Engine Removal via Subframe Drop? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Xi Forum
Old 04-19-2018, 06:53 AM   #1
stevemd
My Ride: 325xiT, XC60, CR-V
Year: 2004
Model: 325xiT
Transmission: 5spd
Is it possible to drop everything down and slide it out the front without a engine hoist?
(I may still need to rent a hoist anyway to get the engine up on the engine stand)
stevemd is offline   Reply With Quote
Old 04-21-2018, 10:24 AM   #2
EvaJuli
My Ride: E46 325XiT
How would you take it out the front without a hoist in that case?
EvaJuli is offline   Reply With Quote
Old 04-21-2018, 12:36 PM   #3
WilloCO
My Ride: '05 330xi 6 speed
Don't.
I haven't pulled my engine, but I have pulled everything else.
Get a hoist. Rent or buy. I have a HF folding unit that's annoying in the garage until I need it. Every time I use it I'm glad to have it.
You can certainly just drop the subframe with the engine attached. I suggest pulling the intake first - there's alot of wiring and plumbing under there.
I bedded my pads when I switched from ceramic to my PDF-Z pads. They actually caught fire during bed in.
05 330xi 6 speed
RIP: 86 e30 w/E36 M3 suspension build
WilloCO is offline   Reply With Quote
Sponsored Links
Advertisement
Old 05-03-2018, 07:58 AM   #4
stevemd
Year: 2004
Model: 325xiT
Transmission: 5spd
Became a good customer of HF again. Used hoist to get replacement engine on stand for freshening (seals, CCV, etc). Bit of re-learning curve but got 'er done.
Old 03-07-2019, 04:17 PM   #5
keehn
My Ride: '00 328i; '03 325x
Year: 2000
Model: 328i; 325xi
Transmission: Auto (GM); 5-speed
I know this thread is rather old, but yes, it is possible to remove the engine without a hoist. You will first need to completely remove the front end, and with three floor jacks, you can support the subframe and carefully lower down the subframe and engine/trans by lowering each floor jack evenly. I would also recommend three furniture dolly's (~10 bucks each at harbor freight) to lower the subframe/powertrain down onto, so you can roll the assembly out the front once it is lowered.
However, with the cost of the floorjacks, you may be better off just buying an engine hoist and suspending the engine from above, and then removing the subframe bolts.
keehn is offline   Reply With Quote
