Expansion Tank Doomsday! - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Closed Thread
Old 02-24-2014, 11:53 AM   #1
hummer
My Ride: 2001 330CI
Told everyone here that I would let you all know when my tank failed. Finally happened last week with a crack on the corner just below the power steering lines. Drove it for two weeks like this with some dripping and refilling. So, 12 years, 11 mos, 199K miles. Radiator still looks OK but it will be replaced along with the original upper and lower hoses and a non-fuctional heat control valve. The only cooling system parts replaced up til now are a water pump (Stewart) at 120K and I'm on the 4rth thermostat. They ranged from the first failure at 30K to being replaced with the pump at 90K. The third failure was 65K.
hummer is offline
Old 02-24-2014, 11:55 AM   #2
yoyomin
My Ride: 2002 330i
how did your t-stats fail? stuck open?
yoyomin is offline
Old 02-24-2014, 12:38 PM   #3
Knight
My Ride: SL63 | SHO | E46
SOB couldn't make it to an even 200K, huh.
Knight is offline
Sponsored Links
Advertisement
Old 02-24-2014, 01:05 PM   #4
KaktusJaque
My Ride: 2005 M3 ZCP
With all the talk about cooling system replacement, and your longevity here on this forum, I am a bit curious as to why you haven't changed out these items long ago as a PM?
*KJ---Don't Believe Everything That You Think! *
Links
2005 M3 ZCP (KJ's Weekend Ride)
2003 Touring 325 XiT (In Storage)
2004 Coupe 325 Ci (Donated to KarsforKids)
KaktusJaque is offline
Old 02-24-2014, 01:13 PM   #5
white46
My Ride: e46 323ci
Originally Posted by KaktusJaque View Post
With all the talk about cooling system replacement, and your longevity here on this forum, I am a bit curious as to why you havenít changed out these items long ago?
Guess because it hasn't failed yet until.
OP sounds like he is mechanically inclined.
white46 is offline
Old 02-24-2014, 02:00 PM   #6
Solidjake
Shifting
Solidjake's Avatar
My Ride: 2013 328i 6MT
Why did it take two weeks to replace it before it failed?
Solidjake is online now
Old 02-25-2014, 07:31 AM   #7
mwk4Jesus
My Ride: 2004 330Ci 6M
Only 199K? I knew those things were just a ticking time bomb!
Romans 8:28
mwk4Jesus is offline
Old 02-25-2014, 08:50 AM   #8
WDE46
My Ride: '13 128i STX
Sample size: 1
WDE46 is offline
Old 02-25-2014, 09:11 AM   #9
Manolito
My Ride: '04 325iT Manual
Year: 2004
Model: 325iT
Transmission: Manual 5 sp
You got your money's worth out of that radiator and expansion tank. Those of us who have wives, daughters, and girlfriends driving our cars don't dare push the limits like that.
Manolito is offline
Old 02-25-2014, 10:12 AM   #10
Knight
I think this is an excellent point. We are more in tune to our cars so sometimes pushing limits to experiment can be fun, but if you are maintaining a loved one's car who A-B's it, I wouldn't play around.
Knight is offline
Old 02-25-2014, 10:54 AM   #11
gman35
My Ride: 2006 bmw 325ci
my ET just failed at 66k original miles on our 2006 325ci, dealership charged $593 to do ET,transmission thermostat,oil change, chnge and fill coolant, and new upper radiator hose. They said valve cover and oil pan gasket are also beginning to show signs of seepage, so that will be next...Gggg
gman35 is offline
Old 02-25-2014, 11:00 AM   #12
hummer
My Ride: 2001 330CI
Because I don't subscribe to the "sky is falling" approach to car maintenance! Some things I do do based on miles or age. But, I don't replace parts simply because someone else may experience a failure and report it here on the WEB. And I don't like throwing money away for no good reason. I troubleshoot the problems and replace parts as needed to fix the issue. I'm the only one that drives the car and don't have to listen to guff from anyone but me.
It started leaking a few weeks ago and I drove it that way adding a little coolant every other day. Had a warm day last weekend so I went investigating after replacing the FSR and found the crack in the tank and the cold heater hoses.
Thermostat always failing closed is another wives tale! My thermostats have failed both ways. The first one was running cold then shot into the red. The others were sticking open.
hummer is offline
Old 02-25-2014, 11:02 AM   #13
74123
Guest
My Ride: 320i SE Coupe
Evidence would seem to suggest PM is a waste of time and money. I have never had a coolant failure that caused me any more inconvenience than the inconvenience of replacing parts that don't need replacing. At the end of the day your car is off the road while the work gets done.
74123 is offline
Old 02-25-2014, 11:34 AM   #14
WDE46
I don't think I've even heard of anyone's thermostat on their E46 failing closed. Nobody reports that.
"someone else" is hundreds (maybe thousands) of people on these forums reporting ET pops and overheats as a result.
What is reported is ET failures starting around 100,000 miles and going up from there. The smart thing to do is to replace it around then so you don't risk a catastrophic failure causing an overheat. That will cost you many times more than a simple tank or overhaul. It's rational and far from a "sky is falling" attitude.
I await your headgasket thread or the "stranded" thread when your FP goes out
WDE46 is offline
Old 02-25-2014, 11:36 AM   #15
WDE46
Have you not seen the large quantity of posters who write about their experience with cooling parts failures? They overheat and ruin the head gasket and warp the head. Not worth it.
WDE46 is offline
Old 02-25-2014, 11:40 AM   #16
Solidjake
Shifting
Solidjake's Avatar
Thread closed. OP got his experience out in the open. Not letting this thread turn into another cooling system war.
Closed Thread
