Vert Rear Defogger / Defroster help - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Convertible
Old 01-02-2016, 11:07 AM   #1
Slupe
My Ride: 2004 330Cic ZHP
I cannot get the rear defogger/defrost to work on my 2004 330ci vert. Fuses are good, so I successfully located the two relays located by the passenger side rear seat. I removed and tested both relays by applying 12v and they operated correctly. I don't have a wiring diagram to know which wires run to the rear window, but with the car running and defrost switch on, I was also able to use my multi-meter and got power on all the wires from the relay. I can hear them clicking when turning on the defroster, turning on the car, and click off when I open the top. So, it seems I have power into and out of these relays. Does all of this sound correct?
Is there anything else between the relays and the rear window grid? I assume I should be able to test power to the grid with my multi-meter applying red to either tab on the window and black to ground. Any other suggestions?
Relay pic attached...
Slupe is offline   Reply With Quote
Old 01-02-2016, 12:13 PM   #2
taylor192
My Ride: 2003.5 M3
Broken wire? I'm assuming the defroster wires are part of the harness that bends with the top, and we know wires break at the bends.
Old 01-03-2016, 09:17 PM   #3
CarbonZHP
Because Race...Convertible?
CarbonZHP's Avatar
My Ride: goes choo choo
Year: 2004
Model: 330Cic ZHP
Transmission: AT->5MT->6MT
For my rear defroster, a single one of the heating coil stripes does not work. Right in the middle of the window. Kills me
Original Car: Silver Grey on Grey, A/T (1 of 186)
As it sits: Silver Grey on Black, M/T (1 of 51)
Instagram: @CarbonZHP
CarbonZHP is offline   Reply With Quote
Sponsored Links
Advertisement
Old 01-05-2016, 01:56 AM   #4
cityjohn
My Ride: 2001 M3
I used this and it turned out perfect. Just leaves a small wide repaired area but now the heater functions. Use a multimeter to locate the break.
cityjohn is offline   Reply With Quote
