Cluster made in 09/2001 or newer (edit: not 100% sure about this date cutoff after looking at some NCS Expert files. Might even be as late as 03.5). I'm sure it is possible to do this on early clusters too, but the software is quite different. I can research if a few of you send me a dump of your cluster EEPROM
Some common sense
As most of you know, E46 clusters tend to be optimistic. What you may not have known is that the DME and Cluster know the exact speed; the error is deliberate on BMW's part. There have been a few ways to correct this in the past; one way is to just trick the cluster into thinking you have smaller tires, but this can screw up things like MPG and average MPH calculations. Another way was to rescale the cluster curve itself, but this required a decent bit of trial and error and it was just fooling the cluster into thinking the scale was larger.
After studying M and non-M EEPROM files, here's what I found -- there is a function deliberately designed to increase the speed by a certain ratio. In the non-M, the displayed speed is the real speed + 5.7%. In the M3, the error is a massive 8.9% -- completely unacceptable IMO.
So here's what you do.
Start up the PASoft software and load your IKE. Read off the EEPROM.
Now, in the built in hex editor, look for the following hex string (pick the appropriate one for your model). In my cluster, it was located at offset 0x339
Save the file, and flash the EEPROM back to your cluster.
Done. If you have stock diameter tires, your speedometer should be almost 100% accurate
If you're curious as to how the change works, the bytes I change are used as a ratio. 0x25 = 37; 0x23 = 35. 37/35 = 1.057, or a 5.7% error. I am not sure what the 0xC8 (200) value represents; I think it might be an upper limit to the allowed error (5.7% until the error reaches 20 km/h). That last byte is simply a checksum (XOR all the values together, and then XOR with 1)
If you have a 99-01 cluster, please send me your EEPROM. I can't promise I'll figure out how to do the change there, but I'll try. Also, if there are any Japanese fanatics here, please send me a dump of your cluster. In the E39, the Japanese values for the cluster are 100% accurate; I suspect the same holds true for the E46. It would be interesting to see how BMW configured the cluster.
Also give me feedback; so far in my testing it agrees with GPS, but it's always nice to have others confirm too.
I’ve got a 99 323i and I went from 205/55-16 to 205/40-16 and Speedo and odometer are now 10% fast now! How can I fix both? Is the trip/odometer ratio adjustable?
Thanks!
@TerraPhantm I've tried to contact you trough PM, but apparently you're so popular that your inbox is full
I would like to change the MPG gauge to display the oil temperature, but I can't find too much information online. Maybe you could help me. Please inbox me if you can!
Im having the speedometer issue, but the other way around.
Driving around with 19 inch wheels, so my speedometer will show 100 while I m actually doing about 106.
Does the same trick work if I calculate a value that will result in a negative number?
Applied teras code to my cluster and I***8217;m getting a consistent 3 MPH difference between speedometer and GPS speed. I.E. I***8217;ll be doing 60 and GPS says 63. 80 and GPS says 83.
Early 2003 M3 with 255/40R19x8.5 squared
All codes expect ***8220;All models: 03 00 01 C8 00 01 CA***8221; gave me a PPPPP error. Any thoughts as to why I can***8217;t get it closer?
I need the exact code for my 330ci with 19 '' tires, and cluster m3smg, currently I have tried these 3 codes with no result, it has an error of 20km / h.
In hindsight I don't think it's actually a ratio. I think they're just different skew factors applied at certain speeds. Setting both to 0 should be true speed. Setting both to 01 like I had done before is close enough to true that it doesn't matter.
I'm not a computer-savvy person, and I don't see the option to "save file" anywhere. Also, when you say "flash the EEPROM back to your cluster," do you mean click "Write EEPROM"?
I'm sorry; I just need this all spelled out and I don't want to screw anything up, but I also want my speedometer to be more accurate.
One of the other menus in there had a box to enter how many counts of the wheel sensor per mile. I played with that until gps and speedometer matched. Never had to write new codes...
And I think there were two boxes. One for speed and one for distance. Factory had them a little different so the speed was slightly higher than actual
Under instrument cluster, click “coding data” and then “recoding”. Two of the boxes are for speed and distance in impulses per kilometer. Higher number should make your speedo slower and odometer read shorter than actual.
Just curious ... if I get a custom gauge overlay that has my stock 330 tachometer range coupled with a M3 speedometer ( minus the M logo ) would it be possible to edit the scale to match the mph? .... or would that mess up the odometer reading and mpg?
As you can tell, in the first post he figured out how to change it in the later models but wasn't positive about the earlier models. Well, I am here to help you out. He did figure it out, it's just hidden within the thread. I did this to my EEPROM and now I am within 1MPH at all speeds below 55mph. Above 65mph it moves to within 3mph I believe. (could be different on your car due to tire size etc)
Note: you can always confirm the location of the values using NCS Expert. "Well according to the daten files, there's a 16-bit value "TACHO_SKALA_ENDWERT" at 0xD2. This translates to "Speedometer Scale End Value" On your file it's set to 0x02bf (703). On the early E46 M3s, the same bytes are set to 0x032a (810). "
D2 and d4 are locations, or offsets, not values. Notice how in the left column there are values like (0x000, 0x010, 0x020... 0x0A0, 0x0B0, etc.)? Go to the row with 0xD0. The first value next to that offset label wiil be located at 0xd0. Then 0xd1, 0xd2, 0xd3, 0xd4, etc.
Maybe that "end" value takes into account that the cluster doesn't start until 10km/h, making it effectively a 240km/h scale or something. Either way 240km should "fix" the difference - guess the error is larger on newer clusters
Does anyone know how to do this using NCS expert and NCS dummy? I've managed to get the data from the module onto my computer using expert, but I don't understand what I should be changing the values to. If anyone knows how it'd be greatly appreciated!
I have e46 m3 2001. my car has 265-35-18 square setting. So the diameter of the wheel and tire gets bigger than factory spec, thus the speedometer reads almost 10% higher than actual speed. It actually bothers me a bit. I use M3 for track day for most occasion.
in this case What should I do to make speedometer to read actual speed? Should I run PAsoft and go to IKE then change number in "Distance / Speed values" and drive the car on the road and change the number again until satisfied?
Related Threads
E46 Fanatics Forum
17.9M posts
592.8K members
Since 2001
A forum community dedicated to BMW E46, E90, and F30 owners and enthusiasts. Come join the discussion about M performance, turbo kits, engine swaps, builds, modifications, classifieds, troubleshooting, maintenance, and more!
