutch disk if the DMF rotational play is less than 20mm at the circumference moving them with hands. Why switch to SMF -- cheaper? The high torque engine was designed to work with DMF to minimize shock load to the transmission internal parts.
Sapote is offline   Reply With Quote
Old 03-18-2019, 05:51 PM   #8
76m2002
My Ride: 2002 325iT
Year: 2002
Model: 325iT
I wouldn't call the 2.5L or 3.0L engine "high torque". If I recall, the DMF came into existence because it was easier for inexperienced drivers to shift smoothly. It doesn't really have any advantage once you have a little experience with a manual transmission. The problem with using an old DMF is that if the mechanism fails, you have to pull the tranny again to change it, so it makes more sense to just change the flywheel when you do the clutch disc.
'76
'02 325iT
'91 318is
Old 03-18-2019, 07:12 PM   #9
Geo31
Ironman
My Ride: 98 M-Z3/01 330iT 6MT
ECS has the DMF on say for less than $400. Why take the risk on an expensive (or PITA) job? You can get a complete kit for a little over $500.
George Roffe
Swim: 2.4 Miles
Bike: 112 Miles
Run: 26.2 Miles
Brag: For the rest of your life
Geo31 is offline   Reply With Quote
Old 03-18-2019, 07:31 PM   #10
Megalocnus
My Ride: 05 330i ZHP/MT
It is relatively rare to see DMF failures not due to worn out clutch and/or abuse, so chances are if the flywheel is ok now, it is going to last.
This is why Sapote's question above is important - what's the reason the flywheel is out of the car?
The car needs a new clutch, or something else unrelated, i.e. engine swap?
Megalocnus is offline   Reply With Quote
Old 03-18-2019, 08:09 PM   #11
bremerd1
My Ride: 323
Year: 2000
Model: CI
Transmission: ZF 5HP19
I did the valeo kit while replacing an engine due to the head warping (123K miles) on a project car. It was a 'while we have it apart' thing. It did chatter at first and was quite noisy, but as it wore in (less than 3000 miles) the chatter seems to have gone away. If you do the valeo kit, get the clutch delay valve delete fitting as well --- it really helped give the clutch a much better feel...
Dan B
bremerd1 is offline   Reply With Quote
Old 03-18-2019, 09:02 PM   #12
DiceyOne
My Ride: 1999 328i
Send a message via AIM to DiceyOne
Your DMF is fine. I'd hit the surface with some red scotchbrite - all of those dark "hot spots" will blend in and you'll realize that they are mostly composed of disc material that is just trapped in the micro-grooves of the friction surface.
As for rotational play, don't be scared into a new flywheel from watching BavAuto's video. Otto is in the business of selling parts and has a habit of displaying properly functioning parts and calling them defective, the DMF rotation is a great example. He's been spooking ppl on here to buy a SMF for years.
Want to know why all DMFs have 4 degrees of rotational play built in?!? Well just go over to the manufacturer's site and watch them explain how it is built.
DiceyOne is offline   Reply With Quote
Old 03-19-2019, 06:32 AM   #13
Effduration
My Ride: '05 330CiC
+1 on this... Otto's video on the Dual Mass Flywheel was inaccurate. The rotational play shown in his video, which he says means it's worn out, seems quite normal. Many of his other videos are quite good.
Brand new DMF's come with 3 teeth of rotational play in them.
Old 03-19-2019, 10:30 AM   #14
jamesbice
My Ride: 2001 M3
I am one of the several examples of people who regretted a SMF. I installed the valeo kit after doing a manual swap. Great feel, but it puts a lot of strain on other components and I got an annoying amount of chatter. I went to the considerable expense and bother of putting in a luk dmf and clutch kit 12 months after.
Personally I would stick with a Dmf, thatís how Bmw designed the car and all the driveline components around it
jamesbice is offline   Reply With Quote
Old 03-19-2019, 12:19 PM   #15
jagmandan
My Ride: E46 325xit -> 330xit
If you want a precise spec on the allowable rotation, Luk has it on their website. I opted for a new DMF.
jagmandan is offline   Reply With Quote
Old 03-22-2019, 01:31 AM   #16
billmr
My Ride: 330ci
You should replace it with another dual mass one, they are not a pain, just a little more expensive, however they are a lot more expensive if you have to do it twice like i did since I used a UUC one.
I repeat
DO NOT USE A UUC single mass rattle maker.
I put one in my e36 m3 it was super annoying and the m5 clutch wore out in 20k
I then put a new dual mass one in and was really happy for lots of miles.
billmr is offline   Reply With Quote
Old 03-23-2019, 01:19 PM   #17
bmwerkes
Para-Magic
My Ride: 01 330i, 5 spd
I have an ACT single mass set up that has been great for years. I thought that the DMF was to soften the driveline lash and make the car feel "Smoother". It also dampens innacurate and clumsy clutch behaviour. The SMF feels more direct, but if you go too light, or too cheap you are asking for trouble in a daily drver. Really light flywheels are for track cars that dont see traffic lights, spend most of their day close to redline, and dont care about excess noise.
ACT Streetlight Flywheel, ACT Sport clutch, Rogue Engineering SSK, H&R Sways, H&R Sport Springs, KONI Yellows, Alcantara M3 Coby Wrapped Wheel, Dinan Strut Tower Brace, Active Autowerke Headers, Kassel Performance Tune, BMW Performance Rotors, ZHP Shift Knob, UUC Transmission Mounts w/ Enforcers, SAP Delete,
bmwerkes is offline   Reply With Quote
Old 03-27-2019, 02:53 PM   #18
stevemd
Year: 2004
Model: 325xiT
Transmission: 5spd
A lot more good feedback, thanks!
Reason the driveline is apart is that I am swapping in a M54B30. Retaining the 5 speed.
Old 03-27-2019, 03:03 PM   #19
stevemd
Year: 2004
Model: 325xiT
Transmission: 5spd
Oh, by the way, I thought that was odd wear on the clutch disc, tapered from outside in on both side of the disc. It only has 44k miles on it as the clutch assembly was replaced by PO's shop at 144k.
Old 04-22-2019, 05:55 PM   #20
stevemd
Year: 2004
Model: 325xiT
Transmission: 5spd
As a general reference, non-auto make specific, Luk says up to 6mm. I measured 6.5mm and about 2.5 teeth in rotation. Easy to rotate. I thought the halves are spring-loaded and would require some force to rotate but I am a DMF noob.
No axial play to mention.
Similar Threads
Thread Thread Starter Forum Replies Last Post
E46 328 '00 328ci 5spd 150k 3500$ Steelheart3c Complete Cars - Private 2 03-16-2019 06:11 PM
E46 M3 FS: CAE shifter, DSSR rod, two SMG gearboxes, HPF Feramic Clutch, flywheel... OldmanLance Engine & Performance 4 02-16-2019 01:54 PM
Rockford Punch HE 12" dual coil SUB...good? m3kid Mobile Electronics Forum 1 12-24-2003 07:08 PM
DUAL question? Presns323i General E46 Forum 2 12-22-2003 05:38 PM
Single, dual, or dedge mdowg10 General E46 Forum 14 12-14-2003 12:01 AM
