M54B30 Swap Into 325xit, Clutch Kits - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Xi Forum
Old 12-27-2018, 06:21 PM   #1
stevemd
My Ride: 325xiT, XC60, CR-V
Year: 2004
Model: 325xiT
Transmission: 5spd
Looking for a clutch kit and from what I have seen on RealOEM, the 330xi and the 325xi use the same kit 212 1752 8211.
However over on FCPEuro they show the above part # only for the 330xi. The 325xi gets a 212 0753 1556 kit which is also the kit for the 330i (rwd).
So, I'm wondering if FCP got it wrong for clutch kits.
Back on RealOEM for the pilot bearing in the back of the crankshaft, it looks like the 330xi and 325xi have different part numbers. The dimensions of the 330xi bearing are shown as 15x24x26 and the 325xi bearing is 15x32x10 of which 15 is the bearing ID and 32 is the OD. I can't get my calipers into the back of the M54B30 crank as the engine is on a stand.
I will be reusing the 325xi 5 speed. The M54B30 is a ZHP out of an auto trans rwd car.
Thanks for any info.
stevemd is offline   Reply With Quote
Old 01-09-2019, 03:29 PM   #2
wagonostic
My Ride: 01 325xiT/5MT
I'll measure the crank on an M54B30 in about an hour and get back to you, assuming it's still necessary.
wagonostic is offline   Reply With Quote
Old 01-13-2019, 10:58 AM   #3
Hrvat
My Ride: 02 Imola Red M3
What year is your xi?
For example, per RockAuto, which is 99% correct:
LUK03059 Clutch kit fits:
BMW 325XI 2004-2005
BMW 330CI 2004-2005
BMW 330I 2004-2007
BMW 530I 2004-2005
BMW X3 2004-2005
BMW Z4 2003-2011
LUK03076 fits:
BMW 330XI 2004-2005
BMW X3 2004-2005
If we go for years 2001 to 03, then:
LUK03048 Clutch kit fits JUST 330xi
LUK03049 fits:
BMW 325XI 2001-2003
BMW 330CI 2001-2006
BMW 330I 2001-2003
BMW 530I 2001-2003
BMW Z3 2001-2002
PM ME FOR FREE SAMPLES
so 2004 bmw's dont come with a diff?
Hrvat is offline   Reply With Quote
Sponsored Links
Advertisement
Old 01-22-2019, 08:47 PM   #4
jfman
My Ride: 325XIT with 3.0 6spd
The trans dictates the clutch and flywheel and not the motor. When I did my m54b30 swap I upgraded the flywheel and clutch to the bigger luk 6 speed parts only when I settled on using an x3 6 speed trans. Before that I was planning on keeping the old clutch setup. In fact I had bought a new clutch (oem 325xi) that I had assembled but I had to remove it and sell it because I was now swapping to 6 speed.
So if you are keeping your old trans, AFAIK, you need to use your old flywheel and clutch.
If you upgraded to a 6 speed trans, you need a 6 speed flywheel and clutch
325XIT M54B30 swapped, 6 speed swapped, E39 M5 SOLD, E36 M3 SOLD
jfman is offline   Reply With Quote
