What is this hose? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 05-19-2014, 10:36 PM   #1
Slupe
My Ride: 2004 330Cic ZHP
What is this hose?
I am losing a little oil and getting the burnt oil smell after driving. The PO replaced the VCG about 10K miles ago, but since that seems to be the most common issue, I decided to inspect for oil leaks and check the torque on the bolts.
I couldn't find any VCG leaks, but I see a cracked hose running along the intake manifold. Please help identify this hose in the first pic.
In the 2nd pic, you can see a little oil mucking up the Vanos line, but it doesn't look like much. Can a little bit here cause the smell too?
I really don't see much, so other suggestions are welcome
Thanks!
ID:	559043   Click image for larger version
Slupe is offline   Reply With Quote
Old 05-19-2014, 10:37 PM   #2
TheMagicalHindu
My Ride: '99 323ci +'00 328i
Not sure but have you checked out the engine CAD on realoem?
I am not a smart man.
TheMagicalHindu is offline   Reply With Quote
Old 05-19-2014, 11:18 PM   #3
dreiundzwanzig
My Ride: 2000 323i
The hose you have pointed to in the first picture is part of the CCV (Oil Separator) System. The CCV can leak oil over time, especially at the lower hoses of the unit.
http://www.realoem.com/bmw/showparts...94&hg=11&fg=15
Number 7 in the diagram (Note that the diagram may look a little bit different with the hose clamp on one end as it shows the early model hose, most CCV's I've seen have a snap fit connection there.)
dreiundzwanzig is offline   Reply With Quote
Sponsored Links
Advertisement
Old 05-19-2014, 11:23 PM   #4
Brandon002
My Ride: 01 330i Sport MtechI
It's part number 7 shown here.
It's called a return hose. Part number.. 11617504536
Can be purchased here. http://www.ecstuning.com/BMW-E46-330...rator/ES25712/
Brandon002 is offline   Reply With Quote
Old 05-20-2014, 08:04 AM   #5
Slupe
Thanks guys - I found that diagram on RealOEM, but it looks nothing like that. After your help and seeing some better pictures, that is definitely it. But I have more newbie questions...
Is this hose covered in an insulation (sort of like plumbing pipe insulation)? After doing more searching, I am wondering if just the insulation is cracked. I don't see any leaks around here and don't have any other issues with the CCV. That seems to be a royal PIA to replace, so I don't want to get into that unless I need to.
I am getting a check gas cap warning (small leak) that I am trying to track down, but I don't see how this could be related either.
Old 05-22-2014, 04:15 PM   #6
dreiundzwanzig
My Ride: 2000 323i
Yes, the hose is wrapped in insulation.
