CCV Replacement Issue - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 03-28-2018, 06:12 PM   #1
stevemd
My Ride: 325xiT, XC60, CR-V
Year: 2004
Model: 325xiT
Transmission: 5spd
I am having an issue connecting the new CCV to the hose that attaches to the front inlet of the small air distribution manifold attached to the top of the intake manifold.
1. I have tried it with the new hose connected to the air dist. manifold then pushing the inlet of the CCV into the hose under the intake but I am unable to get the CCV to turn into position on the hose to lock the connection and permit mounting the CCV.
That must mean the CCV needs to be pulled out of the hose connection, rotated in another direction then pushed into the hose again to try to lock the connection and orientate the CCV for mounting but there is no room to try that.
2. I also tried snaking hose, connected and locked to the CCV, up under the intake and between #1 and #2 runners but no dice.
Now I see why some guys convert to the M56 valve cover.
stevemd is offline   Reply With Quote
Old 03-28-2018, 06:39 PM   #2
jmo69
My Ride: 03 325xi 98 328is
The 50's kid had a trick for that twist connector, I don't remember exactly how he did it. I did the M56 conversion too.
Alternative to expensive xi control arm bushings
Bad outer xi ball joint?
jmo69 is offline   Reply With Quote
Old 03-28-2018, 06:44 PM   #3
2001Silver330CI
My Ride: 2001 BMW 330CI
Year: 2001
Model: 330Ci
Transmission: Auto
BMW E46 Quicker CCV Replacement - Part 1
2001 BMW 330 Ci - Production 10/00
* Saleri Water Pump & Wahler Thermostat - 1/19
* Bilstein Touring Shocks/Struts - 8/18 & 12/18
* Meyle FCAB - 9/18
* BMW CCV - 7/18
* Rebuilt DISA using GAS Kit w/Fluoro O-Ring - 3/18
* Upper/Lower Air Intake Boots - 3/18
* Front/Rear Textar brake pads and Meyle rotors - 11/17
* Behr radiator, BMW expansion tank, hoses - 6/15
* Polk Audio db651s speakers
* Electric Fan Swap (CoolXpert)
2001Silver330CI is offline   Reply With Quote
Sponsored Links
Advertisement
Old 03-28-2018, 08:23 PM   #4
stevemd
Year: 2004
Model: 325xiT
Transmission: 5spd
Thanks.
Old 03-28-2018, 11:50 PM   #5
2001Silver330CI
Year: 2001
Model: 330Ci
Transmission: Auto
You're welcome!
* Meyle FCAB - 9/18
* BMW CCV - 7/18
Old 03-29-2018, 07:41 AM   #6
markusmarkus
My Ride: 2018 M240i
My “trick” to attaching that hose is to rotate the CCV body so that the bottom of the CCV body is facing the engine. Then route the hose down into position. Using a large flat blade screwdriver force the hose towards the CCV body. The rotate the CCV body so that the bottom is facing down.
Old 03-29-2018, 08:04 AM   #7
dmax
dmax's Avatar
My Ride: '16 340i xD 6-spd
Year: 16
Model: 340i
Transmission: 6-spd
My trick was to do it behind the manifold before I'd attached the valve...really frustrating. Good luck!
See Facebook for upcoming shows...and listen to my podcast!
dmax is online now   Reply With Quote
Old 03-29-2018, 08:09 AM   #8
stevemd
Year: 2004
Model: 325xiT
Transmission: 5spd
I will keep you guys posted. For laughs: I picked up a M56 valve (or cyl head) cover from the jy. Then I decided see what all the fuss was about these M54 CCV jobs since I already had a CCV kit on hand and never did one before. Dove in, much cursing eventually ensued.
Old 03-29-2018, 10:51 AM   #9
PabloCruise
My Ride: 2002 325i
Year: 2002
Model: 325i
Transmission: Auto
I have heard it is ultimately a less frustrating task if you pull the intake manifold when replacing the CCV.
And you can replace the vacuum tubing to the SAP at the the same time...
Can anyone confirm/deny?
PabloCruise is online now   Reply With Quote
Old 03-29-2018, 11:38 AM   #10
tcphoto
My Ride: E92 335 MT Coupe
I grimaced as I watched the video, remembering how I struggled to connect that hose running to the top of the manifold. I can understand pulling the manifold if you need to replace hoses and the gasket but I think the video is the best technique. Unfortunately, I don't have Trump sized hands and that made it challenging.
tcphoto is offline   Reply With Quote
Old 03-30-2018, 12:44 PM   #11
stevemd
Year: 2004
Model: 325xiT
Transmission: 5spd
Got 'er done, to paraphrase Larry the Cable Guy. I found it helped to pull off that fuel tank vent solenoid or whatever it is on the left side of the manifold (facing it from the side) and let it dangle down there. If I have to redo this ever again with engine in car, I'm going to do a M56 VC since I already have one sitting in the garage.
