Pa soft cable work w inpa? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 09-06-2014, 10:33 AM   #1
Slupe
My Ride: 2004 330Cic ZHP
I am still trying to fix an issue with my adaptive lights. I am moving from pa soft to inpa based on my searches. Can I use the pa soft cable with inpa or do I need a different cable?
Thanks!
Slupe is offline   Reply With Quote
Old 09-06-2014, 11:08 AM   #2
Justinz
My Ride: N54
Thanks!
I have tried it before and it did not work.
However there may be a way to modify it but I just bought a whole new cable for INPA/NCS use.
Justinz is offline   Reply With Quote
Old 09-06-2014, 12:24 PM   #3
bmray
My Ride: 330Ci aa stage 2
I have the INPA cable but not the computer savy to make INPA work with a windows 7 laptop. Can my cable work with pa?
bmray is offline   Reply With Quote
Sponsored Links
Advertisement
Old 09-06-2014, 12:31 PM   #4
Justinz
My Ride: N54
I believe they are not interchangeable at all, unless you did some type of modification to the cable itself.
Old 09-06-2014, 12:45 PM   #5
jfoj
My Ride: 330CiC, M5, X5, E93
PA Soft/BMW Scanner cable is basically a dongle or converter of some sort, it will not work with anything other than PA Soft/BMW Scanner as far as I know.
Most of the other programs require basic USB to OBDII cables.
Solve your misfires, lean codes, rough idle -
Fuel pump failures -
Temp Info -
Hidden OBC Menu - Check Voltage, Temp, Fuel Level -
E46/E39 GM5 Door Lock Info -
Old 09-06-2014, 12:49 PM   #6
Mattswn
My Ride: BMW 330ci
Will BMW 2013 327 17" wheels fit on my 2004 BMW 330ci convertible
Mattswn is offline   Reply With Quote
Old 09-06-2014, 01:09 PM   #7
Justinz
My Ride: N54
http://www.bmwstylewheels.com/
Find your wheel first are you looking for style 327 or 2013 328 17" wheels?
Old 09-06-2014, 02:12 PM   #8
Slupe
So i just looked at ebay and searched bmw inpa cable. There are a bunch for approx $20 that are k+can, but don't list e46 in the desc. Will these cables work or what exactly do i need?
Old 09-06-2014, 11:30 PM   #9
BaliDawg
Here to serve y’all
BaliDawg's Avatar
My Ride: E39 E46 E84
I have the PA Soft cable and the INPA cable and they are quite different internally. But honestly, I have never tried to use one in place of the other.
Can someone with knowledge of both these adapters please chime in and answer this?
BaliDawg is online now   Reply With Quote
Old 09-07-2014, 09:45 AM   #10
BartenderPlease
My Ride: '03 540i/6 M-Sport
Those cables you found will work.
'02 JR/Naturbraun 330i M-Tech I | M-Tech II Fr. | Supersprint Headers | Remus Sport |
.....| SM Flywheel Conv. | 18" CH'ish reps | Short Shift | Orion V2.5 | RCR LED Tail |
'03 JB/Schwarz 540i M-Sport 337 | Decatted | Short Shift | Carbon Trim | JL Audio | V1
BartenderPlease is offline   Reply With Quote
