E46 transmission warnig light and jolt after an atf change - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 10-21-2011, 12:44 PM   #1
Efanatic
My Ride: '04 e46
I recently brought my car to a reputable shop that specializes on BMW cars..
these are things that they did on my car
- change atf
-atf filter
-atf gasket
-oil filter gasket
-change O-ring
then we started the car ive noticed that the transmission warning light went "ON" then he diagnosed it over the computer and he said that every is working normal.
so on my way home ive noticed that whenever the tranny downshifts i can feel a strong jolt/jerk..but before i bring my car to the shop i didnt felt that jolt..hope you can share on your inputs on this...thanks
Efanatic is offline   Reply With Quote
Old 10-21-2011, 12:49 PM   #2
liquiddawn
My Ride: 2001 BMW 330i
Ooooooooooh boy! This is exactly what I don't want to hear. There are so many variables. What fluid did he use? Are you sure he filled the fluid correctly and that the fluid is full? I mean even though a few people have reported their tranny failing after a fluid change, I seriously doubt the failure happened as soon as they changed the oil.
First, I would stop driving the car immediately and second you need to bring it back to the shop and have them recheck all of their work.
liquiddawn is offline   Reply With Quote
Old 10-21-2011, 12:57 PM   #3
Efanatic
My Ride: '04 e46
they use red line d4 atf..i asked the mechanic how many liters...he told me that he put 6 liters of atf..
Sponsored Links
Advertisement
Old 10-21-2011, 01:02 PM   #4
liquiddawn
Well, did he read the transmission sticker to make sure that it was the correct ATF you need before just throwing it in there? Not all of our trannys use the same fluid! This doesn't sound good. Do you have an automatic or manual by the way? This would be helpful to know.
Old 10-21-2011, 01:28 PM   #5
HyphyMovementZ
My Ride: ZSP, DC5, EM2
My e46s bout 160k drained and filled with textar no problems smoother shifts, but definitely more than 6qt
HyphyMovementZ is offline   Reply With Quote
Old 10-21-2011, 02:34 PM   #6
BmwPerfection
BmwPerfection's Avatar
My Ride: 3.5 M3 & 00 323ci
Send a message via AIM to BmwPerfection
Redline fluid works just fine, its what i use. BMW labels their fluid "lifetime" but preventative maintenance always works. I would keep driving the car and if you experience any tranny problems, then definitely stop driving it and take it back to the shop.
BmwPerfection is offline   Reply With Quote
Old 10-21-2011, 02:38 PM   #7
moiz21
My Ride: 1999 323i 5-SPD
Redline should be fine. It sounds as though it wasn't filled completely. My brother's car did the same thing. He jacked his car up at an angle. Was fine at first, but later on developed jolts as it was shifting. I put the car up in the air again, on all 4 points, and pumped more fluid in. Took almost 2 more bottles of D4 before it began to overflow. Problem solved.
MODS
P46 Projectors + FX-R Retrofit + 6k D2S / 60 LED AE's / Smoked LED Tails / Smoked Turn and Side Markers / BSW 10" Sub /ZHP Knob / Matte Black Grills / DICE / Parrot + Connects2 / OEM Alternative Alarm Mod / Clutch Switch Delay Mod / M3 Rep Front Bumper / 3M Black CF Di-Noc Wrap / K&N Intake / 35% Tint All Around / Black Short Eurotray / 545i Shifter
moiz21 is offline   Reply With Quote
Old 10-24-2011, 09:11 AM   #8
Efanatic
My Ride: '04 e46
guys problem solved regarding the jolt..when i pop the hood they forgot to connect the wire on the MAF sensor..thanks for your inputs..but ive noticed when i parked the car overnight there is a delay when on the transmission about 5-6 seconds but after that it will run normal again...what could be the cause of transmission slip on cold start...thanks
Old 10-24-2011, 11:35 AM   #9
liquiddawn
Like someone else stated above, they may not have filled up with the correct amount of fluid. You should take it back and make sure the fluid is topped off.
Old 10-24-2011, 12:26 PM   #10
cvx5832
My Ride: 535i, 325Ci, C300
I'm sorry about your troubles. With proper maintenance these transmission will last longer than you intend to own the car. As far as Redline D4, I'll also chime in with my "approval". 34k on current Redline D4 charge and all is well.
My suspicion is also on a possible underfill. I hope the garage remembered that the tranny has to be put through the gears (then left in neutral) with engine running and brought up to temp before filling. Were you able to watch the filling process? If the car wasn't running, then the tranny is definitely underfilled.
Big difference from a manual tranny where it's supposed to be checked with the engine off.
cvx5832 is offline   Reply With Quote
Old 10-24-2011, 03:19 PM   #11
Jim Clark
My Ride: 2001 330Cic
There's no such thing as lifetime fluid. On the auto trannies, you need to do a complete flush, it requires special equipment and people who know how to use it.
Jim
2001 330Cic, Oxford Green Met, Sand, Step, Premium, Sports
Jim Clark is offline   Reply With Quote
Old 10-24-2011, 03:34 PM   #12
illogik
My Ride: 325i, A3
Big + on bringing the temperature up for the refill.
illogik is offline   Reply With Quote
