ISAless Help - Page 11 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 05-05-2017, 10:57 AM   #201
daniel_f.
My Ride: 330iC
In the lower boot i will place the blow off valve from an Audi 1.8t
No further development on MS4x from me.
Old 05-05-2017, 12:50 PM   #202
xi46
My Ride: 2002 330xi ZPP/SP/CW
Thanks for the ISA port cap model. I don't have a 3D printer but I'm sure I can find one to use temporarily.
I imagine you're running a turbo? If so wouldn't you want the BOV before the MAF, or is your setup different?
xi46 is offline   Reply With Quote
Old 05-06-2017, 12:53 AM   #203
Blu302
My Ride: '98 E46 323i
Year: 98
Model: E46
Transmission: Manual
The best setup is a plumb-back after the MAF.
_______________________________________________
Power is knowledge, So share the knowledge!!
Blu302 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 05-09-2017, 09:28 AM   #204
cwarel
My Ride: 330ci coupe
My brand new lower boot ruptured under 10 psi of boost
RIP 18 bucks
cwarel is offline   Reply With Quote
Old 07-08-2017, 04:02 PM   #205
Paul_13
My Ride: E46 330i touring
I tried this mod earlier and resulted in a non starting engine.
I think I cocked up by not resetting idlespeed (fluid?) adaptations.
I take it I'm ok just bunging off both connectors and unplugging the ISA?
Paul_13 is offline   Reply With Quote
Old 07-09-2017, 05:57 AM   #206
daniel_f.
My Ride: 330iC
You need to correct checksum4 in order to make the DME happy.
Old 07-09-2017, 07:53 AM   #207
Paul_13
Brilliant thanks
I used MPPS in the end as it has a check sum tool built in
Old 07-09-2017, 08:19 AM   #208
Paul_13
Still won't work
Old 07-09-2017, 08:38 AM   #209
Paul_13
When you say correct checksum4, what do you correct it to?
I corrected to the tune which has the ISA valve. Said 2 checksum errors were found, didn't mention chk5 or chk4
Old 07-09-2017, 01:18 PM   #210
LKMT
My Ride: N/A
Checksum 4 is an addition checksum that the dme uses to verify that the _mon_ values in the calibration file are not corrupt.
The variables that the dme uses to calculate this checksum is located in the program section so tools like Ultimo Checksum Corrector can only correct this checksum in a 512KB file.
If you are using 430056 you can disable this checksum by setting lc_swi_cal_mon_cks to 165(0xA5).
LKMT is offline   Reply With Quote
Old 07-09-2017, 02:06 PM   #211
Paul_13
Thanks for your help
Old 07-09-2017, 10:16 PM   #212
armenh7
My Ride: 2002 325i
In order to disable that, do we need winols? Or can it be done in tunerpro?
armenh7 is offline   Reply With Quote
Old 07-10-2017, 01:38 PM   #213
LKMT
My Ride: N/A
It can be done in Tunerpro. lc_swi_cal_mon_cks is located in the ConfigSwitches category. But from what I have seen it's only correctly defined in the 430056 xdf.
Old 07-10-2017, 11:25 PM   #214
VladBelsky
My Ride: E46 roadster/E85 Z4
Year: 2003
Model: 3.0i
Transmission: 6-speed
...So heres the deal: Siemens did use the MS43 on a different vehicle with the same throttle like we have, but without the ISA. Unfortunally the engine is pretty different (2.5 V6 without Vanos but Dual-DISA etc) so digging through all that code is very time consuming. There are many differencies even in the tune section where there is no damos or xdf either, so even more time consuming.
Fact is, that engine runs rock solid even with auto gearbox, so its basically just a matter of finding the right maps and constants and try to replicate them.
"Unfortunally" our babygirl will get all my love and spare time, so it is not an easy task.
I havenŽt found a way to share just the needed strings of code, so that others could help identify changes needed and further improve the ISAoff files. IŽll try to find a solution.
Land Rover Freelander L314, with the Rover KV6 engine, for anyone who is wondering.
VladBelsky is offline   Reply With Quote
Old 07-13-2017, 05:24 AM   #215
Michel20
My Ride: 528iA LPG
Is it a problem on stock MS42 M52b25tu with M54B30 intake, ISAless with the cap? Could the old ISA be wired. Must ms42 be flashed for this?
Michel20 is offline   Reply With Quote
Old 07-16-2017, 02:29 AM   #216
computiNATEor
My Ride: 10/01 E39 530i5
Anyone willing to test ISAoff with automatic gearbox? We made some nice progress and think we found the problem. Car should be in stock condition, not boosted.
I have two 02 BMW 530is; one automatic, one manual. Both are stock. Would you still like a test candidate?
Thanks for all your hard work!
computiNATEor is offline   Reply With Quote
Old 07-16-2017, 11:32 AM   #217
daniel_f.
My Ride: 330iC
Shure, remove and block the isa airpath and use the latest settings in the wiki.
Old 07-16-2017, 06:37 PM   #218
computiNATEor
Cool; I have a little bit of maintenance to get to first, but I'll report back when I can.
Old 08-23-2017, 02:49 PM   #219
Kopfspringer
My Ride: BMW e39 Supercharged
Year: 2001
Model: E39
massive problems with ISALess Config
Hello together,
i have massive problems with the ISALess Configuration.
I adapted all Tables and Configswitches like the Wiki shows.
But my Car won't start. I corrected Checksum with Ultimo Checksum Corrector.
I get "Motornotprogramm" and Error shwon in the Picture. Sometimes there is another Error too, sayin something from ECU Error...
I run FI Environment. Before switching to Isaless my Car run quite smooth for about 5 Minutes then i get ISA Harware Error and so on, so i decided to go to ISALess.
My bin is also attached. Maybe someone can help me...
Thank YOU!!!
File Type: pdf MS430056_M54B25_fewMaps_part_Kompressor_ICV-Delete-CHKcorrected_V2.pdf (64.0 KB, 17 views)
Kopfspringer is offline   Reply With Quote
Old 08-23-2017, 03:00 PM   #220
Paul_13
Have you seen in the posts above about checksum4?
Also probably a daft question but do we completely remove the ISA and unplug it?
