*** Official E46 Lighting Guide *** - Page 5 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 102 votes, 5.00 average. Display Modes
Old 12-13-2014, 04:41 AM   #81
Solidjake
Shifting
Solidjake's Avatar
My Ride: 2013 328i 6MT
+1 ^ Those are flush from what I know (I've installed them for my customers)
The V2's I have are the first first ever ones made. They "should" be of a bigger diameter now but don't quote me on that. The Umnitza Orion Lites should be flush with the bowl edge.
Thank you all. I will move it to the lighting section later on today.
Old 12-13-2014, 05:36 AM   #82
ChuckyVee
My Ride: 2000 323i, '99 328is
Great video and great job explaining...helped me tremendously..thanks SJ!
First Bimmer..."Miss December"...2000 323i, purchased Dec. 2013 w/82K on the clock. PM thus far...pads/rotors, belts/pulleys, complete CS overhaul, FCABs, plugs, autotranny/differential service, fuel pump, filter, and relay. Full front end refresh with LCAs and bushings, struts and mounts, inner/outer tie rods, sway bar endlinks and bushings.
ChuckyVee is offline   Reply With Quote
Old 12-13-2014, 06:07 AM   #83
Solidjake
Shifting
Solidjake's Avatar
Sponsored Links
Advertisement
Old 12-13-2014, 09:26 AM   #84
DEADF15H
My Ride: 2001 325i Auto
Model: 325i
Transmission: Auto
Thanks Jake!
DEADF15H is offline   Reply With Quote
Old 12-13-2014, 10:04 AM   #85
Dbills
My Ride: 99' 328i
Info vid: E46 headlights explained
I got a pair of V2s probably 6 months ago after the V4s were released and that gap is still there. I actually contacted them thinking they sent me the wrong ones and they said thats how it is supposed to be.
Dbills is offline   Reply With Quote
Old 12-13-2014, 10:33 AM   #86
Dave1027
My Ride: '06 IR zhp coupe
So the halogens basically don't do a lot. Only work when you pull back on the stalk for flash to pass?
Old 12-13-2014, 10:52 AM   #87
Solidjake
Shifting
Solidjake's Avatar
They are highbeams (different option of a highbeam) that do light up the road very well as well (same as any highbeam on any other car) but in regards to if you have bi-xenon it depends how long you can hold the stalk back while being able to drive.
Old 12-20-2014, 10:53 PM   #88
inferno nexus
My Ride: F30 328i
Yellowish Xenon output
Hi Solidjake,
I recently had a P/S headlight replaced by a shop after a deer incident and noticed that the xenon bulb has a lower color temperature than the D/S xenon lamp. I tried swapping out the new xenon bulb with the old one (I told the shop I wanted to keep the old, damaged headlight assembly) but it's still appearing yellowish. Do you know what I can do to get a whiter light output? Do I have to swap in the old ballast or ignitor? Thanks!
inferno nexus is offline   Reply With Quote
Old 12-20-2014, 11:06 PM   #89
(510)330ci
My Ride: 330ci
Ive herd a 55w balist helps
(510)330ci is offline   Reply With Quote
Old 12-21-2014, 10:57 AM   #90
Solidjake
Shifting
Solidjake's Avatar
Inferno, so the white bulb on your drivers side turns yellow on the passenger side? It's probably the ballast. Just make sure that both of the headlight assemblies are the same make (Such as AL)
As for 510 with the 55 watt ballast, I wouldn't do it. The car is coded specifically and meant for 35 watt ballasts.
Old 12-21-2014, 02:46 PM   #91
inferno nexus
My Ride: F30 328i
Both headlights are the AL brand.
I have not tried that yet, but I'll swap the old ballast in and see if it works. Thanks!
Old 12-21-2014, 02:49 PM   #92
Solidjake
Shifting
Solidjake's Avatar
Yup yup, let us know
Old 12-24-2014, 09:39 AM   #93
lllRazorlll
My Ride: Accord Coupe
My passenger side HID bulb doesn't turn on until the engine warms up. This usually happens when it's cold out like now during the winter. What causes this?
lllRazorlll is offline   Reply With Quote
Old 12-24-2014, 11:30 AM   #94
Solidjake
Shifting
Solidjake's Avatar
OEM xenon system in the car? Ballast might be having the issue in the cold, but what I would do is swap bulbs around just to make sure it stays on the passenger side.
Old 12-24-2014, 07:32 PM   #95
lllRazorlll
Nah it's aftermarket stuff from TRS. I have Matsushita Gen V Ballasts, Morimoto Standalone Can Bus, and D2S Osram Xenarc 66240 CBI Bixenon Bulbs. I'll try swapping it over and seeing what happens.
Quick question: If I purchase an OEM xenon headlight (with everything included including ballasts, canbus) I can just plug it in and drive off right?
Old 12-24-2014, 07:34 PM   #96
Solidjake
Shifting
Solidjake's Avatar
From what I know.... yes. But not sure how your connector is for the bulb at the base. Have pics of that?
Old 12-24-2014, 10:26 PM   #97
lllRazorlll
Is this what you're looking for? http://www.theretrofitsource.com/med...llasts_4_1.jpg
This is what I have
Old 12-24-2014, 10:47 PM   #98
Solidjake
Shifting
Solidjake's Avatar
Yea, because the bulb carrier for my headlights at least twist into the housing to hold the bulb in
Skip to 4:30 in my vid
Old 12-25-2014, 03:00 PM   #99
lllRazorlll
Yeah, my bulb carrier operates the same way. I will try to swap bulbs and see what happens.
Edit: So I swapped bulbs and it turns out that it's one of those two parts I mentioned above except the bulb...I don't know if it's something I should be too worried about...
Old 02-06-2015, 02:27 AM   #100
alexs.lens
My Ride: 2003 BMW 330i
http://www.theretrofitsource.com/hid...l#.VNR5qGh4oe0
http://www.ddmtuning.com/Products/DD...ast-35W-or-55W
Excuse the stupidity, but I am new to the e46 world.
I have a facelift 330i with auto-leveling projectors.
Are these what I need if I want HIDs?
alexs.lens is offline   Reply With Quote
