Dash Cluster lights replacement? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 11-25-2019, 11:34 AM   #1
nurp
My Ride: 2000 323i / 75 2002
Can the instrument lights in the dash cluster be replaced? The coolant temp gauge light has gone out. Very dark in that corner. Can not find any information on the replacement of the led's that do the collant gauge.
nurp is offline   Reply With Quote
Old 11-25-2019, 04:37 PM   #2
bremerd1
My Ride: 323
Year: 2000
Model: CI
Transmission: ZF 5HP19
Hi! If it's just the LED, yes if you are handy with a soldering iron - they are small, but a steady hand and some Amazon LEDs, and it's perfectly doable.
I've tried this a couple of times over the years, and not had any success (nothing wrong with the soldering jobs or replacement LEDs). It's never actually been the LEDs that have failed. The traces tend to lift off the PCB or some other failure has occurred every time I've tried to make a repair.
Some things I've picked up along the way: The shop I've used (https://dnaspeedometers.com/) hasn't been able to fix light issues when I take them just the cluster - They've needed the car with it (I'm local to them, so it's not a problem for me). Something about the lights not being checked on their test gear, so they don't have a good way to check it without the car. On the positive side, if you take them a cluster (and car), they check and repair it _all_ if they find any other issues along the way...
You may want to see if there is a speedometer repair shop local to you - it wasn't all that expensive to have done by a professional - under $200 each time I've had one repaired.
You could always 'piggyback' using some very thin wire to one of the working LEDs (on a new LED), but that isn't a 'correct' repair, and didn't sit right with me...
Hope this helps!
Dan B
bremerd1 is offline   Reply With Quote
Old 12-27-2019, 05:57 AM   #3
markusmarkus
My Ride: 2018 M240i
You can also get the LEDs at www.mouser.com.
Sponsored Links
Advertisement
Old 01-10-2020, 03:14 PM   #4
DaveCorey
My Ride: 2000 328i
Jumping onto this thread to see if anyone has a part number or other spec numbers for the dashboard LEDs, in the original amber color. I have the exact same problem as OP, with the temp gauge going dark. Thanks in advance!
DaveCorey is offline   Reply With Quote
